Question about Dewalt DC011 AM/FM Radio
How do you reset the radio to charge batteries
  • 60 Answers
Never heard of a way !!! have a look inside your radio at the fuses x 3 1st fuse near transformer on ciruit board, 2nd on circuit board where battery connects to radio and 3rd in the charger its self on the circuit board. This is white in colour, to replace this fuse you will need to desolder it as I have just changed mine.
Posted on Nov 28, 2009
Hi, my Ford 500 has trouble starting in the cold. When it does start the whole radio etc resets. What should I do?
Hey Kaycee,
Starting issues can be a million things. What caught my eye was the radio reset. I suggest that your battery is too low to maintain enough system voltage, during starting, causing the radio reset.
When you are low on voltage, you may not have enough to make a good spark, crank the engine, and run fueling systems.
You can test by hooking the car up with a jump from another car. Let the other car charge yours before you try your car.
If it starts well, you need to pursue why the battery is low. Battery age, charging system, grounds, wiring are all suspect.
Doc
Jan 13, 2015 | Car Audio & Video
Radio Resets when I PTT
1) You were right to change to new batteries. Yet, the problem you describe is the same problem that would present itself if you had bad or poorly charged batteries. Check your contacts where the batteries touch inside the radio for damage or film/debris. Clean with a pencil eraser.
2) Is it possibly you have changed a setting, or have your radios programmed to a repeater (duplex only) frequency? Reprogram (if possible) your radios to a very basic setting with the code set to zero (off), and all special features turned off. Then using a basic radio-to-radio frequency test the radios again
3) If reprogramming is not possible due to the radio shutting itself down, then you have a battery or charging problem. Be certain the radio is turned off when on the charger and the battery is clean and inserted the right direction. Try charging both radios overnight. Observe your charger, does it seem like it is operating properly?
Basically, problems are either the radio, the battery, or the charger. By process of elimination you should be able to determine which one is the culprit.
Best regards.
Feb 04, 2014 | Motorola Talkabout T9500XLR - two-way...
We have a 2003 yukon denali xl. we have a signal saying battery not charging. we replaced battery and alternator. still won't charge. truck goes completely dead. no lights, radio anything. what el
I'll try to help, everytime something gets replaced on these yukons, that circuit needs to be RESET ! Is there a reset button, on your steering wheel, to reset a variety of functions ? , check owners manual, or call your dealer for better advise
Feb 15, 2013 | 2007 GMC Yukon XL Denali
My mifi XM2go radio will not turn on. I have
Sounds like a bad battery. Try plugging DC adapter directly into the bottom of the unit and turn it on - does it still act-up? If so, bad radio; if it works with adapter only, then battery and charging issue.
Dec 20, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Hi ya my dewalt radio will not power on but still charges the battery
You are lucky it still charges battery. Your transformer for the radio has a fuse on the winding, this has gone or the transformer has gone.
Jul 11, 2009 | Dewalt DC011 AM/FM Radio
Radio Reset on PPT
The Battery Pack:KEBT-071-B was memory depleted. Just Try using Alkaline Batteries and test again, if the test results OK, Memory Discharge de Battery Pack Full Discharge and them complete the charge Cycle Again until the Memory Charge error disapear, or optional Buy a new Battery Pack.
Jun 12, 2009 | Motorola T8500 Two Way Radio
T8500 no recieve transmit vibrates when PPP is pressed
http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Try checking the vibra call settings for your vibrating issue. Also, as for the radios not communicating with one another you should check the programming of the frequency, interference eliminator and the Qt filter. All radios must be identical to work together.
Apr 27, 2009 | Motorola T8500 Two Way Radio
Battery Get Discharged within few Minutes even after Full Charge
I have the same problem, and for now an external charger is the best solution. Also try resetting 4 times. I also got a new power supply, but problem persist. Good luck!!!
jav
Nov 19, 2008 | Kaito KA1103 SW/FM/AM Radio
Dewalt DC011 AM/FM Radio Logo
353 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
