Question about Whirlpool Duet GHW9150P Front Load Washer
I have a older Whirlpool Duet and it is coming up with the code 13 F. What does that mean. I can't find the manual.
  • 35 Answers
Have you tried pressing Pause/Cancel twice?
Posted on Nov 16, 2009
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
Problem with whirlpool w/m adp4737
Whirlpool Duet & Duet HT & Kenmore w/110 model prefix Frontload Washer Error Codes-OLDER
  • F/H--No water detected entering machine or Pressure switch trip not detected
  • F/02--Long Drain
  • F/05--Water Temperature Sensor Error
  • F/06--Drive Motor Tachometer Error
  • F/07--Motor Control Unit Error
  • F/09--Overflow Condition
  • F/10--Motor Control Unit (MCU) Heat Sink Thermal Trip
  • F/11--Serial Communication Error
  • F/13--Dispenser Circuit Error
  • F/14--EEPROM Error
  • F/15--Motor Control Unit (MCU) Error
  • Sud--SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
  • F/dL--Door Lock Error
  • F/dU--Door Unlock Error
Jan 01, 2012 | Washing Machines
Whirlpool Duet Washer error code A10
If the thermal protector on the MCU heat sink gets too hot, it will open
the thermal protector on the heat sink which will stop motor functions
and an “F/10” will be displayed.
1. Check for proper installation, verify the unit is not located
near a source of heat and has proper ventilation.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the MCU, the motor,
and Central Control Unit (CCU).
4. Check the drive system for any worn or failed components.
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Feb 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet f13 error code
hi there
i read your report heres the site for your codes
Whirlpool Duet Washer Error Codes Topic: Whirlpool Duet Washer Error Codes (Read 5660 times) ... Whirlpool Duet Washer Error Codes " on: September 13, 2008, 10:38:25 PM " Logged. John Pahl ... appliancejunk.com/forums/index.php?topic=1785.0 - 81k - Cached
ty for writing to fix ya
best regards Richard
Dec 01, 2009 | Whirlpool Washing Machines
What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The machine quits after a couple of minutes and displays a flashing 13 followed by F
take the kick panel off there are 3 torques 15 screw or 7 millimeter. remove them and on the left side you will find the tech sheet find out what f13 means and let me know.
Jun 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error Code
I don't have a manual on the newest dryer like you have, but one of the models just older than yours has a F23 code that indicates a shorted thermistor.( temp sensor )
Since it is new you need to call for service. They will usually look up the code and tell you if it is anything you need to check but most likely you will need a repairman to repair it in warranty.
Post back if you have any questions.
Nov 08, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
63 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
