Question about Whirlpool 24 in. ADG6340 Built-in Dishwasher
Whirlpool ADG 6340 Dishwasher
I noticed the flashing on the front of the dishwasher when I went to empty the last wash. Now when I try to run a wash it will not work. I have checked the filters and sprays to make sure nothing is blocked. The machine is only 2 years old.
  • Anonymous Jan 30, 2008
    My Whirlpool ADG6340 is flashing 7 times - any idea what this
    fault code is
  • fishywishy May 10, 2008
    My adg 6340 light flashes 7 times and won't run, any solution to this? Have tried pressing and holding button for a while but makes no difference, also tried powering down for a few minutes. Thanks
Fault 7 is a fill fault . If you take the left side panel off you will see a white plastic tank . The sensor in the tank has failed
Posted on Jun 23, 2008
    Scholar:
  • 196 Answers
What flashing are you referring to ? This could very well be a fault code.
Posted on Jan 10, 2008
Looking for answer to error code F5 on Whirlpool Dishwasher ADG 8200
Fault Code F5 or Five Flashes
Cause: Spray arms are blocked/clogged or otherwise malfunctioning.
Action: Spray arms are easily removed so take them out of the dishwasher and wash in the sink to clear out any gunk (using descaler should help shift any stubborn debris). Whilst doing this run the dishwasher on a short program without the spray arms to clear any further blockages.
Jul 14, 2016 | Whirlpool ADG8200 Dishwasher
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
I have a Whirlpool Dishwasher model no. ADG 6340 IX.The inlet valve is pulsing and letting in water on every pulse. It just keeps filling, over fills and trips elcb
Hello there and thank you for choosing fixya
This is a very common problem with these types of machines the water inlet valve has a solinoid for the hot and a solinoid for the cold that opens and closes the water on demand .
When they start to pulsate like this it is trying to close the valve but it cant this is normally due to the valve being clogged with debris or the valve is failing all together and simply needs to be replaced
So what i would do is first if you can look into the inlet valve with a flashlight and see ifit looks like it has stuff in it and if so clean it out and try it again if this doesnt work than you can assum that the valve will need to be replaced here is what the one of the valves should look like or close to it .
$50.60 Quantity:
In Stock
Jun 05, 2011 | Whirlpool 24 in. ADG6340iX Built-in...
Whirlpool dishwasher stuck on prewash cycle
the eprom memory is brocken,the main board must be changed.
Feb 14, 2010 | Whirlpool 24 in. ADG7952 Built-in...
Whirlpool ADG 957 Dishwasher not draining water?
There is a remote possibility that the drain line is clogged. Most units should have an aerator on the top of the sink area HOWEVER some are hooked up directly into the garbage disposal and it's at that point where the line can be clogged. Remove the clamp and make sure the line is clear or the hole in the disposal is clear.
Nov 09, 2017 | Dishwashers
Front light flashing
Solution to the problem:
Discovered that the dishwasher was covered by our household insurance policy. Phoned and arranged for it to be repaired or replaced (no charge). Engineer coming on Friday.
Jun 10, 2009 | Whirlpool 24 in. ADG6340 Built-in...
Dishwasher adg 6340
is this a digital washer? If not turn the knob manualy while the bar is switched to on and see if you can get it running
Mar 30, 2008 | Whirlpool 24 in. ADG6340 Built-in...
Whirlpool 24 in. ADG6340 Built-in Dishwasher Logo
2,075 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
