Question about Grohe Shower Movario 28 443 Chrome Champagne hand shower
I have a movatio shower head with a grohe allure diverter and a grohe tur spout. The tub spout drips after the water is shut off. help
  • 317 Answers
Not the shower head ..its the hot and cold handles...
Posted on Nov 17, 2009
American standard single handle shower vavle drips when tub spout is on.
Be sure to pull the plunger all the way up when diverting the water between the the tub and shower if ti keeps giving you a problem it's faulty
Mar 05, 2016 | American Standard Home
Why is there Rust from tub spout and shower head
When you turn off faucets other than your tub or shower you will note that the water stops fairly abruptly. Not so with a shower head or tub spout. Some water always dribbles out even after you have turned it off. This small amount of water then evaporates leaving behind the iron that was dissolved in your water. This also happens if any faucet has a slow drip. There are products that will easily remove the rust stains. CLR, Iron Out, or Iron Ike are all good products that will remove the stain. Available at hardware stores, plumbing supply houses, and, ugh, Home Depot or Lowes. Please support your local business owners by purchasing there.
Aug 06, 2014 | Grohe Home
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
Kohler rite temp with diverter. When the tub is turned on water leaks out the shower head. Changed the diverter didn't fix problem.
You could have a restriction in the tub spout or just too much pressure. Diverter only restricts flow to tub spout so any restrictions to the tub spout will cause water to go up to shower head.
May 13, 2011 | Kohler K-T396-4-BRZ Devonshire Single...
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Mar 26, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
    Diverter valve does not work correctly.
    the connections are reversed,just change them over and this will fix the problem.
    Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
    Dripping shower head
    If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
    Jan 25, 2009 | Grohe Aquatower 3000 Shower Tower...
    Grohe shower assembly leaking
    hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
    Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
    Rectification work replace seals/repair leak...replace diverter valve assembly.
    Kindly
    Richie (UK)
    Dec 17, 2008 | Grohe Home
    Ghroe Seabury 25502 roman tub filler leaking at liftrod control
    It can be repaired.
    You can see an exploded diagram here
    I can post more if you need more specific instructions.
    Nov 22, 2008 | Grohe 19.045.000 Seabury Thermostatic...
    Grohe Shower Movario 28 443 Chrome Champagne hand shower Logo
    483 people viewed this question
    Top Grohe Home Experts
    Mike
    Donni Steen
    Are you a Grohe Home Expert? Answer questions, earn points and help others
