Question about ASUS Eee 4G Notebook
Will not charge or turn on or anything - ASUS Eee 4G Notebook
    President:
  • 414 Answers
DO IT ONLY IF U R A PROFESSIONAL..
..plz do check the following as in order:..
the Hardware part:..
1) check mains/power supply..the fuse, switch, wiring n associated circuitry..
2) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..
check the battery n adapter [main power], in case of laptops..
replace with a standby n see..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) open the cpu n see if heat is generated..if not..replace the cpu n see..
5) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
6) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
7)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
8)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
plz give priority to steps(2, 4 & 6)..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 16, 2009
After charging,the screen says philips,and wont do anything else
Hi Cheryl, The link below is a youtube page full of videos showing how to turn on your mp3 player and unfreeze it.........CHEERS..
how to fix mp3 player that won turn on YouTube
Apr 24, 2016 | Philips GOGEAR Audio Players & Recorders
My tesoar tablet showed charging for 3 seconds then that was it now it wont turn on it wont do anything
I have a hacker inside my Samsung galaxy 8 notebook, he controls my ph and I pad, how do I break the tracking link.
Mar 21, 2014 | Samsung Galaxy Tab GT-P7510MAVXAB Tablet
I got this tablet for Christmas. Used it a few times. Now it won't charge and won't turn on. It kept blinking the IRULU screen today but now its not doing anything. What do I need to do?
This may be a permanent problem, though it may also just be a battery problem.
If possible try checking the cord on another device that you know works to make sure it is functioning properly. Then try plugging in the tablet to charge, USB to the wall if possible and let it charge for a day or so. Feel free to check it every couple of hours to see if it is turning on. This may just be a battery memory issue, or an extremely drained battery -- though there could be some type of damage.
If you can't get it to turn on after a couple of days of charging then you should probably look into some return or replacement options.
Hope that helped. Good luck.
Dec 28, 2013 | Computers & Internet
The 255 wont do anything when charging. How can
when it is charging u just slide the on/off switch to the left, it is spring loaded, hold to the far left for a second then release, if the unit doesn't turn on it is defective.
May 04, 2010 | Garmin Nuvi 255 GPS Receiver
My Mp3 PLayer is charged but no matter what I do, It wont turn on
your battery has run out and needs to be charged that's why it is not turning on.
connect it to a another usb port on your computer and it should be able to turn on and charge, it should work, if you still have problems, comment back.
Jul 03, 2009 | Philips GOGEAR SA6045 MP3 Player
Plantronics Pulsar 590A headset won't charge anymore.
I too have the same problem as jessehaye154, does anybody know of a solution?
Apr 10, 2009 | Plantronics Pulsar 590A Wireless Headset
When is the battery charged?
these small dvd player are built with less options
normally with cheap batteries, so usually it will turn green when fully charge or even turn off. hard to say. but since it cheap batteries, it probably wont do anything at all.
i would charge it for 10-14 hours then unplug the device.
the battery will get hot, and then the device will no longer work after over charging the player.
so charge for 10-14 hour only UNPLUG the player
play til it dies then start process all over again.
if you find that the battery is dying faster and faster then you have a cheap battery
theres no easy fix for this, some battery cannot be interchanged
when buying something make sure you can exchange the battery like a laptop. this way if the battery is overly charge it doesnt leak into the player.
or into the device
Jun 18, 2008 | GPX PDL805 Portable DVD Player
MOTOROLA H500
I CHARGED MY BRAND NEW MOTO H500 HEADSET FOR 3 HRS CAME BACK AND BLUE LIGHT WAS OFF. THAT MEANS FULLY CHARGED. WHEN DISCONNECTED FROM CHARGER. I TRIED TO TURN IT ON AND NO LIGHT OCCURED. FLASHING.. STEADY... PULSING... OR ANYTHING
Jun 15, 2008 | Motorola Mobility H500 Wireless Headset
Froze and now dead
Stuck or frozen
you have to hold the the menu and middle ong for 10-20-30 secs
hold the menu +center button and it will turn off and reset
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Mar 17, 2008 | Apple iPod MA446LL/A MP3 Player
ASUS Eee 4G Notebook Logo
187 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
