Question about Acer TravelMate 340T Notebook
MY ACCER 320T KEY BOARD IS NOT WORKING IN WINDOWS, WHEREAS THE K/BOARD IS FINELY WORKING IN HARDWARE SETUP MODE. CAN U PLS TELL ME THE SOLUTION.
2 Suggested Answers
CreativeTECH
  • 1719 Answers
SOURCE: hello sir i need your
Hi Zulfi,
The standard keyboard language and widely used setting is "ENGLISH (US)"
Set the Keyboard layout to English US so that you have standard keys for symbols etc. like @ sign with SHIFT+2 etc.
The keyboard layout / Language of your PC may have been changed, so follow these steps to select the International keyboard layout:
- Go to Control Panel - Region and Language settings
- On the Keyboards and Language tab, click Change keyboards.
- Click Add.
- Expand the language that you want. For example, English (United States).
- Expand Keyboard list, select the United States-International check box, and then click OK.
- In the Default input language list, click Language name - United States-International (where Language name is the language that you selected in step 4), and then click OK two times.
- In the Regional and Language Options dialog box, click OK.
Hope it helps! Good Luck!
CreativeTECH
Posted on Apr 07, 2011
My hp desktop computer was working well but after a lightning, it is able to boot with no usb port responding and it does not have a ps2 mouse or keyboard connector. What should i do?
pls clear cmos jumper first. after power on and go to bios by press the key board key. if worked, pls check the O/S setup or recovery setup . pls select select system restore and press restore previous date.
if not working usb key board and install PCI or PCI X usb adapter and plug to key board and mouse to it and go to bios and disable on board usb controller.
go to O/S and check
Jan 04, 2017 | HP Computers & Internet
Doesn't enable virtualization
To determine whether your PC supports hardware virtualization:
Step 1. Does my PC have a CPU with support for hardware virtualization?
Download and run the Hardware-Assisted Virtualization Detection Tool
If you receive the message This computer does not have hardware-assisted virtualization, your computer does not meet the hardware requirement for Windows Virtual PC, but you can still use Windows 7 XP Mode by running this hotfix. Be aware that XP Mode will run much better if hardware-assisted virtualization can be enabled.
If you receive the message Hardware-assisted virtualization is not enabled on this computer, go on to Step 2 below.
If you receive the message This computer is configured with hardware-assisted virtualization, download and install Windows Virtual PC and Windows XP Mode.
Step 2. Does my PC BIOS support hardware virtualization, and is it turned on?
Instructions to turn on hardware virtualization in your PC BIOS are specific to OEM models. It is important that after changing your BIOS settings the PC is completely shut down at the power switch before restarting so that the new BIOS settings can take place.
Examples for some models of some computer manufacturer's BIOS settings are below:
Sample instructions for your PC
Expand all
Dell systems
Depress the F12 key when boot menu text appears at startup
Select BIOS setup and depress the Enter key
Using the mouse, expand the Virtualization Support menu item by clicking on the plus to the left of Virtualization Support and select Virtualization
Check the Enable Intel Virtualization Technology checkbox
Click Apply
Click Exit
Fully shut down (power off), wait a few seconds, and restart your computer
HP systems
Depress Esc key when prompted at startup
Depress the F10 key to Configure BIOS
Scroll to System Configuration using the arrow keys
Select Virtualization Technology and depress the Enter key
Select Enabled and depress the Enter key
Depress the F10 key to save and exit
Select Yes and depress the Enter key
Lenovo ThinkPad systems
Depress the blue ThinkVantage key when prompted at startup
Depress the F1 key to enter the BIOS setup utility
Using the arrow keys, scroll to Config and depress the Enter key
Scroll to CPU and depress the Enter key
Scroll to Intel Virtualization Technology and depress the Enter key
Depress Enter key to continue
Depress F10 key to save and exit
Acer
PCs capable of supporting Windows XP Mode have already been enabled and do not require additional configuration.
Asus
Samsung
Panasonic
Depress the F2 key when boot menu text appears at startup
Select Advanced menu in Setup Utility
Change "Intel Virtualization Technology" setting from Disable to Enable
Depress F10 to exit Setup Utility
Select Yes in confirmation menu
Depress Enter to exit confirmation menu.
Please note the instructions above may not work in all cases and consulting with your computer manufacturer may be necessary. Additionally, we expect hardware virtualization to become more available when Windows 7 is shipped, particularly in business-class PCs. For those PCs that come pre-installed with Windows XP Mode we recommend the computer manufacturer turn on hardware virtualization before shipping the PC.
Once you have confirmed your PC supports hardware virtualization
Download and install Windows Virtual PC and Windows XP Mode
hope this helps
Aug 08, 2012 | Computers & Internet
My accer 5740 comes up with status error oxc00000e9 what does this mean
Researching microsoft resources, this looks like it is either a registry error or possibly a system BIOS error.
Please tell me what happened just prior to you receiving this error? How old is the laptop? Have you made any changes to the laptop recently, either software or hardware?
If you have a recovery partition, you can do a non-desctructive recovery to see if you can restore your windows installation to a normal state. If you have a restore disk, you can do the same thing, you will restore the computer to factory settings. However, you may loose your documents and files if you are not careful.
You can also try to start the computer and hit the F8 key, which should bring you a menu. See if you can start in safe mode. If so, try and use system restore and find a restore point on a date before you started having this problem.
You can also look for the correct key to go into the setup before the computer tries to start windows. The key is often the F2 key or the delete key. Your screen may tell you after you see the acer splash screen. If you get into the BIOS setup, you can look for the key or selection to reset your BIOS.
I have included a link to the ACER support page for your laptop. The tab you will come up on is a bios download. But there are driver downloads, applications downloads, patch downloads and user manuals.
Please respond after you have tried my suggestions.
Brian
http://support.acer.com/us/en/product_support.aspx?tab=1
Jan 08, 2011 | Acer Aspire 5050-3371 Notebook
In nova net pc with intel D945GCLF Mother board , it does not boot the system with windows, and want to flash the bios , its not supporting with usb boot, cd,dvd booting ? , then how we install windows in...
while booting up it must be giving you an option to enter the cmos setup with hitting either f8 key or del key or f10 key. Just hit the key at the appropriate time and enter the advance setup in the cmos setup and go to boot devices and select the priority you wish. In some cases the hard drive and cd rom have jumper settings for putting them in master and slave mode. just read on the drive label and set your cd rom to master and your hdd to slave and you will be able to boot through cd and instal windows.
Dec 26, 2010 | Intel Computers & Internet
New system gets hangs, keyboard also but mouse works fine... Could you pls tell me the solution.. wat went worng
Please check the key board P/S 2 pin, open it and connect correctly.or tell what type of msg will apper in your screen.
Sep 02, 2010 | Microsoft Windows XP Professional for PC
How to put dsl-320T in full bridge mode?
You could install Router Techs firmware on your modem www.routertech.org and it would give you the option to put the modem in full bridge mode. However I'm not sure the hardware on the modem fully supports it. You might have to use half bridge mode and let your router do the DHCP.
May 18, 2008 | D-Link Computers & Internet
Problem with keys used to enter the cmos
For Toshiba notebook PCs manufactured since the introduction of Windows XP, one or more of the following methods will be effective:
  • Toshiba Hardware utility method: Run the Toshiba Hardware utility from the Toshiba Console. It may also accessible (as 'HWSetup') from the Windows Control Panel. Changes to some of the settings will require re-starting the computer. This method is the only way to access the BIOS settings on some notebook PCs (Satellite 5000 series, for example). (For these machines, pressing and holding the F12 key immediately after powering-on the notebook will allow you to alter the notebook's boot priority.)
    If the Toshiba Hardware utility is not present, try the F2 key method and the Esc key method (see below).
  • F2 key method: Turn the computer on. If you see an invitation to press the F2 key to enter Setup, do so. The Setup screen will appear.
  • Esc key method: Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
For more information search on toshiba web.
Thanks
iqbal
Mar 17, 2008 | Toshiba Satellite 5005-S504 Notebook
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
Problem acer 5052
While your using the windows environment try alt and enter keys similtaeouly should give you the ol dos style.
Sep 29, 2007 | Acer Aspire 5050-3242 Notebook
Acer TravelMate 340T Notebook Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
