Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Bosch classix washer dryer has just flooded water through its door and drawer whilst on a cycle. Any suggestions?
    Scholar:
  • 62 Answers
Several possibilities.
  1. Was water poring out of the drawer when the appliance was in spin?if so then possible cause is that the appliance hasnt draqined its water first. It is trying to spin with water in drum and it has to go somewhere.
  2. Is the appliance overfilling? Water level should just come to the bottom of the door but if you see it rising up to the top of the door then you have a problem with the water level sensor (or a blockage)
From experience with the type of fault you have i would say that its not draining all the water before spin. If you have a pump out function then do this a few times until ALL the water has drained. put a large towel in front of bthe filter and unscrew filter cover and check for a blockage.
If you cant find anything then you may need to call a engineer
Hope this helps
Aardvark Repairs
Posted on Nov 16, 2009
Testimonial: "Helpful advice given in a structured way. Many thanks"
My bosch classix dryer is saying container is full but its not and machine keeps turning off. Any suggestions?
Owner's manual no manual? Try MFG website or email their customer service, or try
manualslib.com
What does container mean? Water condensate bucket? or similar?
Apr 12, 2015 | Bosch Washing Machines
Bosch classix water won't drain
check for blockages in the outlet pipes, filter and pump.
Dec 30, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
Bosch Classix SGS43C12 dishwasher programs not working & dispenser drawer not opening
The control board on this model is know to have issues with dry solder joints, If you are handy with a soldering iron you can fix it quite easily.
Mar 04, 2012 | Bosch 24 in. SGS43C12 Classixx...
The wash cycle starts with a 5 second delivery of water then stop
SOUNDS LIKE YOURE INLET VALVE HAS FAILED IF YOURE MACHINE IS COLD FILL ONLY IT WILL ONLY WORK ON ONE PART OF THE CYCLE ALTHOUGH IT HAS ONLY COLD FILL THERE ARE 2 VALVES SHARING SAME BODY,WILL NEED CHANGING
Aug 11, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Major leak after 20mins into wash cycle!
Have a good look at door seal., and see if you can see any hole or tear in rubber.If o/k, then remove rear panel, and watch whilst it is running, and see if you can see any sign of water coming from anywhere.
Make sure the water is not running down the front from the dispenser, which would suggest a blockage in the dispenser drawer.
These are the steps I would take first.
Also make sure the waste outlet is clear
Plz leave rating and any comment you may have.
Thanks..
Jan 21, 2009 | Hotpoint Aquarius WD640 Front Load...
A mold smell from my washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Dec 28, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Only adds water and drains
well. check for limescale in the back. if there isnt any there then call a mechanic ^_^
Jun 25, 2008 | Bosch Classixx WVF 2402 Front Load...
Bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
May 28, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
172 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
