Question about Dell Optiplex GX520 Desktop PC - Intel Pentium 4 3.0GHz, 512GB DDR2, 40GB HDD, CDRW, Windo
Blue screen physical memory dump..page_fault_in_nonpaged_area *** STOP: 0X00000050 (0xBAD0B148, 0x00000000, 0x805BA28F, 0x00000002)
    President:
  • 414 Answers
Probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/daughter or addon card(s)..
..plz do check the following as in order:..
the Hardware part:..
1)a)inpower on mode, open/unplug the data/vga cable of the monitorfrom cabinet..see if raster or 'osd' is appearing on the monitorscreen..if so monitor is ok..else replace the monitor and see..[notapplicable in case of laptop]..
b) in case of laptop try to getoutput from external display unit/monitor using vga port..if there'sproper display in there..the problem is probably with either the 'lcd'or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4)see ifthe ram(s) is loose/faulty..open clean/remove carbon & oroxide formed on the teeth with an eraser n resit it..or replace with astandby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6)remove/cleandust neatly..dust is non-uniform in nature n may cause jam/shortcircuitry/excess resistance n many more..resulting an increase in heat..
7)open the CPU Heat-Sink with fan out of the socket..put some "Heat SinkCompound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit ittightly in position..
8)on main/mother board..see with a debugcard for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuitlie around atx connector..the crystal clock generator (if cpu isn'theating up)..
9) [in case of desktop] the smps itself may bdefective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic',or pwm switching regulator circuit..look fordefective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
the Software part:..
1)hva licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove allthe unnecessary startup items from here..(if u can't find what toremove, post me/us in ur comment with all the items listed in each nevery tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a)'AutomaticallyRestart' right click onmy computer->properties->advanced->startup nrecovery->(un check on the) Automatically Restart;
b)'ErrorReporting' right click on mycomputer->properties->advanced->errorreporting->disable error reporting->(uncheck on the) 'but notifyme when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 16, 2009
  • 2,973 Answers
This is an indicator thrown by Windows that it is about to crash. When this starts to happen, you must take a backup of your data, specially the My Documents folder and the mp3s and 4s and other videos, if they are on the same drive as the Windows folder and reinstall Windows. You will loose all SW/programs that you installed for your work including MS Office and will have to reinstall all of them again.
2 Suggested Answers
  • 105 Answers
SOURCE: Physical memory dump
Hmm... Well a Bluescreen is when your computer crashes, and (as you have found out) preforms a physical memory dump. This can be caused by multiple things. Such as bad drivers, PFN(page frame number) or problems with your memory. When a bluescreen event occurs, the is a technical information which has an error code that can be used to help find the problem. In order to fix this problem, you may have to remove any software, or hardware that you have recently installed. To uninstall software, you may need to boot in safe mode, which is where your computer starts up using the minimal amount of drivers needed, in order to try to prevent the computer from crashing.
Here are some useful websites (sorry, my hyperlink icon isn't working):
  • www.datarecovery.com.sg/data_recovery/hard_disk_symptons_blue_screen.htm
  • www.maximumpc.com/article/features/blue_screen_survival_guide
Posted on Feb 27, 2010
Installed memory
It could be a bad memory module or just not properly seated in the slot. Does it work when you remove what you just added?
Nov 26, 2013 | Packard Bell EASYNOTE MV35202 COMPATIBLE...
Page in fault in nonpaged area
you have a faulty RAM. try switching it with a new one, it should solve your problem
May 23, 2017 | Acer Aspire One Netbook
Blue screen appears & keep restarting
It is possible that the malware is to blame, in which case a computer technician will need to sort it out.
I think it may be a bad memory module or loose memory module connection.
Take care!
damnor01
Apr 28, 2012 | Acer Extensa Computers & Internet
What do I do to stop my laptop from dumping physical memory? My laptop says this: STOP:0X000000D1 (0X6F19E728, 0X00000002, 0X00000000, 0XF7A59271) W22N51. SYS- ADDRESS F7A59271 BASE AT F79F0000, DATE STAMP...
You have either installed a faulty driver or unsuitble update or your Hard Drive,CD Rom or some other Hardware has failed, try starting in Safe Mode by pressing the F8 key several times right after starting your computer if you get in select the "last good known configurations" or "safe mode" itself and undo changes made before this happend. If all fails try to do a system restore from the safe mode entry.
Jul 07, 2010 | Toshiba Satellite A100-S8111TD Notebook
Feb 27, 2010 | Dell Dimension 8400 PC Desktop
Page fault in nonpage area
Restart the Computer and keep tapping the F8 key for 5 to 7 seconds to display the Advanced Boot Option screen. On that screen, select "Last Known Good Configuration" option. Furthermore, if you've installed any new hardware then uninstall it.
Once the Computer is able to boot successfully, run "chkdsk /f /r" utility to detect and repair any disk errors.
Faulty hardware, a buggy system service, anti-virus software, and a corrupted NTFS volume can all generate this type of error.
Aug 29, 2009 | Computers & Internet
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Laptop starts dumping memory
Please run a system restore to factory settings.
May 14, 2009 | HP Compaq nx7010 Notebook
Inspiron 600 m Dell blue screen
Keep pressing F8 as the computer starts up, select "last known Good Configuration" from the menu.
Jan 22, 2009 | Dell Inspiron 600M Notebook
Dell <b> Optiplex GX520 Desktop PC - Intel Pentium 4 3.0GHz, 512GB DDR2, 40GB HDD, CDRW, Windo Logo
469 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
