Question about Nokia E75 Cell Phone
I PAIR IT WITH MY EAR PIECE PLANTRONICS DISCOVERY 925 BUT IT FAILS TO CONNECT
  • hjkdfg May 11, 2010
    GENERAL PROBLEM
    » Nokia Solution » Motorola Solution » Sony Ericssion Solution » LG Solution » Samsung Somution
    UNLOCK CODE
    » Nokia Unlock Code » Motorola Unlock Code » Sony Ericssion Unlock Code » LG Unlock Code » Samsung Unlock Code
    lkkjhg5
Problems with dicovery 925 keep blinking purple light and can't pair with the phone help
Something you may want to try is start from the beginning. Check to make sure there are no other bluetooth devices loaded onto your phone that might interfere with the process. Turn off your phone. Disconnecting the battery of your mobile for 30 seconds and reconnecting helps to reset the phone. The instructions for turning off the headset and re-pairing the two devices are located in the following link for the Plantronics Discovery 925 User's Guide.
Good luck from Headsets Direct!
Sep 03, 2011 | Plantronics Discovery 925 Bluetooth...
I have an LG phone and my Discovery 925 bluetooth from Plantronics won't connect anymore. When I have it in discovery mode my phones message states "no devices found."
You want to make sure that there is no other bluetooth interference on your phone and follow the instructions on the link for the Plantronics Discovery 925 (see page 4).
Jul 17, 2011 | Plantronics Discovery 925 Bluetooth...
Bought this approx 2 or 3 months ago. In about a week the ear piece broke. now I can't seem to find a replacement. The clerk at the store tells me they don't make this kind any more . How...
I would recommend looking into different models. The Plantronics Discovery 925 is a great model out now, but depending on your price range, there should be a great number of solutions from manufacturers like Plantronics or Jabra
Jun 28, 2011 | Samsung WEP700 Bluetooth Headset
It will not turn on after a full charge
Sounds like you have a bum unit.  Plantronics gives a 1 year warranty with every wireless product, I'd send it back.
Have you made sure that you're turning it on correctly?  You push the call answer button and hold it down for about 3 - 5 seconds before it turns on, until the blue light turns on.  Make sure that you don't hold it longer than that or it will go into pairing mode.
Apr 26, 2009 | Plantronics Discovery 925 Bluetooth...
Switching on discovery 925
Switch the bluetooth function on your phone, search for devices and then pair with your headset once it finds it. Allow it to connect without confirmation and leave your bluetooth switched on on your phone. Everytime you turn on your headset it should connect automatically.
Apr 10, 2009 | Plantronics Discovery 925 Bluetooth...
The Plantronic Discovery 925 will not stay in my ear. I've tried diferent sizes but nothing works. What is the proper way to insert in my ear?
make sure the clear rubber piece that looks like a horse shoe is pointed towards the top of the ear.  You could have a weird shaped ear however.
Apr 09, 2009 | Plantronics Discovery 925 Bluetooth...
Instruction on how to wear plantronics 925 bluetooth
The round portion that has the smaller hole in the center, with the small extension, goes into your ear. The squarish loop then needs to be rotated to out, so that it is "hooked" into the curve of your ear. Try different sizes to get the right fit of the loop (the bodies are identical).
Jan 30, 2009 | Plantronics Discovery 925 Bluetooth...
I need to know how to pair my plantronics discovery 925 - I have no user instructions
set your phone to discovery mode. press and hold the button inside of the diamond until it flashes blue and red. once you do that, your phone should see it. Pair it to your phone by putting in code. 0000.
Happy Calling :)
Dec 19, 2008 | Plantronics Discovery 925 Bluetooth...
Nokia E75 Cell Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
