Question about Canon Office Equipment & Supplies
My canon 17oo pixma wont recognise the 40 black
My canon 17oo pixma wont recognise the 40 black ink instal
    President:
  • 414 Answers
Did u changed / replaced the cartridge with original spare or refilled it??
do not panic..this kind of problem often follows with (esp. an unbranded) cartridge change and or refilling..!!
it also can be the defective cartridge itself causing such problem..!!
well if u r a professional then just dip a cotton into isopropyl alcohol n gently rub the connector sensor/ contact surface, n reinsert it properly, gently rub on the head too n make sure ink is coming/flowing, make sure the toner is not jammed or dried up, also have a glance on the 'carriage' n see that no sensor pins are broken and or bend..!!
..if u r not an professional, make sure it is properly inserted and the ink-spill protective/head covering is removed....
if all the above fails, then it may b a defective or demo cartridge..!!
and call ur system admin....
Posted on Nov 16, 2009
I am having the problem with my black ink cartridge, because the printer Canon PIXMA 160 does not recognises the black ink cartridge PG 40. Could you, please, help me?
it is maybe that you refilled it too many times, you can buy a new cartridge or think about buying a new printer because pg40 cartridges are expensives and at the price of 2cartridges you can have a new printer
Apr 21, 2012 | Canon Office Equipment & Supplies
Both lights on printer flashing
If you set to black and wite it should also print pictures by the way, it does not accept grayscale because it won't be able to print in grayscale photo quality.
Aug 20, 2008 | Canon PIXMA iP1600 Printer
My canon pixma iP 1800 does not recognise refilled colour cartridge. Can you suggest a fix?
  1. For the not-so-tech friendly, installing ink cartridges in printers can be messy and time-consuming. Although companies such as Canon are constantly trying to make designs more convenient for all users, there are still several tips that can help new printer owners install Canon PG-40 printer cartridges without mess or hassle.
  2. Compatibility
  3. Although many printer cartridges are specific to only a few models, the Canon PG-40 printer cartridge was designed for use with many models of the Canon Pixma and even some of the Canon fax machines. As of September 2010, the Canon PG-40 ink cartridge can be used with the Pixma iP1600 through iP1800 printers, the iP2600 printer, the MP140 through MP190 printers, the MP210 printer, the MP460 and 470 printers, the MX300 and MX310 printers and the JX200 and JX210P fax machines. This versatility allows users to stick with the same type of ink cartridge over the life of several printers and allows small business offices an opportunity to buy one type of cartridge for all office printing requirements.
  4. Refill
  5. Replacing printer cartridges can be expensive and, if it is possible, as it is with the Canon PG-40, refilling is a cheaper and more environmentally friendly option. Refill the PG-40 by gathering a 10 cubic centimeter syringe with a 1.5-inch needle, a pair of latex free gloves, an MIS Yellow Drill Tool, Scotch tape and black ink. Remove the label from the top of the cartridge and use the yellow drill tool to open the vent hole that was covered by the label. Next, load the syringe with 20 CCs of black ink and inject it into the ink hole (where ink leaves the cartridge for the page.) Make sure the needle reaches the bottom of the ink tank and then slowly inject the ink into the cartridge, stopping when the ink begins to well up at the needle insertion point. Now remove the needle and clean the top of the cartridge off to avoid color contamination. Put a small strip of Scotch tape over the vent hole and poke a small hole in the tape with a pin. Now reinsert the cartridge and run up to three cleaning cycles to calibrate the printer.
  6. Resetting the Ink Level
  7. While refilling ink in a PG-40 can save money, it can also cause difficulties when using the automatic ink level sensor. Reset this sensor by removing the cartridge after the printer has been calibrated and placing a thin strip of Scotch tape on the line of gold-colored leads nearest the ink hole on the bottom of the ink cartridge. Replace the cartridge and wait for the computer to display a warning about the ink cartridge being loaded incorrectly. Remove the cartridge and move the tape from the first to the second level of leads and replace the cartridge. When the PC displays a message that the cartridge is not recognized, remove the cartridge and replace without the tape. The ink level will be reset.
Jan 09, 2011 | Office Equipment & Supplies
Ink cartridge
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-7
May 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Mp145 ink
Canon PG-40 Black
High Capacity Canon PG-40 Black Ink Cartridge
Pixma Series: iP1600/ iP1700/ iP1800/ iP1180/ iP1200/ iP1300/ iP1880/ iP2200/ iP2500/ iP2580/ iP2600/ MP150/ MP160/ MP170/ MP180/ MP450/ MP460/ MP470/ MP470SE/ MP140/ >>>>MP145<<<<
MP210/ MX300/ MX308/ MX310/ MX318/ iP6310D
Canon CL-41 Color
High Capacity Canon CL-41 COLOR Ink Cartridge
Pixma Series:
Jan 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Compatibility of Ink cartidge.
The MP600 does not use the 40 or 41 cartridges, it uses individual color (and black) ink tanks. But other models (MP190, MP460, MP470, etc) do use these cartridges. The error message you are receiving indicates that the printer does not recognize the cartridge you installed as a valid black ink cartridge. This can mean that either the cartridge is faulty, or that the printer has a problem.
I would suggest trying another new cartridge, and if you still get the same error, to contact Canon for support options if the unit is still in warranty.
Oct 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Ink cartage
This printer will take either the PG-30 or PG-40 (larger size) cartridges for black ink, and either the CL-31 or CL-41 (larger size) cartridges for color ink.
Jul 26, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP510 wont recognise cartridges
Using replacement cartridges that come without a chip seems to be the problem I had with the Canon Pixma 510 printer they are cheaper
but if they do not show the ink levels then its inconvienent so I have but Canon products with a chip and they work perfectly.
Nov 11, 2007 | Canon PIXMA MP510 All-In-One InkJet...
57 people viewed this question
old marine
old marine
