Question about Zyxel P660HW-D1 Router
How do I change the wireless channel on my ZyXel P660HW-T1 router? I use the NetGear smart wizard that came with it.
  • jadoremark Nov 16, 2009
    Thanks. That helped get me started in the right direction. However, when I go to my router's configuration page, it only shows me the status of the router. It doesn't allow me to change anything. Can you help please?
    Ok, I figured out my password now. Thanks!
  • 4,281 Answers
First connect your router to computer with ethernet cable.
Then you can access it with below defaults link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
If you are not able to access with above link then go t ostart menu ->run type in run "cmd"
then type in command prompt "ipconfig /all"
There is gateway ip is ip of your router.
YOui can access router with that gateway ip.
Then you can see configuration page .
Click on wi fi or wireless then change channel type to 4, 6 ,or 11 .These 3 gives best result.
Then save settings and restart router for take effect.
Let me know if you need further assistance.Thanks.
Posted on Nov 16, 2009
I have a Zyxel P660HW-T1 v2 and when trying to use laptop wirelessly, the internet connection keeps dropping. While connected to the router by ethernet cable, internet is fine. All was working fine until...
For that you need to change wireless channel type in router. You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless->wireless channel type to 3 or 6 or 11 then save settings and restart router. . Let me know if you need further assistance. Thanks for using FixYa.
Jun 22, 2011 | Zyxel Prestige 660HW Wireless Router...
There's a network key for my ZyXel P660HW-T1 modem when connecting through wireless, and i never set any network keys before, what could be the probleM?
See there might be network key set up on the wireless modem already, you will need to check what the network key is ?
For this you will need to access the set up interface of the modem/ router.
Is there any computer connected to the router ?
or is there any other computer able to go online ?
use that computer to find out the key.
Click Here for more info about how to find the key
Nov 12, 2009 | Zyxel P660HW-D1 Router
ZyXel P-660HW T1 router - sporadic wireless connection
It could be caused by interference by other nearby networks/devices. Try changing the wireless channel.
Jun 03, 2009 | Zyxel P660HW-D1 Router
HELP!!!!!! Trying to enable wpa-psk security on my laptop?
You should set the security on your computer wifi card to wpa-psk and then type in the securitycode which is written in your Zyxel Router.
If this is not possible with your networkcard, change to wpa or wpa2 inside the Zyxel. And do the same procedure with your networkcard, when detected the Router.
May 04, 2009 | Zyxel P660HW-D1 Router
Can't connect my Ipod touch to my router?
You must be sure to what router you are trying to connect. I understand you have a ZyXel and a linksys. You must have 2 wireless networks. Your wireless network must be secured, so you just have to use the correct password. I need more details. Try this http://technicalsupport.blog.friendster.com
Feb 08, 2009 | Linksys Wireless-G WRT54G Router
i had the same problem too with my'n. My issue was on of my setting's was set to block that wi-fi connection. Try switching your setting for finding internet connection from automatic to manual. that should do the trick!
Dec 20, 2008 | Zyxel P660HW-D1 Router
Zyxel P660HW T1 V2 main screen in Turkish
go to settings of that and then change its language to english.
if u dont understand that then press reset button for 10 seconds which is back on router.then it reset but u have to reconfigure your router again if u reset it.
Nov 24, 2008 | Zyxel Prestige 660HW Wireless Router...
P660HW-D1 Router not working wireless
Problem with the Zyxel P-660?   I experienced:
1. laptop would see the wireless 660HW briefly and then it would disappear.   2. laptop would not see wireless at all. 3.  same issue with desktop when using USB wireless 11g dongle 4. no problem on wired connection (ethernet)
EASY solution!   if Zyxel is set to scan for a channel it will want to work on channel 13 nearly every time in a busy environment.
HP laptops and many receivers cannot recieve on 13 -  highest channel is 12.
Pick on setting for the Zyxel which matches an available channel on your receiver.  Problem solved.
Nov 20, 2008 | Zyxel P660HW-D1 Router
Zyxel p660hw wireless problem
I forgot my modem wireless password...and I can not make a connection without cable...
Jul 12, 2008 | Zyxel P660HW-D1 Router
ZyXEL P660HW-61
while your computer is directly connected to the router, try to change the channel to 1,6 or 11. Try to enable wireless security and disable firewall on your computer. try to turn off other wireless device that may cause interference on your network
May 08, 2008 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Logo
4,123 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
