Question about i-mate JAM Pocket PC
My mobile have startup pob blue page was there but then the device couldn't continue to start up(It's green page usually), it is showing a blank white screen. I have tried removing the sim and battery and nothing is happening
  • i-mate Expert
  • 2,973 Answers
Nothing will happen with those actions. You must get the firmware reinstalled. The firmware seems to have got corrupted somehow. The screens indicate towards this. So get the firmware reinstalled. it can happen to any phone that keeps getting data from here and there. Including the internet or the bluetooth. Contact the service center of your phone.
Posted on Nov 16, 2009
I have an HP Mini 110-3135DX. When I turn on the power all that is displayed is a blue screen and it wont boot. How do i fix it?
check you bios pages are correctly configured,,goto bios navigate with "tab" and arrow keys,,play around untill you know these pages dont change anything untill you are sure you know what you are doing..Exit and save pay attention to boot sequence if this is set up wrong it might cause failure in the way you describe,the instructions on the right hand side of the bios pages should help you---good luck --Davey
Jun 20, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
I have a PB6200 BenQ projector. When the computer starts up it shows the BenQ and then shows the windows computer startup screen until it finally fully boots up. Then the projector does not show what is...
There's a display "toggle" sequence on your computer to send the signal to your external post (VGA?). Look at the Function keys (top row) for a screen icon. Hold Fn key down and press that Function key (on Dell, usually F8). You should get an indication on your screen of which outputs are active -- look for BOTH.
May 28, 2017 | BenQ PB6100 Multimedia Projector
In management ,I can show a 500GB disk but couldn't read or write , couldn't active . I couldn't take out my data .
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 08, 2011 | Western Digital 500GB ELEMENTS 500 GB USB...
How do i remove web search as my home page
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. Click the General tab.
  4. In the Address box, type the Web page address that you want for your home page.
    NOTE: If you want the page that you are currently viewing in Internet Explorer to be your home page, click Use Current.
  5. Click OK.
FOR FIRE FOX
  • At the top of the Firefox windowOn the menu bar, click on the ToolsFirefox menu (Tools menu in Windows XP), and then click OptionsFirefoxEdit menu, and select Options...Preferences...
  • Select the General panel (Main panel in Firefox 3.5).
    • In the Startup box click the drop-down menu next to "When Firefox starts:" and select what Firefox should display when it starts up.
    • Show my home page - Displays the home page (or home pages of course).
  • Show a blank page - Displays a blank page (this loads fast - no waiting for lots of tabs to load).
  • Show my windows and tabs from last time - Opens the pages you were visiting the last time you used Firefox so you can continue right where you left off. Click OK to close the Options windowClick Close to close the Preferences windowClose the Preferences window .
kindly rate this solution
thanks and regards
Feb 14, 2011 | Computers & Internet
My laptop is on but the screen is blue and won't go to the desktop
A Mac that shows you a blank blue screen instead of logging you in may be afflicted by a malfunctioning startup item. Most people have a number of programs that start up whenever you log into your computer, and it's likely that one of these programs is causing issues. The startup item is unable to load, and so it causes the rest of the computer to hang.
In order to get your Mac past this hanging blue screen, you need to boot into safe mode and figure out which startup item is causing problems. The Apple Support article "I see a blank blue screen when I try to start up my computer" tells you exactly how to go about this procedure. Basically, you must remove all your startup items and add them back in one-by-one, rebooting each time until you find the one that causes the hanging blue screen.
Dec 28, 2010 | Computers & Internet
The computer is on, but the screen is all blue
Dec 28, 2010 | Apple MacBook Mac Notebook
I have dell insprion 1525 laptop. my dvd drive does not read dvds, the green light just continuously blinking. cds shows blank.
Hi
Please can you try the following
1) Power in laptop
2) Continuously press the F8 key until a advanced startup menu is seen
3) Choose safe mdoe
4) Try CD in safe mode and see if it works
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron 1525 Notebook
Samsung F480 won't startup
press Camera button + volume down + power button ( together )
if the mobile turn on and show ( download or any word .. so you can fix it by changing the software )
Dec 19, 2008 | Verizon Communications Samsung Juke Cell...
I Mate Jama Start up problem
make a hard reset to your I-mate jama
Remove the battery, Simultaneously hold volume(-) button and red hangup button, while still holding those keys, insert the battery and wait for the led to go out, release keys and device will hard reset.
Start->Settings->System tab->Master Clear->1234->ok
here is the video for how to
http://mygsmtube.com/videos/198-imate-jama-hard-reset-howto.html
Oct 31, 2007 | i-mate JAM Pocket PC
Start-up of i-mate JAMA
I had same problem. Remove memory card, battery then reboot then put memory card back. Should work. regards
Sep 25, 2007 | i-mate JAM Pocket PC
i-mate JAM Pocket PC Logo
83 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
