Question about AOpen AK77-8X Max (91.8A710.101) Motherboard
Same thing Now when i boot, the system shuts off and theres this alarm that goes off. I'm completely lost.
No display in 810 mother board
Posted on Feb 20, 2008
  • 1,067 Answers
Bad power suplly alot dust in it blow it out screw mobo screws tight down reseat everthing inside chesak power plugs is it well vented
Posted on Jan 10, 2008
Cobra troubleshooting
We do not have info on aftermarket systems. Suggest you remove it completely and install a quality system.
Dec 31, 2013 | Cars & Trucks
How do i disengage the alarm system in a 2002 dodge stratus?
lock all doors then use key in front passenger door to unlock. that disables the alarm
Jan 17, 2018 | 2002 Dodge Stratus
I unlock jeep commander door manually, and my car alarm goes off
mine does the same thing and all you need to do is jump in and start it for it to stop but you go in and staryt meesing with things ist gonna mess up something
Jul 27, 2012 | 2006 Jeep Commander
I need to completly disable a factory alarn in a 1988 cadilac coup deville as i lost my alarm beeper and the alarm goes off every time i open my door and i have to piull the battery terminal to make i
The alarm system is integrated into the vehicle electronics, you can't completely bypass it. You don't need a remote to have it work right and not go off, you have a problem with the system like a door sensor.
Jun 29, 2012 | Cars & Trucks
When the car is started alarm goes off and car shuts off. do not have keyless pad to shut off alarm
  • if it is a factory system the following should reset it.
    • Turn the ignition switch
    • Insert the key into the driver's side
    • Turn the key clockwise to lock
    • Turn the key counterclockwise to unlock it.
      The alarm system recognizes an authorized key was used and the system
  • you may have to do this each time you unlock the car.
    if it is an aftermarket system you will either have to identify the system and serial number and try to contact the manufacturer for a replacement fob, or have the system removed completely.
    Feb 23, 2011 | 1998 Jeep Cherokee
    Grandson locked his 97 dakota with elecronic pod. lost the pod cant get alarm system off. truck starts and dies, figure security is shutting off fuel. heard there is a system to shut the system off using...
    alarm systems have a starter kill that will not let vehicle start, not any type of fuel cut off. I have worked with several alarm none have fuel cut off
    Jan 28, 2010 | Vehicle Parts & Accessories
    Just replaced the battery and it tripped the alarm. finally got it shut off and now it just clicks when I try to start it.
    If the vehicle has a 'Factory' alarm system, try cycling the jkey in the ignition ON-OFF (not to start), 5 times. This will defeat the factory alarm. This method is used in case the remote trasmitter battery goes dead, or the transmitter is lost.
    This only works on Toyota Factory security systems, however.
    Oct 09, 2009 | 1998 Toyota 4Runner
    2002 Isuzu Troper Alarm Going off for no reason
    pull the fuse and there is a sensor adjustment for those but you need to have it checked by a car audio and alarm guy
    Aug 24, 2009 | 1999 Isuzu Trooper
    Shut off hourly alarm on g-shock
    Okay I have this module so here goes.
    Start from your regular timekeeping mode (use lower left buttin to cycle through until you get to the normal time display).
    Press 'mode' button (lower left) once. You are now in alarm mode.
    Press lower right button to cycle through the alarm modes. The cycle goes: hourly beep on, timed alarm on, both on, neither on. You will see the corresponding icons (a ripple icon for hourly beep and and a bell icon for the alarm) appearing/disappearing in the top left of your display as you cycle through. So if you are in hourly beep mode now you probably need to press that lower right button 3 times to get to 'neither' alarm being on.
    Press lower left button to return to normal display.
    Hopefully - enjoy the peace!
    Jul 05, 2008 | Casio G-Shock G2600 watch
    AOpen AK77-8X Max (91.8A710.101) Motherboard Logo
    5,669 people viewed this question
    Top AOpen Computers & Internet Experts
    Michael Galve
    Michael Galve
    Alun Cox
    Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
