Question about Toshiba Satellite M35-S456 Notebook
I NEED REPLACEMENT BATTERY PA3331U-1BAS - Toshiba Satellite M35-S456 Notebook
  • 2,567 Answers
Here is a link to a very good site where you can find a replacement battery for your laptop:
http://www.sparepartswarehouse.com/Toshiba,Laptop,Parts.aspx
Posted on Nov 16, 2009
M PSA10A-OY75MP SAT A10 SYT UNI CORRECT BATTERY MOD NO PA3284U-1BAS ?because battery says 10-8v 3600mAh charge pack says 15v~5a
I didn't understand fully but it is not unusual for a laptop battery to have a different voltage to the charger. My laptop battery says 11.1V 56Wh but my charger says 19.5V @ 4.62A. As long as you have the correct battery replacement part and correct charger everything will be fine.
May 11, 2014 | Computers & Internet
Is it ok to replace PA3534U 1BRS with PA3534U 1BAS
The power specs are a bit different, use what your laptop originally has in it. Beware of inexpensive replacement batteries. At best, they don't work well, at worst, they COULD be a fire hazard. Use a genuine Toshiba replacement battery. You will be glad in the end.
May 26, 2013 | Computers & Internet
Is it ok to replace PA3534U-1BRS with PA3534U-1BAS
Use what was originally in your Laptop. A genuine Toshiba replacement.
May 26, 2013 | Axiom Memory FOR TOSHIBA PA3534U1BRS
IT CAN NOT BE CHARGED OVER 70 %
Some batteries have a reset button on them. If it doesn't then the battery needs replacing. Most only are good for a couple years then stop charging properly, if at all.
Aug 09, 2011 | Toshiba Battery (A105BATTERYBT9C) for...
When I go to use wi-fi, it keeps saying wi-fi is disabled. Yet, other laptops in the house work off the wi-fi
Do not expose the <a href="http://www.laptopsbatterysupplier.com/4200mah-replacement-laptop-battery-for-a1280-p-2055.html?cPath=9_2163">apple A1280 battery</a> to high heat or freezing temperatures. Do not leave your <a href="http://www.laptopsbatterysupplier.com/4600mah-replacement-laptop-battery-for-a1281-p-2061.html?cPath=9_2202">apple A1281 battery</a>in your car in the summer. Hot <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps8-c-32_2062.html">Sony BPS8 battery</a> discharge very quickly, and cold ones can't create as much power. 6. Fully charge new <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps9-c-32_2063.html">Sony BPS9 battery</a> packs before use. New pack needs to be fully charged and discharged (cycled) a few times before it can condition to full capacity. 7. For laptops that work as Desktop Replacement, the <a href="http://www.laptopsbatterysupplier.com/toshiba-laptop-battery-pa3534u1bas-c-447_1843.html">Toshiba PA3534U-1BAS battery</a> should be re -installed every 3-4 weeks and allowed to fully discharge. 8. Leaving the <a href=" http://www.laptopsbatterysupplier.com/4400mah-replacement-laptop-battery-for-gateway-nv52-p-1904.html?cPath=35_2094">Gateway Nv52 battery</a> in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
Aug 01, 2011 | Acer Tablets & eReaders
My notebook stopped charging the battery, I tryed other batteries but the problem is on the notebook. It works as the battery is being charge but the charge meter does not goes up only goes down when...
The problem is with the battery, the battery is been shorted, perhaps, due to power surge, the problem is not with the charger, to confirm this, if you remove the battery and plug in the charger to your notebook, you will see that it will still work, all you need do now is to get a replacement battery, because there is nothing you can do other than getting a new battery. Once you fix the battery, the problem is fix.
May 21, 2011 | TechFuel® 6 Cell, Battery (SATUMT577) for...
Http://www.batterylaptoppower.com/toshiba/pa3537u-1bas.htm Shorter battery life notebook, notebook battery can not be used, laptop battery suddenly power...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Aug 25, 2010 | Dell Inspiron 2200 Notebook
Toshiba Satellite M35-S456 Notebook Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
