Question about Mustek Plug-n-Scan 1200 UB Plus Flatbed Scanner
Was working ok, then next time came to use pop up says "not connected check cable",reinstalled drivers & checked cable but still not good
  • 35 Answers
Are you working with Windows XP? If so, have you done a recent windows update? Uninstall drivers and use windows default drivers as PnP= Plug and Play scanner.
Windows should allow you to use the scanner as PnP.
Other than this. Have you Googled for other drivers? Try the Drivers Guide and type in Username: drivers Password: all
You may have to register for free but they will give you 10 free drivers a day and all the drivers are rated with feedback and comments.
Posted on Nov 16, 2009
I have a hifonics brutus 1700. I burned one of my subs out the other seems to be okay, but now I have no sound. The protect light doesn't come on and it looks all normal. What can the problem be??
Here's a few things you can do to find out what's wrong ,first make sure you have 12volt on your batt lead and your remote turn on and make sure you have good ground.Take an ohm meter or a 9volt battery and put across/momentary the voice coil on your good sub should read somewhere between 2-8 ohms,if using a battery speaker should pop.if ohms check out or speaker pops your good connect it to your amps output.Next make sure you have a signal to the amp,if you have multiple amps use the rca cable from amp that's working for testing purpose.if all that checks out you'll need to have your amp check by professional
Mar 06, 2015 | Hifonics Car Audio & Video
Tip
Tutorial to connect lg phone to a P C
<b>This tutorial works for most of d lg cellphones which don't provide a dedicated application to make our task easy.... <br /></b>Generally frm LG mobile official website (<a href="http://www.lgmobile.com">http://www.lgmobile.com</a> <span>[nofollow]</span>), we don't get pc-suite like nokia to make our tasks easy, dey just provide USB modem driver for recognising ur mobile....<br />Requirement,<br />A LG cellphone, a usb cable, usb modem driver frm LG website.........<br /><br />Steps-<br />1-connect ur mobile & ur OS will ask u to install driver for nw hardware found<br />2-Locate d downloaded driver and install it as prompted....<br />3-Go to device manager (type devmgmt.msc in run box frm start menu)<br />4- Look for ur new device installed under com & ports section & note com port no...<br />5- go to control panel - phone & modem option- add - select- "don't detect my modem" - next- under standard modem types - select standard 33600bps modem- next- select d com port u noticed in step -4 - next/ok<br /><br />Now check if everything is ok by selecting now installed modem - properties- diagnostics - query modem........<br /><br />Now follow d procedure mentioned in d above post by admin to set up gprs connection........
on Jan 29, 2011 | Cell Phones
Printer not talking to desk top.
Please check usb cable first, make sure that it is ok. Then check usb port,move the usb cable to other port. Then check if usb cable and port are ok, try to connect other printer or device by using that usb cable and port. If works well means the usb port on printer got a problem. But if still not work the problem could be on usb cable or usb port on computer.
If you are sure that both the printer and computer are ok, try to reinstall the printer driver. Good luck!.
Source: Printer Clinic - Where printer problem get solved
Sep 18, 2012 | Canon Pixma MX310 All in One
92 wrangler wont start
Jiggle the wire connectors going in to the computer under the hood -- first check battery cables/terminal connections at battery -- beleive it or not, connection could SEEM good because you get crank & lights, but if it's faulty, loose, engine won't start - computer requires good solid voltage flow.. next check a fusible link very close to the battery off of the positive cable. check fusible link carefully. this could cause your problem for sure.
Aug 10, 2012 | Jeep Cars & Trucks
I have a behringer EP1500 amp, connected to a behringer mixer VMX100. i am getting a popping sound, the sound is random, it happens at various times, so i cannot say it always happens after i have...
hi,
check the power outlet socket to which the amp and mixer is connected. if there is any loose contact in that power socket, this problem can occur. try to use a good surge protector with emi filter for connecting the amp and mixer.
ok
Dec 29, 2010 | Behringer Audio Players & Recorders
I have a samsung printer ML1210.I have installed the driver that came with it but every time i reboot the computer or switch the printer on a bubble pops up in the corner saying new hardware detected it...
you may want to try switch to a next usb port or replace the usb cable. it just seems more like your pc is not getting the correct reading from the usb connection.
try to reinstall the driver again once you swap the usb cable to other port.
test by switching your printer on and off again to see if the same error pop up saying new hardware detected. if it does happen again. uninstall the driver & download it from www.samsung.com
May 19, 2010 | Samsung ML 1210 Laser Printer
My HP 5370C scanner no longer works. When I tried to scan, a blank white image appeared. Tried a few more times, same thing. The next day I tried scanning again a pop-up appeared indicating ,no scanner...
The problem is in the connection cable, Check the cable that connects your scanner with your computer, If still not working, try replacing it with a new one.
Jan 26, 2010 | HP ScanJet 5370C Flatbed Scanner
Samsung SCH U440 won't connect with PC Studio 3 via USB
first pcsuite install before driver install your phone connect it now working , or your phone connected cable already install pcsuite next yor phone pcsuite cd insert pc next connected data cable display find new hardware plse search install driver automatic two times try it now working
Jul 07, 2009 | Samsung SGH-D980 Cell Phone
My computer has not accepted my new hp all-in-one
Hi you may try:
1) connect to other PC install driver and test if ok mean printer and driver work normal. if not ok, change cable test again. this step should be done to make sure the printer good or not.
2) change a USB interface on your PC cancel old driver and reinstall driver test, if still not connect
3) virus attack damage your system somewhere, recovery your system files using antivirus scan or system recovery using system restore tools. not solve go next
4) reinstal windows
Dec 22, 2008 | HP Office Equipment & Supplies
Mustek Plug-n-Scan 1200 UB Plus Flatbed Scanner Logo
67 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Tony
Mike
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
