Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Macbook frozen with question mark folder blinking
You either have a severely corrupted directory, or a physical hard drive failure. For the former, boot to your Restore CD and Repair Permissions, failing that, Disk Warrior. For the later, replace the hard drive with a new one
Posted on Nov 16, 2009
  • 143 Answers
SOURCE: blank screen with blinking folder
This is a sign that the startup disk can't be found.
When you power on the computer, try holding down the "alt" key or "option" key on your keyboard.
Then after a while, it should ask you to select the location of the operating system. Select your macintosh HD. Everything should load as normal.
If this doesn't work, insert the install cd's and hold down "c" instead. This will load the cd with mac os x on it. You can then install the operating system. Please make sure you have backups. Unless the option to simply upgrade or repair your mac pops up, you will loose your files following this method.
Nathan.
Posted on Apr 14, 2009
kklare
  • 85 Answers
SOURCE: My macbook won't go to the login menu. It gives a
You have a disk/file system problem. Use your system install disk and in Dish Utility, repair and when OK, fix permissions. Do this after each install--can usually just use DU and verify+fix. If you must, then boot in Target mode (hold T on boot) and connect to another Mac, Use Firewire, if can, else may need to remove disk and put in external. If no fix, then will need re-install.
Posted on Jul 13, 2009
SOURCE: when i turn my macbook on it just stays on the
. Your mac has lost its operating system !!! reload and start computing
Posted on Oct 28, 2009
  • 846 Answers
SOURCE: my macbook is frozen with the folder icon showing
Looks like you need to replace the HDD. An alternative way is always try to repair it yourself. There are Mac Repair Guidesthat show how to open an Macbook. Watch out for the ribbon cables,those tear easily. Replacement parts are usually available on Ebay.There are third party services that can do it for you, like Mac Repair NYC.
Posted on Dec 27, 2009
damien729
  • 221 Answers
SOURCE: My MacBook OSX will not
Hello
That looks like your Mac does not see the System folder, for multiple reasons:
- Your hard drive needs repair / change- Your system files have bad permissions or are missing (to check this, disk utility in the Utilities folder cane good help)- Your hard drive has been erased or partitioned.
Hope that helps
Posted on Sep 27, 2011
Why does a question mark on a folder blink at startup and not turn on laptop?
Hi Joe. It means that the start-up drive has some corruption of some sort. I've posted previously what to do in such situations so just search for flashing question mark and there's a walkthrough of possible fixes.
Mar 27, 2012 | Apple MACBOOK PRO 13 INCH NOTEBOOK 24 GHz...
My MacBook OSX will not open and I keep getting a file shaped folder with a question mark blinking?
Hello
Hope that helps
Sep 22, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Dropped my notebook and now it won't boot up. It shows a blinking folder with a question mark.
the hard drive is busted.
a folder with ? means it can't read or detect the hard drive.
you will need to purchase a new hard drive and reinstall osx on it.
unfortunately the data is prolly gone as well.
Apr 10, 2011 | Apple MacBook Mac Notebook
Won't turn on
The problem in blank white screen is the display (LCD). Send it to a technician for repair. The blinking folder with a question mark is conflict on drivers. Have you installed a software lately? If you do please uninstall it. Maybe that is the cause of having a blank white screen.
Jul 12, 2010 | Apple MacBook Pro PC Notebook
My macbook is frozen with the folder icon showing on a blank screen with a question mark on it? Help
It sounds like your MacBook can not find the system software to boot up. This is often a sign of a hard drive going bad. Try booting from the CD/DVD that came with your MacBook and running Disk Utility.
You can also refer to this article:
http://support.apple.com/kb/TS1440?viewlocale=en_US
I hope this helps.
Nov 16, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Jul 13, 2009 | Apple Customized 13 MacBook Notebook...
Blinking file folder with question mark and a DVD is stuck in it
Hello, The blinking file folder with the question mark can happen when the computer doesn't "see" your System. It can be caused by a faulty hard drive, or by a damaged operating system. You can try to reboot the mac, hold the mouse button during 20 seconds to eject the CD, then insert you installation DVD (leopard). Reboot the Mac again, and hold the "C" key. Select english, the go to the tools menu, and Disk Utility. Go to the SOS tab, select your drive and click "repair". If something red appears, it means that it has found something wrong on your hard drive. Best regards
Jun 10, 2009 | Apple MacBook Mac Notebook
Question Mark folder in my mac notebook
hey if you have the Utilities disk or any Mac OS install disk, place that in the computer, restart and hold down the c key.
That prompts the computer to boot from the cd.  If it gets past the question mark folder, then we are making progress.
At this point exit out of the installer, (unless you want to do a new install)  look through the top menus, to find the utilities options that will allow you to run a diagnostic and repair.  That should get you on the right path.
Let me know if this gets you back up again.
I do have some other steps that may also work if the problem persist.
Have a great one!
enov8  = )
Mar 05, 2009 | Apple MacBook Laptop Computer Mac...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
26 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
