Question about Canon PIXMA iP2000 InkJet Printer
Error 6b10 - Canon PIXMA iP2000 InkJet Printer
    President:
  • Canon Master
  • 2,022 Answers
This error massage come due to paper feed sensor error i suggest you to show it service center .
Posted on Nov 16, 2009
I receive an Error Code 6901 on my MX725 printer, what can I do?
It usually means that it needs to be cleaned.
Take out the cartridges and look to see if there is build up.
That normally causes the error.
Apr 17, 2015 | Canon PIXMA Office Equipment & Supplies
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
6b10 error, meaning?
Hi this is what i found for your problem hope it helps thanks. Paper feed cam sensor error or Error Code 6B10
Condition: An error occurred in the paper feed cam sensor during paper feeding from the cassette, or the paper absorbing a large amount of ink jammed in the PF rear guide.
Problems and Solutions:
  • Jammed paper in the PF rear guide (when a large amount of ink was absorbed in the paper);
    - remove the jammed paper and foreign material.
  • check for foreign material or paper debris in the cassette or in the PF rear guide;
    - remove foreign material.
  • If other solution fail, replace one off the following part
    - PF pick-up unit
    - Logic board
Sep 21, 2011 | Canon PIXMA iP2000 InkJet Printer
Error 6b10
Hi there!
Here's what you can do:
1. Press ON/OFF switch to reset the multifunction device 2. Press Stop/Reset and ON/OFF to reset the printer 3. Try to check for jammed paper. click this link and under service & support type paper jam http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport 4. The MP600 may require repair
If you will still receive the message you can check this link for your model or contact the customer service http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Hope this helps!
Mar 29, 2011 | Canon PIXMA MP600 all-In-One InkJet...
ERROR CODE 6B10 OR 6810
I went to www.canon.com/support and selected your printer. I then searched for your error code and did not find the specific code. I only found the following:
Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1. Press ON/OFF switch to reset the multifunction device 2. Press Stop/Reset and ON/OFF to reset the printer 3. Removing paper jams MP500 / MP800 / MP950 4. The MP500 may require repair
You can click the "contact us" link and call them to get direct support from them. If you bought your printer recently, they will most likely give you free support over the phone.
Nov 21, 2009 | Canon Pixma MP500 All-In-One InkJet...
I see a 6B10 error code what is that?
If there is no paper jam, then your unit needs servicing. Go to www.usa.canon.com (in the U.S.) and they will advise.
Jun 28, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon MP830 fault code 6B10
Try to change paper size in the offending tray.
Jun 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have Canon Pixma IP4500, got a Service Error 6B10, How can I fix it without sending it to Canon Centre? because I also got inktank system installed.
If you have disassembled the printer and after putting it back together again, this error pops up, things migt not be as bad as they seem.
Turn the printer on its side and remove the bottom paper tray. You'll see the gap where the tray normally slides into. On both sides you'll see a spring loaded lever. Check that the springs are fitted properly and the levers move smoothly. The small lever is the one that takes care of the paper detection, but if the big one does not move properly, you'll end up with the error too. In my case, the spring got twisted underneath the big lever and that gave rise to the 6b10 error. HTH.
Hans
Oct 15, 2008 | Canon Office Equipment & Supplies
6B10 problem
If you still need the user guide, you may find it here: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=12804
I'm afraid that here is already a mechanical problem on your printer if displays 6B10. It's a paper feed sensor error on your printer that means you need to have it serviced with an authorized canon technician.
Hope this helps.
Thanks.
Jul 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA iP2000 InkJet Printer Logo
216 people viewed this question
old marine
old marine
