Question about Hotpoint VBXR1090D Top Load Washer
Hotpoint vvsr1070daww washer fills with water then quickly drains
    Brigadier General:
  • 3,513 Answers
The symptoms that you have provided is clear that there is some problem with the water pump is busted, it is located on the other side of where the drain hose is attached
Thanks for contacting Fixya.com
Posted on Nov 16, 2009
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
Hi, I have a Hotpoint Aquarious washing machine (UK). It has developed a leak and seems to be overfilling however it does stop filling. Hope you can help.
I can not see the entire front of your machine, are you sure its over filling? I use a front loader also, at the bottom of my front loader is a small door, when I open it there is a drain pipe inside, sometimes the drain needs to be cleared. I am hoping this is your issue and that this is a quick fix for you.
If not, you can check the back of your washer where your water hose connects to washer. Inside the hook up is a screen (on your washer) sometimes these become clogged due to mineral deposits in the water.
Jan 07, 2013 | Washing Machines
WASHER WON'T FILL WATER
Check to be sure the drain line is higher that the tub of the washer. You have a siphon going on the drain.
Nov 05, 2012 | Hotpoint Washing Machines
All cycles on my washing machine work, but machine will not agitate. What are possible solutions to fix the issue? It is a Hotpoint, top load, model # is vvsr1070daww
The most probable thing causing it to not agitate is going to be stripped/broken agaitator coupler.
The video will show you to take out the agitator and check for a defective agaitator coupler
http://www.youtube.com/watch?v=N26MCQKuXn0
GENE
Sep 05, 2011 | Hotpoint VVSR1070D Top Load Washer
WASHER FILLS UP THEN DRAINS WATER OUT. WILL NOT HOLD WQTER. TUB PROBLEM?
If you do not have water on the floor under the washer, then your tub is fine. You could have a drain solenoid valve problem.
Oct 25, 2009 | Hotpoint WMA64 Front Load Washer
Fills, does not agitate, drains, spins, fills, does not agitate, drains, spins
grab the agitator at the base and give it a quick push upward..remove and see if the white dome with bolt holding it down is stripped on the inside where it splines onto the transmission shaft. :)
Jun 13, 2009 | Hotpoint VBXR1090D Top Load Washer
Hotpoint washer fills begins to agitate then refills continously.
Very likely your drain hose is set too low. You can solve this with a standpipe or a kit called a siphon break.
Dec 31, 2008 | Hotpoint VBSR3100GWW Top Load Washer
NOT FILLING PROPERLY
have you got the drain pipe going up to about worktop level of machine?
if the drain just goes downwards then the water just runs out as fast as it comes in. get a sililiar situation if you put drain pipe too far down a standpipe - then a syspon forms and water drains out
Jun 28, 2008 | Hotpoint First Edition FEW12 Front Load...
Not draining and flooding my kitchen!
hiya
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
please dont forget to rate the helpfulness of this reply thanks kj
Jun 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint VBXR1090D Top Load Washer Logo
43 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
