Question about Cell Phones
Can receive calls but unable to dial out comes up with ''connection error'' and a small red sign
When a call comes in and I transfer to my boss' extension, incoming calls do not come through, caller states phone keeps on ringing. Also on that same extension calls do not transfer to voice mail.
  • Begin the transfer. With the caller on the line, press the "Transfer" key. The caller will automatically be placed on hold and you will hear a dial tone.
  • Connect the caller to the other party. Dial the extension of the party you wish to reach. When you hear the extension ring or after you've announced the caller, complete the transfer by pressing "Transfer" a second time. If the person does not wish to receive the call, press "Release" to disconnect from the dialed extension. Press the key beside the flashing arrow on the LCD indicator where the various lines are displayed to return to the caller.
  • Cancel an incomplete transfer. If you make an error when dialing and need to retrieve the caller, simply press the key beside the flashing arrow on the LCD indicator.
  • Park an incoming call. Parking a call at a designated extension allows the recipient to answer the call from any phone in the facility. With the caller on the line, press the "Park" key twice. If your system designates a particular extension for parked calls, the caller will be held at that extension. Otherwise, the caller is held at your extension. To specify an extension for a parked call, press "Park," dial the desired extension and press "Park" a second time. Replace the handset.
  • Retrieve a parked call. On any system phone, press "Park" and dial the extension on which the call is parked. You will be connected to the caller.
Aug 18, 2016 | Nortel Norstar M7310 Telephone
ZTE MF190 Dialing problem
I have a unlocked ZTE Mf190 USB-Modem. When I put the SIM card in it and connect it to the computer, I am able to connect to 3G Internet via beetel connection manager. Is it also possible to send and receive SMS. But when I try to make a voice call on beetel voice call panel, I receive this error message "Dialing failed! Please try again!" . And also when I use another phone to call the SIM card line number that I put in the USB-Modem, I receive busy tone
Mar 31, 2013 | ZTE Mf190 Unlocked 3g Gsm 7.2 Mbps...
Hi,i have nokia 5800 xpress music unable to view dialed ,received & missed calls. It says no dialed numbers
  • Increase the log duration option.
  • Also check whether the theme is blocking you from viewing the call logs.
Mar 19, 2013 | Nokia XpressMusic 5800
Error 734 ..ppp protocol terminated in .Aircel pocket internet
dear Sir,
I have the mobile handset samsung GM S 3310. I am usuing Aircel Pocket internet in this phone. Surfing net is not a problem from the handset , but unable to connect it to my laptop.
Before dial up, it gives :error 734 ..ppp links protocol terminated. Therefore I Can not connect pc to handset as the dial up connection is not established.
Oct 28, 2009 | HTC S710 Smartphone
Unable to answer and call out
Your welcome!
Thats why we come here... to help others and to get help!
I am just going to post entry as a solution, so this way the problem is off the help menu and put into the solutions category.
Have a great evening.
Apr 29, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
No dial tone on xp
U need to double confirm the phone line whether got dial tone or not. What u can do is to plug the phone line to a single line phone. If dial tone is available, u can able to make call.
Feb 13, 2009 | Dell Inspiron 530 Desktop Computer
Unable to find Voice dial for bluetooth carkit
in your settings you have car setting try there first
Jan 04, 2008 | LG Prada KE850 Cellular Phone
Unable to make or receive phonecalls
Your phone is barred. This means it has been blocked of making or receiving any calls.
Aug 18, 2007 | O2 Xda Orbit Smartphone
Blinking Standby
regarding the Pioneer VSX-912 blinking standby light. This is how you reset it; press the "advanced surround" and the " enter" at the same time for about 3 seconds. Make sure you press the ENTER on the reciever (its the one on top next to the small dial) If you press the "ON" instead of "ENTER" it will not work. If an error message comes on and shuts the unit down, just reset it again. This should save you some $$$$. To bad Pioneer did't put this info in the manual.
May 22, 2007 | Pioneer VSX-D912 Receiver
Sending and receiving problems
Where the telephone line comes in from the wall, make sure that it is plugged in the "line" or "wall" port. There is probably another port call "tel" or "acc". If the line is plugged into that port you will still get a dial tone but you are not connected to the fax's modem. You hope that's it. Ed
May 15, 2007 | Canon FaxPhone L75 Plain Paper Laser
Cell Phones Logo
205 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
