Question about Frigidaire FGF378AC Gas Kitchen Range
FOIL I PUT SILVERFOIL ON BOTTOM SHELF AND IT IS STICKING HOW CAN I GET IT OFF
    Genius:
  • 1,554 Answers
You will have to heat it to get the sticky to release.
put a hot skillet on top of it or use a hand torch..
Posted on Feb 03, 2008
Rack to cook meat loaf
My wife takes a cookie cooling rack (with wires) that fits into a cookie sheet with sides; she then covers the cooling rack with aluminum foil and uses a fork or knife and pokes holes in the foil. She then places the meatloaf (or whatever you wish to bake or roast) on the foil covered rack and puts it in the cookie sheet. The holes allows the fat or other juices to run down to the cookie sheet and the meat loaf is not sitting the fat.
Feb 01, 2015 | Hamilton Beach 8 Quart Slow Cooker,...
I have an old upright fridge and there is no shelf in the freezer..can i put a wood shelf in it?
your are fine to put a wooded shelf in,best to cover in saran wrap or aluminum foil though
Mar 23, 2012 | Refrigerators
It appears to get to hot i put foil in bottom to
The manufacturers of most kitchen ranges recommend that you DO NOT put foil on the oven bottom. Although, you may have good intentions, it causes problems just like the one you mentioned. It can cause uneven heating, inaccurate oven temperatures, or an oven to become too hot. If this is an ELECTRIC range, it can even cause premature failure of the heating elements. In some cases, if the oven is too hot, the foil can become seriously affixed to bottom oven pan which becomes extremely difficult to remove. It is recommend that you routinely check the oven after each use, allow to cool and clean as necessary with an approved oven cleaner (yes, they even make these cleaners for self-cleaning ovens) to keep stains and spills to a minimum. If you have questions, please post back and let me know. I hope this helps you.
Jul 01, 2010 | Kitchen Ranges
Foil sticking to bottom of self cleaning oven
Have here spray the bottom with oven cleaner and let it soak for one hour then scrape off with a spatula.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Dec 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
There is a round silver disk (seemingly made out of card board) that fell off. Can it be replace with another cardboard cut out in the same shape?
the disk is just a microwave diffuser but, it is made with a special foil do not put regular foil into a microwave for any reason; just glue the disk back on with ordinary glue
May 20, 2009 | Microwave Ovens
Foil is sticking to bottom of oven
pull off as much of the foil as you can and then spray the fringes of it with some oven off oven cleaner. Use rubber gloves as this is a strong chemical. Let it sit for thirty minutes and then pull off as much more foil as possible. Repeat until the bottom of the oven is clean.
Apr 30, 2009 | LG LRE30755 Electric Kitchen Range
Yes, we were a couple of dummys when we received our brand new LG stove, with convection oven,glass top and very fancy, and we put tin foil to cover the bottom of the stove and of course yesterday when I...
I really don't know what to tell you. During the clean cycyle the metal probably melted and is permantly sealed to the bottom. You are lucky the oven still works. Sometimes using foil will destroy sensors or other things. NEVER use foil in ANY oven!!!!! The only exception is to partially cover the shelf underneath something you know is going to make a mess. Even then don't cover more than about 60% of the rack.(Never do this in a convection oven as the fan will blow the foil ) Also NEVER!!! allow foil to come in contact with a hot burner. It will melt to the smooth top or coil.
Jul 07, 2008 | LG Kitchen Ranges
Foil baked onto oven base.
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. Oven operation is not affected. The only option you have is to replace the panel or the entire oven liner...
Jun 07, 2008 | Ovens
Melted Tin Foil in bottom of oven
Use "The Works Toilet Bowl Cleaner" to dissolve the foil. *Caution* when the cleaner is applied to the foil a chemical reaction occurs releasing some harmful fumes so please use outside or in a well ventilated area. I just did this to a Frigidaire oven I bought from Lowes at a discounted price. The previous owners bought it, did not read the owners manual or just disregarded the warnings on using foil in the oven and thought they would line the bottom pan with foil to help make it easier to clean (Good idea, but don't try it on the hidden element ovens). With the heating element being hidden under the drip pan the heat is hot enough to melt the foil and fuse it to the pan. Now most of the pans on these ovens are removable by just a couple of screws and I strongly recommend removing the pan when doing this. Squirt some Works toilet bowl cleaner on it in a well ventilated area and watch it go to work. It took about 15 minutes for it to dissolve all the foil on my oven, then I rinsed it clean and reinstalled it in the oven. The pan does have a slight discoloration on it, not from the cleaner but from the foil being melted onto the pan, if you choose you can buff this out. Most of the modern ovens have the ceramic coated drip pans in them so the Works toilet bowl cleaner will not harm them, unless you have scratched the finish off. Works Toilet bowl cleaner contains a fair amount of hydrochloric acid which is what makes this work so well.
Oct 23, 2007 | Kenmore 33169 Gas Single Oven
Frigidaire FGF378AC Gas Kitchen Range Logo
35 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
