Question about Samsung ML-2550 Laser Printer
Engine Fuser Error
Printer won't print. Engine Fuser Error appears on the display.
  • gravman Jan 20, 2008
    The exact same thing happened to me just about a week ago. I am now scouring the 'net for a solution. So far nothing and I think I've had the unit significantly longer than the warranty period. I used to like Samsung. I'm going to have to rethink that if I have to replace a 400 dollar printer. The problem is that I don't like HP any better. I'm running out of reliable computer peripheral manufacturers I can trust!
you must change your heat termostat
Posted on Sep 25, 2008
4 Suggested Answers
SOURCE: Printer won't print. Engine Fuser Error appears on
engie fuser
low heat error
Posted on May 27, 2010
  • 1110 Answers
There is a problem with the fusing unit in the machine. Most common failure is the heating element or thermal fuse. The fusing unit is the part that heats up and "fuses" the toner onto the paper. It is located right where the paper exits the machine. Pretty simple repair. You can buy the fusing unit new from for $119
Their part number is H5244
Good Luck and Thank You for using Fixya
Posted on Mar 29, 2010
SOURCE: In my printer power is on and red light will appears
I have to install this printer in xp professional o.s.
than what can i do now
Posted on Mar 22, 2009
My HP LaserJet printer 5200dtn is displaying error message "50.3 Fuser error" what is the solution to this problem because I can't print
50.3 means the fuser is getting too hot. It will either be a problem with the thermistor in the fuser or the power supply. If you can find a another fuser to test with you can answer the question pretty quickly.
Mar 02, 2015 | HP LaserJet 5200dtn Printer
Hp t1100 error 50.2
  1. Remove the printer from any UPS supplies, additional power supplies, or power strips.
  2. Plug the printer into a wall outlet to check whether this resolves the problem.
  3. If the printer is already plugged in, try another power source in the building independent of the one being used.
  4. The line voltage and current source at the printer location might need to be inspected to make sure that it meets the printer's electrical specifications.
  5. Turn the printer off then on.WARNING: Be careful when removing or reseating the fuser. Temperatures can reach 400+ degrees Fahrenheit.
  6. If the message persists, turn the printer off for 30 minutes to allow it to cool, then reseat the fuser after checking the internal wiring connections on the right and left side, ensuring that these connections are properly seated.
  7. If the 50.1 or 50.2 error recurs after power-cycling the printer or when trying to print, try installing a known good fuser from another HP LaserJet 4100 series printer, if available.
  8. If the fuser is near or at the end of its estimated life expectancy (approximately 200,000 pages), then replace the fuser. After replacing the fuser, print a Configuration page, a Menu map (shows fuser settings), an Event log, a Supplies status page, and a Usage page, to reference the status of the new fuser and to ensure that the previous fuser settings are in place with the replacement fuser. To print an Information page on the HP LaserJet 4100, perform the following steps
    1. Press the MENU rocker key until INFORMATION MENU appears on the printer display.
    2. Press the ITEM rocker key until PRINT CONFIGURATION (or until PRINT MENU MAP, etc, appears in the printer display.
    3. Press the SELECT button to print the selected information page.
    To print an information page on the HP LaserJet 4100MFP, perform the following steps
    1. Press the MENU button.
    2. Press the DOWN Navigation button until INFORMATION is highlighted.
    3. Press the RIGHT Navigation button.
    4. Press the DOWN Navigation button to highlight PRINT CONFIGURATION (or PRINT MENU MAP, etc, appears in the printer display.
    5. Press the SELECT button, the button with the checkmark on it to print the selected Information page.
  9. If 50.x errors persist after properly installing a known good fuser, or if the errors follow the questionable fuser (provided it is not near the end of its estimated life expectancy), contact HP for further assistance.
Removing and replacing the fuser
Mar 23, 2013 | HP Designjet T1100 Photo Printer
When I turn the Printer on, it will initialize and then display an error message "50.7 fuser error" and will not get to 'ready mode' for printing
1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Fuser Ref:
May 05, 2011 | Computers & Internet
Replace fuser E error
Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
Apr 05, 2010 | OKI B6200 Laser Printer
HP2605 shows 50.7 erro
Sounds like a faulty sensor. Buy a can of compressed air blow it throughout the printer. Sometimes toner dust sits on the sensors giving a false reading. If after this you still get an error you're going to need a printer engineer!
Dec 15, 2009 | HP Laserjet 2605 Printer
Hp error 59.4 - will not print - have change carterages -
This 59.4 error is a fuser error. Which means it could either be the fuser is faulty, or the fuser motor. I would suggest calling HP support if your printer is under warranty, they should send you a replacement fuser.
Aug 29, 2009 | HP LaserJet 2840 All-In-One Printer
Xerox phaser 6265 displays engine service 8300
From the service manual:
Code 83: Engine NVRAM is corrupted or receiving wrong data from a CRUM.
1 Cycle power to the printer. Does the error still appear? If so, go to step 2.
2 Remove and reinstall the Imaging Unit and Fuser Assembly. Does the error recur
after the power has been turned off and then on? If so, go to step 3.
3 Replace the imaging unit. Does the error still occur? If so, go to step 4.
4 Replace the fuser assembly. Does the error still occur? If so, to to step 5
5 Replace the EEPROM board. Does the error still occur? If so, replace the Engine Control Board.
Jun 23, 2009 | Xerox Phaser 6250 Laser Printer
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
Samsung ML-2550 Laser Printer Logo
1,265 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
