Question about ASUS P4GE-MX Motherboard
I want to disable chasis intrusion switch. Beacuse mother board perfectily well out side cabinet ,but does not boot after fitting inside cabinet
    President:
  • 414 Answers
Ok do it only if u r a professional..'
refer to the extreme right-hand-bottom [as ur back panel to the left n cpu to the top] of u r mother/main board..in here there is a 3-pin jumper named 'CHASSIS'..place a jumper or set it to pin-2-3 [the middle n right pins respectively]..
hope it'll work..for reference :
http://www.filefront.com/4169747/P4GE-MX-Users-manual-for-English-Version-E1862/
always better to seek professional advice of ur system admin/vendor....
Posted on Nov 16, 2009
The problem of my computer is when i open my computer its not boot to windows it shows chassis intruded fatal error-system halted! what can i do to solve that problem? my board is asus p5sd2-vm.
chasis intrusion is an option in the bios, when U start the pc, press dell to go into the bios, walk trhough the settings ( I think it will be in a section advanced or security) where U can switch off intrusion.
Did U open the case recently?
Jun 16, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
When i open computer this massge fatal error chasis intruded
Your PC has a chasis intrusion detection chip installed.
This is common with most business class PC's.
Simply replacing the cover or defeating the chasis intrusion switch will remove the problem. Most people tape the button down if they leave their cases open.
Aug 30, 2010 | Computers & Internet
I am getting the fatal error chasis intruded error on every boot...motherboard model is p5sd2vm...rahul
Chassis intrusion can be disabled one of two ways.
First, Check your bios settings. There should be a security or PC health section where you can clear that error and disable the intrusion warning.
Second, there is likely a small switch near the chassis side when the side panel is removed. This is the chassis intrusion switch. It will likely lead to a 2 or 3-pin connection on the motherboard. this can be disconected without any ill effects.
Aug 13, 2010 | Computers & Internet
Chassis Intruded
try take out the battery on board for one min. then put in battery see if that works jim
Feb 16, 2010 | ASUS K8N Motherboard
I have a Asus P5VD2-VM SE and when i boot my pc this show me a message Chasis intruded System Halted someone can help to solve this problem
You will need to go into your system BIOS and disable the Chassis Intrusion Sensor. BIOS is accessed by pressing the "del" key during the initial POST screen (or when giant Asus logo is on the screen) .
Look through there and located and disable the chassis intrusion sensor. If you can't find it, reference your manual for the board. If you don't have one, one can be downloaded in PDF format from the Asus website.
Be careful when in the BIOS, changing anything to an incorrect value could render your system useless! Don't play with anything, unless you explicitly know what you are doing, and what the setting does...
Be sure to "Save and Exit" in order foe the changes to stick.
Dec 18, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
HP D530 SFF CHASIS FAN NOT DETECTED
tell me the wright way to remove 512 chassis fan error i am very depressed on this
Mar 17, 2009 | HP Compaq d530 SFF PC Desktop
Asus k8s mx mother board problem
To get rid of this message at boot you must turn off the Chassis Intrusion detector feature. To do this you must restart the computer, as it boots press DEL to enter BIOS.
Under the SECURITY tab in BIOS select CHASSIS INTRUSION and select DISABLE.
Then select EXIT and SAVE CHANGES and OK to reboot the system.
Jan 31, 2009 | ASUS K8S-MX Motherboard
Error Boot "Chasis Intruded fatal Error System Halted"
Well it seems like that the cmos battery is down. You need to do the following
Change the CMOS battery,
Enter into bios and change the date and time properly,
Save and exit bios.
Now you should be able start your computer in windows.
Nov 26, 2008 | ASUS P5P800S Motherboard
Mother board driver issues
Don't panic. If you take the cover off the side of the computer and look at the motherboard you will find a jumper that says cmos. You can switch the jumper and wait a minute or so then switch it back and it will boot up its defaults. If you cant find the jumper just take the battery out of the motherboard and wait a couple minutes and then put it back in. that will do the same thing and it should boot up fine.
Mar 02, 2008 | Intel Motherboard
Asus Board MOdel Number P4BGL (845 Mxl) is giving an error called Chasis opened or tampered.?
I read a solution of your problems, i did not ry this. But i want you to try in your motherboard: this was qoute by
" 9. anonobomber, 07-05-2002 09:51 read the manual from your motherboard, I'll quote it for you; Chassis Intrusion Lead (4-1 pin CHASSIS) This requires an external detection mechanism such as a chassis intrusion monitor/microswitch. The sensor is triggered when a high level signal is sent to the Chassis Signal Lead, which occurs when a panel or light detector is triggered. This function works with an optional ASUS CIDB chassis intrusion module (see your vendor for more details). If the chassis intrusion lead is not used, a jumper cap must be placed over the pins to close the circuit.
pinout 1[+5volt] [power supply standby] [chassis signal] [ground]
in order to supress the messages you are getting you will need to get a jumper to fit over the chassis signal and ground to bypass the chassis intrusion detection circuit.
This has nothing to do with resetting the CMOS. For board specific locations of the pins check http://www.asus.com.tw for the manual pertaining to your motherboard"
Jan 21, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
ASUS P4GE-MX Motherboard Logo
201 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
