Question about Dishwashers
Dry dish washing
My Kitchen Aid dishwasher has a problem of not having any water. This has happened a couple of times before but did not stay that way. It is a few years old, around 10 or so I estimate it to be.The model number is KVD123HBO , the V could be a U and the O could be a D in this number. I
    President:
  • 1,314 Answers
Remove your lower kick plate inside the dishwasher you will see a safety float under that safety float is a micro switch make sure the actuator rod from the safety float is depressing the micro switch and that the micro switch is good if that's good then replace the water valve where the water line comes in
Posted on Jan 09, 2008
How do I turn up the heat to remove most condensation after washing?
As part of the current ecological, energy-saving, environmentalist-wacko movement, dishwasher makers have cut back on the heating used to dry dishes. In fact in many dishwasher designs, they have eliminated the drying vent altogether, and instead use a condensate or condensation-drying system. In this system, the last rinse cycle is heated to a high temperature, to heat the dishes. The water is then pumped out, and the dishwasher shuts down. The theory is that water will evaporate off the hot dishes, condense on the sides of the dishwasher, and run back down into the sump area. Bosch was one of the first diswashers to do this, and it works fairly well for them. Other manufacturers have tried this, with varying results. Here's what you can do to improve drying:
1. It is imperative that you use rinse-aid (Jet-Dry). This allows more water to flow off the dishes and what flows off does not need to evaporate.
2. If the dishwasher has the options, turn on high-temperature wash and sani-rinse. This gets the dishes hotter for better evaporation.
It is possible that the heater may not be working at all, and that will cause poor washing performance and no drying. This is very rare in dishwashers less than 3 years old. Most likely, poor drying in a new dishwasher is caused because you are not using rinse-aid.
Sep 21, 2014 | Whirlpool Dishwashers
Dishes not dry after wash cycle
Hello uno203 - Hi - If the unit is not drying nor cleaning properly, there are two main things to check first. Is the incoming water temperature at least 120F (49C)? If not, I strongly suggest that the temperature be adjusted on your water heater. Are you using rinse aid? Use a rinse agent to increase drying performance and using Sanitize or Air Dry Off mode also helps improve drying. If any proves to be ineffective, contact a professional to move forward accurately. Unit may have an issue with the heating element or a communication problem with the board not responding.
Nov 12, 2012 | Electrolux 24 in. EDW5505EPS Stainless...
Dishes are not always dry, even after sitting overnight
hi
make sure you are using rinse aid as this helps to evaporate the water at the end of the cycle in the drying stage. I know tablets have rinse aid built into the tablet but this can wash away on some wash cycles and do nothing so even if you are using tablets i reccommend still using rinse aid.
Jan 24, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishes dont get washed soap left on door something not right
Soundl like you're not getting water going into the dishwasher. Check out the water inlet valve.
Nov 19, 2009 | Whirlpool Dishwashers
When the wash cycle is done, the dishes are wet
It seems that the newer dishwashers are worse at drying dishes than their tupperware melting predecessors were. They have all been tuned down, and do dry less. The only thing that you can do is to set your machine for the hottest wash, power dry and use a rinse agent that provides a sheeting action. Some folks use white vinegar as a supplement to their rinse aid, which has the added bonus of killing mold. Water also stays attached if the water has laid down minerals as noted by cloudy glassware. If this is the case, a dishwasher filter (dishwasherfilter.com, $70) might help. We try to wash hot, with a power dry and use a rinse aid/vinegar. Then, when the cycle is complete, but the dishes are still hot, we open the dishwasher, and "jiggle" the racks to get the excess water off of the glasses, and leave the dishwasher open about 2" at the top, so the dishes will continue to air dry. This has been an effective method for us.
Best regards, --W/D--
Aug 03, 2009 | Siemens Dishwashers
Our Whirlpool KUDP01ILBS2 dishwasher isn't working like it used to. Dishes seem to be getting partially clean, they aren't getting dry at all and it seems they may be being rinsed/washed with dirty...
Heat that is retained in the dishes is largely responsible for drying in this dishwasher. Since plastics do not retain heat very well, they will not dry as well as glasses, ceramics or metal dishes. Rinse aid must be used so that the final rinse water will sheen off of the dishes to accommodate this drying process. The heater element at the bottom of the tub is used to add heat during the drying cycle to aid in this process as well. This model of dishwasher does not have any forced air circulation system. Here are some tips that may help you resolve your drying problem:
  • Make sure that you are using rinse aid. Failure to properly use rinse aid can prevent proper drying. Adjust the amount that is dispensed if necessary. Also, check to make sure that rinse aid level decreases over time indicating that it is being dispensed properly.
  • The NORMAL WASH and POT & PANS cycles heat the final rinse water up to 140 degrees F. Use these cycles to help the drying process.
  • Do not choose the air dry option. This option cuts off the heater element during the drying process. NOTE: The heater element is not turned on during the first 6 minutes of the drying portion of the cycle.
  • Do not overload the dishwasher. Load the dishes to allow for proper water drainage.
This dishwasher has a heater fault detection circuit. If the heater is not working, the control will detect the lack of increase in water temperature. The dishwasher will stop and the CLEAN light will blink seven times repeatedly. The dishwasher would not be able to be used until the problem is corrected and the control is reset.
Feb 10, 2009 | Dishwashers
Doesnt dry dishes
The heater on this unit only comes on twice, once in the wash cycle, and again in the Sanitary rinse. During the drying cycle all that happens is a vent opens and a fan comes on. The fan removes the hot moist air from the unit and the dishes dry off. If your water is not hot enough, this is why your dishes are still wet. Rinse aid also helps to sheen off the excess water as well.
Sgt 48
May 06, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Rinse aid used very fast and dishes not drying
Look for a blue or green streak on the door panel when you upen it to load the dishes. Does the washer sound different during the wash than it used to? If so your dispenser is leaking. This will also cause the water to suds up and not wash as well as it should. Start the washer with no detergent or dishes and let it run for 5 minutes, then open the door and see if there are a lot of suds in the water. Post back to let me know what you find.
Oct 20, 2007 | Whirlpool 24 in. ADP5966 Free-standing...
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
111 people viewed this question
Top Dishwashers Experts
