Question about HP Computers & Internet
D33007 vc37 intel p4 cpu 478 need manul
D33007 vc37 intel p4 cpu 478 need manul for motherboard
3 Suggested Answers
  • 624 Answers
SOURCE: Are all P4 478pin cpu's compatible with the P4mm2 motherboard?
Just in case your pins are only bent you can straighten them out as long as you are careful. Take a mechanical pencil without lead (.5 works ok but .7 may be easier to use) and ground it by touching it to your power supply. Then work the CPU pin slowly into the pencil and slowly bend the pin up. If you?re patient and careful you can usually straighten out any pins that have been bent. You didn?t stat which version motherboard you had. On the P4VMM2 (V1.3) motherboard the manual states that the motherboard will automatically determine the CPU clock and system buss frequency and makes the appropriate changes. The manuals only references a front-side buss limitation of 400 MHz, however, a FAQ from the manufactures support site says the V1.x motherboard?s CPU is limited as follows: - Pentium 4 400Mhz FSB (256K/512K L2 cache) CPU ? 2.6GHz - Celeron 400Mhz FSB (128K L2 cache) CPU ? 2.6GHz I would stick with the FAQ recommendations if you have to purchase a new processor, that or contact the support line to verify. Make sure you point out the FAQ on their site since they will probably just refer you to the manuals specs. P4VMM@v1.x CPU FAQ: http://www.ecs.com.tw/ECSWebSite/Support/FAQ_Answer.aspx?FAQID=3010023&MenuID=65&LanID=9 Let us know if you have any other questions and please don?t forget to rate the posting.
Posted on Jan 14, 2007
mewms_14904
  • 1027 Answers
SOURCE: CPU Upgrade for Compaq (283983-001) Motherboard
download and run everesthome
click on the + by motherboard
click on cpu then click on motherboard
the cpu will id the the processor
motherboard will id the FSB speed.
CPU-Z
click on the download latest version, left column
when you unzip and run this it will tell you if the processor is 478 or 479 pin both have 478 pins but location is different.
Posted on Mar 30, 2008
CPU upgrade for Compaq SR1220NX Desktop Computer
Hi
The specs for this machine state that it is a motherboard with
"Socket 478 for Intel P4 Williamette and Northwood processors
Supports Intel Pentium 4 processor up to 2.8 GHz
Supports Intel Celeron processor up to 3.06 GHz (Prescott based Celeron with 533MHz FSB)"
In other words, any CPU that is not socket 478 ( a fairly old socket now) will not even fit on the board. You do not mention your current CPU so you need to compare it with the spec above to see if you can improve it. It is an old machine/motherboard, so your money might be better going towards a motherboard or system box upgrade.
Cheers
Oct 14, 2014 | Computers & Internet
I have this moterboard 845gvm-v ms-7057 ver : 1.0 i would like to know wat cpu i can upgrade to my pc speed is 2.40 ghz and i have a socket 478
Supports Socket 478 for Intel P4 Northwood/Celeron/Prescott/Prescott Celeron processor
?Supports up to 3.06GHz and P4 Prescott up to 2.8GHz.
Oct 24, 2010 | MSI 845GVM-V (MS-7057-010) Motherboard
Intel Chip peplacement
according to the manufacturer:
Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~3.06GHz or faster Processor
Support Intel(R) Hyper-Threading Technology CPU
400/533MHz system interface speed
any socket 478 processor with a 400 or 533 bus speed should work.
Jul 23, 2009 | Matsonic MS9158EP (DSMTSMS9158EP)...
Motherboard ID Motherboard Name Compaq Evo
as long as it is a socket 478 processor which narrows it down to P4 or celeron ( P4 being better and faster ) it should be fine.
Obviously it will state what processors it can handle in the computer manual so if you find the manual it should state in there.
I dont think it will handle more then a 3ghz P4
Apr 18, 2009 | HP Compaq dc7100 PC Desktop
Looking for manual and upgrade options
you can type in D33007 VC37-L in a google search engine or you can go to "Manual.Pronot.com" and look for the manual for that mobo
Apr 15, 2009 | Computers & Internet
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
Motherboard and CPU
Well anything along the 2ghz line in cpu will do and as long as you get a compitibale motherboard that will be fine. If you want a specific combination the intel BX80557E2220 processor (Core 2 Duo) ans the MSI P31 Neo-F LGA775 Intel P31 1333 FSB DDR2 ATX i personally think is great. Please bear in mind you may also need new RAM for this combi.
Jun 21, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
P4 ugrade required
Sadly you wont find any 1066Mhz FSB processors for the Socket 478. The best you can find is the 3.4Ghz with 800Mhz FSB. It might be cheaper and also better value for you to get a Socket 775 based motherboard and Core2 Duo processor. The value range E2160/2180 processors or the E4300/4400 processors have been tested to be even faster than the Socket 775 Pentium Dual 3.4Ghz and they also use less power.
An article on socket 478 for you http://www.xbitlabs.com/news/cpu/display/20040123103754.html
Dec 02, 2007 | Intel P4 Socket-478 Original CPU Cooling...
Motherboard needs cpu
server mother boards are very fast and performance is really good. there is no problem using it as a home pc. you can use 478 socket processor
Oct 02, 2007 | Intel Motherboard
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Computers & Internet Logo
1,549 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
