Question about Logitech X-540 Computer Speakers
How do i connect logitic speakers to my television
    Problem Solver:
  • 7 Answers
Either use your t.v.'s white and red (if avaliable) outputs and run them to the inputs on your receiver or if your t.v. doesn't have inputs run your cable through a vcr and run the vcr to the surround sound receiver.
Posted on Nov 16, 2009
I was watchin Tv and the sound just went out. If I turn the tv up all the way I can here a humming noise...
Sounds like the speakers are blown.
Your only choice now is to connect external speakers to the TV or to purchase a new television. The speakers built into TVs are generally low quality 10 Watt speakers, it is always recommended to connect external speakers to a flat panel television.
Mar 11, 2011 | Televison & Video
No audio,tried menu items and selections,nothing.The sound just went out,what do you think it might be?
There is no sound or low volume coming from the television speakers.
Solution Follow this procedure to troubleshoot when there is no sound or low volume coming from the television.
NOTE: Because each of these steps represents a possible solution to this issue, check the television status after completing each step.
Increase the volume of the television. Ensure the television audio has not been muted. Ensure no headphones are not connected to the television. If using a set-top box with a volume control, increase the volume of the set-top box.
NOTE: If the set-top box is connected using an Audio/Video (A/V) connection, ensure that the A/V cables are connected securely to the appropriate video input on the television.
Verify that the MTS settings of the television are set to MAIN or STEREO .
NOTE: If the source device is not set to stereo or is not capable of transmitting a stereo signal, sound may come from one speaker on the TV only, and the volume will sound low. In this case, adjust or replace the source device.
If the TV has a Simulated effect in the audio menu, turn it off . Ensure the televisions speakers are not set as the center speaker.
NOTE: Some televisions allow the televisions speakers to act as the center channel speaker when using a multi-channel receiver.
Verify that the speakers are set to ON in the television menu.
IMPORTANT: If the television has audio output jacks and they are connected to a stereo system, then the speakers on the television may be turned off. Some televisions require the internal speakers or the center speaker setting to be off before audio can be sent out to a stereo receiver via the audio out jacks.
Ensure all audio and video cable connections are properly connected to the television.
Test the television using another source like a VCR, DVD player or Blu-ray Disc™ (BD) player.
Reset the television to the original factory settings. To reset your TV to factory settings, turn the TV ON. Then, while pressing the UP ARROW button on the Remote Control, press the POWER button on the TV. The TV will turn itself OFF then back ON.
NOTE: If your remote control does not have a RESET button or the procedure did not reset the TV to the factory default settings, perform a power reset.
If the issue is still unresolved after completing all the troubleshooting steps suggested, service may be required.
Jan 30, 2011 | Sony FD Trinitron WEGA KV-36FV27 36" TV
I have loaded my logitic camera but can not make or receive a call on g mail
Greetings-
I had the same problem with my camera. Go to googles help section for you account there is a applaction to download from google that will setup your camera to work with GTalk.
I hope this helps
Dec 14, 2010 | Logitech QuickCam Pro 5000 Webcam
MY LOGITIC MOUSE NEDS NEW PADS ON THE BOTTOM OF IT .CAN YOU BUY NEW ONES? ONE OF THE PADS IS MISSING CAN YOU REPLACE THEM?
THERE IS NO NEED TO REPLACE PADS MOUSE WORKS WITHOUT PADS. YOU MAY INSTEAD OF IT USE SEPARATE MOUSE PAD AVAILABLE IN MAY SHAPES/DESIGNS
Aug 16, 2010 | Logitech Cordless Mouse
I want to connect 2 speakers(left and right) to lcd.how can i?
Please follow the steps below:
Step 1: Connect the two RCA plugs on the Y adapter to the right and left Audio Out jacks on the back of the LCD TV.
Step 2: Insert the mini-plug on the cable attached to the right-channel PC speaker into the mini-plug jack on the Y adapter.
Step 3:Connect the mini-plug on the audio cable attached to the left-channel PC speaker to the mini-plug jack on the back of the right-channel speaker. This completes the PC speaker connections to each other and to the television. The TV sends an audio signal to the right PC speaker, which separates the signal and sends the left-channel stereo information to the other PC speaker.
Step 4:Connect the AC power plug to the back of the right-channel speaker and plug the other end into an electrical outlet.
Step 5:Switch on the speakers and the television to enjoy audio from both the TV's built-in speakers and the external pair of PC speakers.
Regards
BEADHZ
Dec 30, 2009 | LG 37LC7D 37 in. LCD HDTV
Screen goes solid blue - no commands - battery is fully charged
You might try to to go to Logitic.com and re-program your remote. You have to register to use their set-up program/ They have a fairly easy way to set it up. You will need to have the remote connected to your computer with a USB cable when you start. http://www.logitech.com/index.cfm/440/3865&hub=1&cl=us,en
Oct 26, 2009 | Logitech Harmony 890 LCD Remote Control
Connecting speakers.
The speakers cannot be connected directly to the audio outputs. These outputs are for use with an external amplifier. Connecting speakers directly to these audio outputs can cause damage to the set. Thanks
Oct 24, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Trying to connect bose speakers to my insignia flat screen tv?
this can be done with a receiver hook-up. The speaker are connected to the receiver and the television is also connected to the receive input circuits. This should be explained in the owners manual of the television and the receiver. Another way to connect the speakers is to have a preamplifier and a amplifier. Where the speakers are connected to the amplifier and the television is connected to the preamplifier. The preamplifier output is connected to the amplifier input. This all also should be explained in the owners manuals of the products.It is important to read these manuals to find the correct connection methods and correct cables to use for the connections. If you still cannot do the connections , Then call customer service for the devises to get help with the procedures. Hope this helps you with your problem.
Mar 28, 2009 | Insignia LCDTV26 26 in. Television
Center speaker no longer works
Wiggle the connection that the center one is plugged to. It starts static or playing then the internal connection is broke loose from the solder joint.
Plug another speaker to that connection. If it plays then the speaker is blown.
Feb 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Logitech Access Keyboard problem
Typeing with the Logit. keyboard shows no letters on my Gateway screen. Changed batteries. Arrow works appropriately, but no letters seenon the Gateway scree.
Nov 25, 2007 | Logitech Deluxe Access Keyboard
Logitech X-540 Computer Speakers Logo
155 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
