Question about Canon PIXMA MP160 All-In-One InkJet Printer
LOST MANUEL? NOT SURE HOW TO USE THE SCANNER AND I HAVE HEAVY STREAKS ON THE IMAGES PRINT ON PHOTO PAPER.
    Problem Solver:
  • 19 Answers
For the manual download from canon.com
Posted on Jan 09, 2008
Scaned photos have vertical streaks in them also colors are off?
Vertical streaks caused by one of two things. Most probably glass needs cleaning. Could also be several pixels are bad. If that's the case, it's cheaper to buy a new all-in-one. Try cleaning first. Colors may be from your monitor not being adjusted properly. Do the photos print out properly (except of course for the streaks)? If so, monitor is the culprit. If not, scanner tube is shot. Again, buy another scanner/printer.
Aug 18, 2012 | HP Photosmart C6180 All-In-One InkJet...
My printer is leaving horizontal streaks across
When I had the same problem, I found out, that Epson did not like Generic Ink. As soon as I replaced it with Genuine Epson Ink, it was fine.
Make sure you do Maintenance, Nozzle Check and Head Cleaning. You might be clogged?
Good Luck.
Nov 05, 2009 | Epson Stylus Photo R220 InkJet Printer
Have hp photosmart printer 7700 series problem loading 5x7 photo paper into printer
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr5
Aug 18, 2009 | HP Officejet 5610 All-In-One InkJet...
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Green streaks on scanned images
Try placing your paper at different places on the scan bed. Also if you have fluorescent lights on nearby turn them off.
Also is your driver compatiible with your OS?
Did you recnently upgrade anythin?
Feb 27, 2009 | Microtek SCANMAKER I900 Flatbed Scanner
Blue Streaks
Try removing the printhead (cartridges first, careful where you put them, they'll make a mess) then clean the print surface with a window cleaner and cotton swabs.
There may just be deposits on the surface and this is not far from the paper surface.
Aug 15, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Epson Perfection V100 Photo flatbed scanner
I would not think Norton is the problem but one can never be sure - Uninstall Norton to prove one way or the other Then come back
Aug 25, 2007 | Epson Perfection V100 Flatbed Scanner
Red line on last quarter of photos
I assume that the red line is not on the photos themselves (make sure this is the case - if they're scanned photos, it might be a scanner problem). If this is a 4" by 6" paper, set it in the printer after bending it in the opposite direction. 1) Set a sheet of paper on the printing side of the paper to be printed on. (If the print surface is touched by hand, the print surface may be soiled by skin oils, and the print quality may deteriorate.) 2) To bend the paper, hold the paper in a rounded shape for about 10 seconds. 3) Remove the paper not to be used in printing, and confirm that, when laid flat with the print side up, the center of the paper to be printed on is raised between 2 to 5 mm (0.2 in.) . 4) The curled paper to be printed on should be set in the printer, and printed, sheet by sheet. Canon recommends using Photo Paper Pro PC-101S 4" x 6" sized paper. When using PC-101S, printing is performed at the center of paper and streaks or uneven printing is avoided. If this is an A4 sized paper, try using Photo Paper Pro PR-101 paper, and make sure that the printing quality is set to "high" or "fine". If nothing helps, I would suggest trying a new ink cartridge. If you still have this problem and nothing solves it, call a repairman.
Apr 09, 2006 | Canon BubbleJet i560 InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
32 people viewed this question
old marine
old marine
