Question about Toshiba 26HF84 26" TV
Toshiba 26HF84A has No video
On screen display o.k, sound o.k, menu o.k
no pic
  • andrewcabage Feb 27, 2008
    i have the same problem any ideas anywhere thanks andy
  • motoxyz Nov 23, 2008
    Same problem here as well. Apparent cause is a drop off of my couch of about 18 inches onto its top. All menus display OK, although there is occasionally some flicker in the display. Sound comes through without any problem.
    Model: Toshiba 26HF84A
2 Suggested Answers
atang1
  • 734 Answers
SOURCE: Toshiba D-VR35 when i put in
Electronis circuits do not like moisture, which is your problem here. You have to dry the unit by turning it on, until dried up, then all the elctronics functions will work again.
Posted on Mar 10, 2011
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
May 13, 2017 | Sony Televison & Video
Hi I hv a toshiba smart tv it's two years old , it comes on but does not hv pic it does hv sound
if you choose the menu does it display menu items or is there no image at all? No image at all when you press menu would mean the backlight is likely not working and requires repair. If you do get menu items on screen check the image settings and ramp up brightness and contrast
Jan 14, 2016 | Toshiba Televison & Video
Toshiba 26HF84A TV turns off
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 07, 2017 | Toshiba 26HF84A TV
Medion MD 84100, i accidently changed the video output setting, i get sound but no pic, plz direct me through the menu to change back
Boot into Safe Mode by pressing F8 during boot. Lower your screen resolution. Right click desktop > Properties. Lower Screen Resolution.
Oct 01, 2012 | Medion Computers & Internet
Television turns on, but no video or sound
If you do not also get the On Screen Display/Menu you have a bad board somewhere==
Double check your connections and let me know as much as you can about the problem
I am here to help
Mar 15, 2012 | Toshiba 37CV510U 37 in. LCD HDTV
NEXXTECH need codes for toshiba tv
universal remote codes for Toshiba are as follows:
112, 313, 413, 419, 506, 510, 512, 517, 613, 902
Mar 14, 2011 | Toshiba 26HF84A TV
Brand new canon slr camera. can't see a live pic on led
Canon 350D can only take picture it does not take video. On screen of course you can play the photos you have taken. But that is all.
Feb 28, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Have a toshiba 27df47 flat screen tv. how do you
First make sure the video inputs are not locked using these instructions:
To set up the video lock:
1. Press MENU, then press or to display the LOCKS menu.
2. Press  or to display the password entering mode.
3. Use the Channel Number buttons (0-9) to enter your password,
then press ENTER. The LOCKS menu appears.
4. Press  or to highlight VIDEO LOCK.
5. Press or to select:
• OFF: Unlocks all video input sources.
Then it appears that choosing Video 2 using the TV/VIDEO button should enable the front input.
An entire manual is avialable here that should closely match your tv:
http://www.tacp.toshiba.com/tacpassets-images/models/27DF46/docs/27DF46_om_E.pdf
Aug 29, 2009 | Toshiba 27DF47 27" TV
Toshiba 57h81 with sound and no pic? no menu but guns are lit???please help...ps just replaced stk392-110 with same...before this happened...removed screen to clean and when replaced back on, i got...
After the set has been on for 20 min., the heat sinks on those should be nice and warm. If they are then if you have a stand-up video I/O board with plug in jacks, make sure it is seated properly.....Try this first and let me know.
Aug 14, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 32" LCD video doesn't work anymore
Lamp has gone out, sounds like...accordianman
Feb 27, 2008 | Televison & Video
Toshiba 26HF84 26" TV Logo
168 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
