Question about Konica Minolta Office Equipment & Supplies
Hi, when I power-up the machine, the power save light just turns on but no lcd or warmimg up happening. I try resetting, same thing happens.
    Problem Solver:
  • 6 Answers
Need to know model of machine? it could be something simply like a setting or you may need a board
Posted on Nov 16, 2009
My Singer Quantum 9960 machine was accidentally plugged into a 220volt supply as I am currently in a country that uses 220volt. The LCD screen lights up for less than one sec and then went off. I...
this happen to me exactly - i checked and the fuse is blown, which is a good thing because it will hopefully have saved the rest of the machine from being toasted. I will find out soon once i get a new fuse.
Apr 22, 2011 | Singer Sewing Machines
I SEE the green light when I turn on the camera but LCD screen of Sony DSC-F505V is dark black, nothing happens-total silence and cannot take any pictures. Did I loose my camera? Solution?
Based on the information provided it seems that the issue may be with the LCD Screen. You can check if the Camera is working by capturing images and inserting the Memory Stick in the Computer Memory Card slot. If the image capturing is normal then the images can be saved to the Computer. If the images are not getting captured, then the issue may be with the Camera. We can try power resetting the Camera to resolve the issue.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
If the issue persists after resetting, then service may be required to identify the exact cause.
Thanks for using FixYa.
Jan 19, 2011 | Sony Cyber-Shot DSC-F505V Digital Camera
All the lights are blinking when the door is shut but won't allow me to turn on. I have checked the power switch & reset my circuit breaker. Last time this happened (about a tear ago) Maytag instructed...
i have model number mdbd850awb and this exact same thing happened to me on the weekend. i fixed the problem by total chance! I depressed the "off" button for a few seconds and it reset the control panel, now it's working great... i hope this works for you and saves you some time and money!
Aug 26, 2010 | Maytag 24 in. MDB5600A Jetclean II...
My Tv, Olevia LCD HD TV 242 FHD T11, will not turn on
Same thing Just happened to me ths AM. Acting Wierd then this morning fuzzy screen and poof won't come back on.
Comcast box was resetting at the exact same time and I found this online....
http://www.my3cents.com/showReview.cgi?id=18330&s=1188
Mar 06, 2010 | Televison & Video
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Red light blinks but nothing happens
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 02, 2009 | Olympus FE-310 Digital Camera
Monitor power light blinks blue but does not power on
if the screen was fryed the fuse would of blew which means there would be no lights at all.. the best thing you can do is plug your screen into another pc to see if anything happens.. if nothing happens then yeah your screen must of messed up somewhere.. but if your screen works on another computer then your graphics card config cant be right somewhere along the line
Jun 10, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
LG 42 LCD no sound or picture
This is probably bad capacitors on the power supply board. My LG 42LB1DR has a known problem with this and I replaced the four bac capacitors myself and saved 5-6 hundered dollars that I was also told that it would cost to fix. I fixed for under 10 dollars and about 20 minutes. LG knows about it but they dont really want to admit it. My TV was only 26 months old when this happened. The four capacitors are made by Samxon and are 2200uf @ 10v. They are junk so even if you have the entire board replaced for say $200 its just going to happen again. They need to be replaced with a different brand.
Jan 28, 2009 | LG 42LC2D 42 in. LCD HDTV
My Mitsu WD-62628 will not turn on
It is probably by coinsidence that the set has failed. I doubt it was from the house cleaner. The set most likely failed on its own. The power supply is a common fault in most LCD screens when they fail. Sometimes a failure can occure on any of the other boards, and thus cause a fault in the power supply.
Jerry G.
Apr 16, 2008 | Televison & Video
My lcd display turns off randomly
check power saving settings under control panel
Dec 01, 2007 | Acer Aspire 9300 Notebook
20 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
