Question about i-mate JAM Pocket PC
How to properly shut down it - i-mate JAM Pocket PC
    Problem Solver:
  • 5 Answers
Network>disable>turn off screen>open up back cover
Posted on Nov 23, 2009
Model PL81. Why does it zoom, beep, and shut down?
Are you positive that the battery is good? Turning on for a few seconds and then shutting down is a classic symptom of a battery that did not take a proper charge and as soon as the surface charge is used, unit will shut down. And what if your charger is not properly charging the battery?
If you have a battery eliminator try that in lieu of the battery to see what happens.
Mar 28, 2016 | Samsung Cameras
HP Dv7t won't shut down properly
I would run a registry cleaning programme first. It may be just looping.
Feb 15, 2014 | HP dv7t Notebook
Hp P6653 won't shut down properly after clicking shutdown
Open Control Panel, select Power Options, select High Performance, Use this procedure to set the Advanced power settings: http://www.makeuseof.com/tag/windows-7-power-options-sleep-modes-explained/ Use these tip to speedup starts and shut downs: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332 Try Freeware MALWAREBYTES at : http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version, Run a FULL scan, delete ALL results, reboot.
Mar 09, 2013 | HEWLETT-PACKARD Pavilion p6653w...
My computer is on but no picture. It says windows was not shut down properly
Hello Pattiaknight,Make a desktop shortcut to shutdown and include a switch that forces all open apps to shut down without warning.
Just right click the desktop, New, Shortcut, type:
Shutdown -f
Shutdown -f closes any open programs without warning.
Now instead of shutting down the usual way, just use that shortcut to shutdown. If the error stops it means some program wasnt shutting down properly on occasion.
Please let me know if you any further questions or concerns.Also please rate it if you like the answer,it helps alot.
Thanks.
Apr 19, 2012 | Sony Computers & Internet
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Aug 17, 2011 | Gateway LT2021u Netbook
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue
Mar 05, 2010 | Microsoft Windows XP Professional With...
Why does laptop shut down
Your laptop is getting overheated . Check there is proper vent for fan . Also ensure the heatsink is proper . Remove the battery and check the working of laptop is proper with AC plug .
If it is proper then you need to change the battery .
Mar 03, 2009 | HP Pavilion dv9000z Notebook
My laptop won't shut down properly!
Is it possible that you have changed the settings of what buttons do what on your system? E.g. you could have changed the power button to "switch user" instead of "shut down", to check this (in XP) go to "Power Options" (in Control Panel" and then click on the "Advanced tab" at the top, then select "Shut down" from the drop down menu at the bottom of the window.
If this is already set to shut down then maybe you could do a system restore in case another setting has been changed, restore it to before the PC started doing this.
Alternatively try actually choosing "Turn off Computer" from the Log On screen (press Ctrl + L to get to this screen, or choose switch user/log off). If you are using Vista I beleive that there is a shut-down option from the Log In Page there (which again you can access by pressing Ctrl + L on the keyboard.
Hope this helps!
Dec 29, 2008 | Computers & Internet
Cann't shut down properly
If you are trying to shut down with the camera still connected!!??GOTO the bottom right of screen and ""safely remove hardware"" see if the system will shut down.....sometimes a hardware driver does not want to shut down so you must turn it off and plug it in again when you start windows again....
Nov 28, 2008 | Sony VAIO PCV-RX753 PC Desktop
i-mate JAM Pocket PC Logo
51 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Bilal Ahmed Qureshi
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
