Question about Compaq iPAQ Connection Point CP-2W (241274-001) 802.11b Wireless Access Point
Set up Hi, my parents gave me their old compaq ipaq cp-2w router but they didn't have the manual. I'm having trouble getting it all set up. I followed some instructions I found on another website that told me to do the whole IP number thing, but nothing happened. Can you help me? Thanks!
    Novelist:
  • 101 Answers
Hi Rbosley,
I found the real manual here,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=us&dlc=en&product=218413&os=228&lang=en&
Second one down.
Are you using Cable, or DSL. DSL requires you to setup a PPPOE connection, putting in your Username and password for you DSL connection.
Are there any other routerrs on the network? Just making sure you are not trying to use the router then there is one already one on the work.
I would suggest your use the reset button on the back, resetting it to defaults. That way, you should be able to plug in your modem to the WAN port, plug your computer into the LAN port.
Then restart the modem, wait 2 min, power up the router, wait 2 min, and startup the PC. Make sure your IPs are set to automatically get IPs and DNS. The router's DHCP should supply them to your PC.
DSL requries you setup a PPPOE connections, which really just consists of selecting the pppoe option, putting in the infomation, and the doing all the rebooting.
It you still are having issues, get back with us!
Posted on Jan 09, 2008
I forgot my security key for the cp-2w
you will have to reset it and start over. Press the reset button until it shuts off and comes back on . Follow the instructions like you did when you first purchased it. You can give it a new security key, but you should write it down somewhere so you can use it whenever you need to.
Nov 08, 2009 | Compaq iPAQ Connection Point CP-2W...
How do i get the wpa key fro my psp
you can try looking at you router settings ,look under security settings. if its not there you won't find it.
Jul 07, 2009 | Compaq iPAQ Connection Point CP-2W...
Setting a secuirty access password on Compaq IPAQ router CP-2W
You want to setup WPA, assuming the access point is new enough.
WPA with a Pre Shared Key (aka PSK) is what you want. This is often called WPA Home or WPA Lite or something similar. All a PSK is really is a password.
Look for this on your wireless setup menu. You should be able to set it there. There's a small chance this is on the advanced screen, although most have it on the normal screen. If you have a really old access point, you're likely going to only be given WEP options. If so, spend the $50 for a new one. You'll be money ahead in the long run... Since this is an 802.11b access point, that's almost certainly the case...
Mar 31, 2009 | Compaq iPAQ Connection Point CP-2W...
Give me a wpa key for my psp
If you forgot the key:
Reset you router to factory settings.
Enter a new WPA key to the router and PSP.
Mar 17, 2009 | Compaq iPAQ Connection Point CP-2W...
Lock my wirless
Hi!
I found the user guide for your device form HP's download page. You can click this link and just go to page 28, and it will give you the step by step instructions on how to setup WEP to secure your wireless networks. If this will not work or need more further assistance just reply to this thread. I hope this will fix your concern.
May 11, 2008 | Compaq iPAQ Connection Point CP-2W...
No signal
Is the wireless switch of your pC on? if it is, then try to reboot your PC and the router. You should see one. Check also if the SSID broadcast of your router is enabled.
Oct 06, 2007 | Compaq iPAQ Connection Point CP-2W...
Weak/No signal
Opening your browser. Looking in your manual there is an instruction telling you how to connect directly with your modem. Type that address in, enter the user name and password it tells you. Then look through several of the option tabs it will display. There will be one that controls the "transmit power" level. Once you find it, change it to 100% if it something less than that. That should fix your problem.
Sep 07, 2007 | Compaq iPAQ Connection Point CP-2W...
I don't have a cd installation ...have no idea how to hook this up..please help
You probably dont need to get any cd, but here is a basic setup. 1. First reset router to factory specs..there is probably some sort of reset hole on the router. With router disconnected Stick paper clip inside and hold while you turn back on router about 10 seconds. 2. Next with computer and Modem turned off plug the Ethernet cable from the modem to the WAN port on the router. 3. Next plug an ethernet cable from the router to the PC. 4. Turn on Modem, then PC it should get you on the internet. 5. Usually the Wireless portion is defaulted to ON, so knowing you have a wired connection, you can now try with your wireless device. 6. Windows will find this signal and it will give you an option to connect to it. When you get an IP address, you will be on. To get into more advanced setup, you will need to get into the router. Try It you should be alright
Feb 27, 2007 | Compaq iPAQ Connection Point CP-2W...
No Signal
hey i hope this issue has been resolved by now... ami i right .. if its not then jus lemme know n i l post ya the exact solution for this one ,,, i think its a very minor issue,,, plz respond
Aug 18, 2006 | Compaq iPAQ Connection Point CP-2W...
Compaq iPAQ Connection Point CP-2W (241274-001) 802.11b Wireless Access Point Logo
238 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
