Question about Cell Phones
I can't remember my keypad lock for my moile - Cell Phones
Don't know how to set key pad lock
Before locking the keypad first remember if the keypad lock is assigned with a security code.
Default value of the security code is normally 0000.
1. To lock the keypad first press the option key, then select the LOCK KEYPAD.
2. To unlock the keypad press the option key then press the "C" button.
You can check more lock/unlock optoons in the users manual, downloadable from this link. Read page 63 and on.
http://dl-www.sonyericsson.com/cws/download/1/150/669/1192984731/J230i__UG_R1a_EN.pdf
Sep 04, 2011 | Sony Ericsson J230i Cellular Phone
How unlock my nokia keypad .it's 1100 nokia mobile. I can't remember keypad unlock code
keypad can be locked using the security code .... security lock can be reset using master unlock code ...
you can get the master unlock code at www.theunlockspot.com ... in reliable cost
Nov 12, 2010 | Nokia 1100
I HAVE LOCKED THE KEYPAD SECURITY SO PLEASE TELL ME HOW TO REMOVE THE KEYPAD SECURITY LOCK
If you remember the code you would not be on this site. Only way to get over this problem is to get the firmware re-installed.
Aug 02, 2009 | Nokia 5130 Cellular Phone
Keypad is locked
Blackberry has given the keypad unlock code for security purpose if you dont remember your keypad unlock code. You need to enter wrong password for 10 times you're handheld will get wiped out you will lose all the data which is there in you handset, Then it will ask for the Reset password enter the new password and remember that.
Aug 01, 2009 | RIM BlackBerry 8700c Cellular Phone
Unlocking keypad lock
To lock the keypad so that you don't accidentally call anyone, simply press AND HOLD the red "end call" button.
To release the lock, press the left menu button, then hash (#)
Please rate after seeing my solution
Mar 06, 2009 | HTC S710 Smartphone
How to lock and unlock keypad Motorola VE240
To Lock your phone
Hold down the # symbol on your phone until it says: "Phone Keypad is now Locked"
To Unlock your phone
The screen should now read in the bottom right hand corner "Unlock". press the corresponding key. It then asks "Unlock Keypad?" "Yes" or "No". Select Yes and press Menu button (also the play/pause button).
Hope this helps you all!
Jan 02, 2009 | Cell Phones
Nokia 1650 v5.53 RM-305
i lost my security pass word. how can i handle that phone
Nov 01, 2008 | Samsung SGH-e315
Keypad lock on nokia 6670
That was a simple question but you can get applications for locking the keypad automatically also like the previous non-Symbian phones.
But if you dont want auto key-lock,
Press the left soft-key
and then the * key to lock the keypad.
Remember, the menu key is different from the left soft-key.
Do the same to unlock the keypad.
Remember to rate me.
Sep 19, 2008 | Nokia 6670 Handheld
Locked cell phone keypad
first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
if that doesn't work then try this from the website.
How do I lock/unlock the phone's keypad? To lock and unlock your phone's keypad, press and hold the left navigation key.
Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK button. You can set your phone to lock the keypad immediately, or automatically if no key is pressed after 30 seconds, 1 minute, or 5 minutes.
To unlock the keypad: Press 1-2-3 in that order."
good luck!
Apr 15, 2008 | Kyocera K10 Royale Cellular Phone
Keypad lock code
save ur data on to mem card and remove ur battery,,put it back. switch on the phone again.
Sep 15, 2007 | HP iPAQ hw6515 Pocket PC
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
