Sony PlayStation 2 (PS2) Console Logo
Posted on Nov 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flashing red and green light
Light on the front of the Playstation 3 blinks red and green, it indicates that the system is beginning to overheat.
Anonymous
Level 2:
Champion:
  • Expert 273 Answers
  • Posted on Nov 18, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
273
Questions
Helped
57510
Points
425
Dude, don't send it sony!
read the manual, it said:
- it's over heating, so give it plenty of room to breath and make sure no vents are blocked.
- don't use the system when it behaves this way.
- completely shut off the console and let it cool down, then you can use it again.
  • Anonymous Nov 18, 2009
    i meant: don't send it to sony!
Anonymous
Level 3:
President:
  • Master 2,777 Answers
  • Posted on Nov 16, 2009
Anonymous
Master
Level 3:
President:
Answers
2777
Questions
0
Helped
666084
Points
9584
You are going to need to call Sony for repairs to this unit. Their number is:
Flashing red and green light - globe.gif 1-800-345-7669
Ps2 just blink red does not turn on
  • If the power light on the front of the system is flashing red, or alternately flashing red or green, this may indicate the PlayStation 2 system may need service. Contact Consumer Services below.
https://support.us.playstation.com/app/answers/detail/a_id/120
When i turn my playstation on, after 5-10 seconds it shuts off by itself and the red light keeps flashing, what do i do?
If ur ps3 console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
The PS3 red light problem occurs when your system refuses to boot up and has a small flashing red light on the power button. In most cases, the power button will turn from red to yellow and then back to a blinking red and the system will not boot up from there as it is supposed to.
There can be a variety of issues that cause the Playstation 3 red light problem, but in most cases it comes down to the system overheating. The more it overheats the more damage is created internally to the motherboard
and other functioning components. This can be caused simply by a flaw in the system or by obstructions to the fan vent such as a wall, floor, or excessive collection of dust...
click here to download repair guide
1helpful
Ps3 will not switch on. The green light turns orange than red
This is known as the yellow light of death (ironic i know because it blinks red). This is caused when the unit overheats causing the solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
Will not power up starts and then stops flashing
This is known as the yellow light of death for the ps3(ironic i know because it blinks red). This is caused when the unit overheats causing solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty with this site: https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_c921F5935-E460-55B7-A328-5BEA7D5C49AE_kDAFA2718-297A-1EA2-6192-44C4B1E6348C
1helpful
2answers
Ps2 shuts and starts blinking red light
To confirm: red light blinking does mean that the console is overheating, which I know from experience.
Solution: Do not leave on carpet or any materials similar as they insulate. If possible, leave the console vertical instead of horizontal and this will help cool the system. Better yet, if you can still find one, a USB fan that plugs onto the front of your grill.
Hope this helps.
Read more: http://www.ps3news.com/forums/pc-tech-support-news/ps2-overheats-shuts-itself-off-37172.html#ixzz0OqeZo6Sy
1helpful
PS3 will not boot up, red light is on, will go to green for awhile then drops back to red
Excerpt from the PlayStation 3 Manual:
The power indicator on the system front is flashing red and green alternately.
*The interior of the system has become hot. Check whether the system is being used in a hot location or whether the vents are blocked. Continuing to use the system in the above condition will cause it to stop functioning. Turn the system off and leave it unused until it cools down. After the system cools down, turn it on again.
The power indicator on the system front is flashing red and the system does not operate.
*The temperature inside the system has risen too high. Check whether the system is being used in a hot location or whether the vents are blocked. Touch the power button on the system front to stop the flashing, and then leave the system unused until it cools down. After it cools down, turn on the system again.
If this does not resolve your issue, you may need to send it in for a repair.
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
3answers
PS3 Quit
Alot of the playstation 3 systems are having problems overheating. this would be the cause of the system shutting off. not to much u can do unless u know how to replace the fan or if you bought the warranty. other then that you would have to take it to get fixed or buy a new one. hope this helps sorry if it dont
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
