Question about SanDisk Sansa m240 MP3 Player
My Sansa m240 does not play music, it freezes.
My Sansa m240 just stopped when I was listening to music from my song list. The FM radio works just fine. When I try to play music it says "no files" and freezes. When I connect it to my XP pc it no longer appears as Sansa m240 but MTP device. I tried to format it but it does not appear on the disk management window. Is there any hope? Please help!!!!!
  • Anonymous Jun 25, 2008
    The SanDisk will play for a little while then freeze and say "no files". FM radio works fine. I tried changing the battery but still won't work. Can it be fixed?
  • Anonymous Jun 26, 2008
    My Sansa m240 does not play any music, I can turn it on but it does not do anything else
Try going into your USB Settings on your device and ensure the unit is set to msc
Posted on Jan 10, 2008
I cant find place to add music files to my player, SanDisk Sansa m240... I go to my computer open the files and find no music library
use windows media player... open WMP connect your player it should recognize it... use this to sync music to your sansa...you highlight the songs in WMP right click ... go to add music .. select sync .. once you get the songs into a sync list ... you just sync the sansa...
Oct 16, 2009 | SanDisk Sansa m240 MP3 Player
Normal Play
Hello!!
If u have reset pin on the player .. try resetting it ...
Cheers!!
Aug 05, 2009 | SanDisk Sansa m240 MP3 Player
My sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
Jul 15, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk 240m mp3 not playing
the radio and mp3 uses one audio amplifier, check if you have loaded your music with mp3 songs, if not load with mp3 songs. if songs used to play and just stopped playing, then follow these steps,
i does your display show song playing, if it does then your set is fault, and if it doent and display unsuppoted, load with mp3 songs.
ii if it was playing and just stopped, than take it to a tech, who can open it and check the change-over switch, or selector of that set.
iii the problem is to very big.
Mar 30, 2009 | SanDisk Sansa m240 MP3 Player
Unable to play all songs downloaded on sansa clip
You have to resyhnchroize within Rhapsody itself to make the message go away.
Oct 19, 2008 | SanDisk Sansa Clip MP3 Player
Music mode screen is frozen after listening to FM radio
press the middle button and the power button for q0 seconds
Oct 11, 2008 | SanDisk Sansa e260 MP3 Player
M240 freezes all d time
I would format the device to remove all of the data and start over.
You can FORMAT the device thru My Computer>Device Name (m240)>Right Click and select FORMAT.
Best of Luck.
Nov 11, 2007 | SanDisk Sansa e250 MP3 Player
Certain songs wong work
get a refund. It needs to be relicened on the net
Nov 09, 2007 | SanDisk Sansa e260 MP3 Player
Sound
When I have this problem, I go to the menu, highlight fm radio and the sound comes bac. Then I go back to 'play music mode' . It's worked every tme.
Jul 22, 2007 | SanDisk Sansa m240 MP3 Player
Sandisk m240 freezes halfway through playlist....
When you disconnect be sure to use windows' disconnect device safely  thing on the bottom right part of the screen by the clock. Even though the player says it's not writing it probably still is even after a long period of time so if you just unplug it it will mess up whatever mp3 it was transferring at the time.
Nov 26, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
103 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
