Question about Nokia 6300 Cellular Phone
Restriction code for nokia 6300
I have a seconf nokia 6300 and when put a sim card it said, enter restriction code. the serial number is 353508023085900.please help guys. thanks.
What is restricion code
Restriction code and network unlock code is same..Nokia Phone asks restriction code..If your Nokia Locked to network and you are trying to inserting other GSM Network sim card it will display the message "Enter Restriction Code" Without unlocking it you cannot use other GSM Network sim card.After Unlock it you can use only gsm sim card...
You can get the Restriction code from service provider,but they ask to wait for many days or months.
So you can get the Restriction code for Nokia 6300 easily from the site
Mobile-unlocker.com/nokia-6300/rs2wp9/ and unlock it easily...To enter the code you can follow the instructions below:
Nokia 6300 Unlocking Instructions :
Warning : Do not enter any wrong unlock codes on your Nokia 6300 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 6300 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 6300 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6300.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6300 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6300 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6300
Aug 09, 2012 | Nokia 6300 Cellular Phone
What's your problem?nokia 6300 restriction codes imei number352939/02/354728/7
Restriction code is nothing but the unlocking code for your mobile.
Unlocking your phone just removes the SIM card restriction so that you can use other network's SIM card.
To get the restriction code for your Nokia 6300 model mobile, just visit this site http://www.theunlockarena.com/nokia-6300/rs13wp9/,In this site just give your IMEI number , country & network lock after that within a short period
you can get the restriction code for your nokia mobile............I hope this is helpful for you.......
Dec 03, 2011 | Nokia 6300 Cellular Phone
I have a nokia 6300 phone with an old sim card in. I want to use a new sim card from another provider in the phone but it is asking for a restriction code, how do i dind this?
Restriction is nothing but the unlocking for your mobile,
Unlocking means in your phone just removes the SIM card restriction on your phone so that you can use any other network's SIM card.
To get the restriction code for your Nokia 6300 model mobile, just visit this site www.classicunlocking.com/nokia-6300/rs17wp9 , in this site just give your IMEI number , country & network lock after that within a short period you can get the restriction code for your nokia mobile............I hope this may helpful to you.........
Aug 24, 2011 | Nokia 6300 Cellular Phone
Nokia 6300 security code lost.IMEI No 359544/01
Warning: Do not enter any wrong unlock unlock codes on your Nokia 6300 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
Each Nokia 6300 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 6300 mobile phone atwww.mobileunlocksolutions.com.
May 26, 2011 | Nokia 6300 Cellular Phone
Restriction code
CALL SEVICE PROVIDER FOR NUMBER REMEMBER MOST PHONES ARE LOCKED TO A SERVICE PROVIDER IF YOU ARE USING SIM CARD FROM ANOTHER CO. IT MIGHT NOT WORK
Sep 20, 2008 | Nokia 6300 Cellular Phone
Nokia 6300
look under the phone for the serial number(imei) which is a 15 digit number............write it down and let me have it.
you can also enter *#06#  when there is no sim card in the phone to get the phones serial number.
good luck
May 29, 2008 | Nokia 6300 Cellular Phone
6300
Restriction code is the unloack code right :
Here is it :
Before trying anything else, contact your service provider and ask for an unlock code.
Usually, if you've been a customer of theirs for some time, they will provide you with an unlock code for free. This is, by far, the best way to get your phone unlocked.
Download software to generate the unlocking code. Software is available on some websites for free and some pay websites that also offer support if things go wrong.
See external links below.
Find the Serial number of the cell phone, also known as your IMEI number.
Using the software you have downloaded, enter in your Manufacturer (which is in this case Nokia), your model number, and your IMEI number.
Also enter your country and the Network. Calculate the code, this may be different depending on which software you are using. If your phone is the Nokia 6300phone, select the model 6300, they are the same phone.
#pw+403927744443466+7#
Remove the SIM card from your Nokia phone.
This is typically done by removing the back cover of the phone and removing the battery and sliding the card out. Put the battery back in and power the phone on.
You will see a message "Insert SIM Card".
Enter all of the characters you see in your code, including the # symbols.
To get a 'p' press * 3 times, to get a '+' press the * key 2 times, to get a 'w' press the * key 4 times.
Disregard any spaces in the code.
In order to unlock your phone you generally need to enter only one code.
Start with the first one. If your phone is not unlocked by typing the first code (MCC+MNC), use code "7" (Multilock)
Once you have finished entering a code that works you should see a message that says "SIM is not restricted" or "Restriction off" message depending on your model.
If not, try entering another code. Message "Cannot undo restrictions" means the phone is "hard-locked" and cannot be unlocked by code.
Tips
Unlocking only applies to GSM phones, phones using other cellular technologies, cannot be unlocked without special software and hardware.
Switch off the phone. Hold the keys "3", "*" and "Call" and switch the phone on. Keep the buttons held down till you see the word "Formatting..." on the screen. Make sure that the battery is full charged before you attempt this. This should reset the phone lock code.
Warnings
Attempting to unlock your phone is done at your own risk.
Although unlocking your phone is legal, some cell phone operators might choose to void your warranty should you unlock your phone (then again, some cell phone operators won't mind).
Most phones only allow you to try a certain number of unlock tries, Nokia phones have a limit of 5 tries.
After that, the phone becomes "hard-locked", meaning it cannot be unlocked without using special equipment.
Most of the newer phones will not work with the codes generated by the free unlock programs.
You can get a free unlock code generator software free from here :
http://unlock.nokiafree.org/
You can also download from here :
http://unlock.nokiafree.org/NokiaFREE_v310_Nokia_unlock_codes_calculator.zip
You can check this :
http://www.wikihow.com/Unlock-Your-Nokia-Cell-Phone
Good Luck.
Live, Love, Laugh.
May 10, 2008 | Nokia 6300 Cellular Phone
Nokia 6300
Follow the instructions given below & unlock your mobile by getting unlock code in this site http://www.theunlockarena.com/unlock-your-phone/rs13wp2/ & gain solution ...
Apr 30, 2008 | Nokia 6300 Cellular Phone
Nokia 6300,vodafone help with restriction code please
i got a nokia 6300 from england and i want the restriction for it to be used in jamaica
Mar 18, 2008 | Nokia 6300 Cellular Phone
Unlock 6300
model Nokia 6300
IMEI plain: 354835/02/536220/4
Jan 12, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
57 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
