Hello my monitor is not showing up on my computer and I have to use my television to send this request. I even went to displays and I only see my television and not the monitor. I try to wake up the monitor but it says before it goes back to sleep mode that it is not getting a signal. I tried everything unhooking my computer and shutting it down but that did not work. I have a Dell computer and flat screen monitor. Can you help?
  • 380 Answers
Some dell monitors have dual input; thats VGA and DVI. Make sure the input you are using is what you have selected, and that the cables are secured to the pc and monitor.
Also, make sure your video card driver has support for dual output. You may need to contact the manufacturer of the video card and get a newer driver, and update your direct x stuff as well. If the card has support for multiple outputs, but you cannot detect them, it is MOST likely the driver, but check your cable connections as mentioned earlier, just to be sure.
Posted on Nov 16, 2009
Display are not showing cleanless
Try connecting an external monitor to the computer and see if it displays better. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your video card inside the computer is good, but your lcd screen is bad. If the Borrowed monitor displays the same way with problems, then your video card inside the computer is bad.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
Jun 09, 2012 | Lenovo G555 Laptop
Hi, I have two monitors and was playing with the display in preferences and my apple monitor went blank-black and I can't get it to work
Hi thirdeye6j93,
Thanks for your question at Fixya,
Please find the solution to your problem as follows :-
  • Please make sure that when you click on the display preferences and select displays option , you will need to go in arrangement option and then follow the instructions that you see.
  • To play a DVD on a television connected to your computer, click the Arrangement button in Displays preferences and move the menu bar to the television.
  • If you don't see that Arrangement button, then it means that your computer is only capable of mirroring (showing the same image on all screens).
Hope this helps ...:) In case you have any queries , feel free to contact me.
Sep 25, 2011 | Apple M7720LL Monitor
My Viewsonic VG2021m Monitor recently cut out every 5 or so seconds (the display came up and then went off) again and again and now it seems as though i cant turn it on at all even though the blue on light...
The intermittent image, dark picture or no power are all indications of a failing power supply. If you can solder you should be able to repair your monitor. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ The post is about repairing the Westinghouse LCM-20V5 but they both use the same power supply board, the Delta DAC-12M033 so the information is the same. If you don't want to do the repair yourself we do offer a repair service for this model for $32 plus return shipping. More information on this service can be found here. http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this information helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Sep 19, 2010 | ViewSonic VG2021m LCD Monitor
I have a compaq presario c500, i have connected my s video cord from my laptop to my tv and yet nothing shows up on the tv even if i go to display properties and try to add a monitor
The problem probably lies in the fact that you have not told the computer to send the display to another device. This is done through a combo of keystrokes--using the Fn key with the special function key that shows a monitor (or two monitors) on it.
If you hit that combo, it will cycle through the attached displays.
Jul 29, 2010 | Computers & Internet
Monitor has very slow turn on time, about 5 minutes, even when computer is on and in sleep mode, when you hit a key it takes about 5 minutes for monitor to fire uo
The usual cause of the slow display start up is the power supply. When you turn the monitor on or wake it from power save the power supply starts up but if it does not get stable voltages then it will not display a picture until they do stabilize. When the power supply starts to fail you can get this type of symptom. Other indications of failing power supplies include blinking power lights, fuzzy or wavy display or even a high pitched sound coming from the back of your monitor. If you cab solder then you should be able to do the repair yourself. We have a step by step repair article posted on our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/ Look it over and see if this is something you can do, if you don't want to do the repair yourself we do offer a repair service. Here is the link to request a service number on your monitor, http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this information is helpful, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Mar 23, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
How do I reset my Westinghouse L2046NV monitor -- this monitor will turn on and light up and the picture will come on but then go off after 1 or 2 seconds -- any ideas ?
Hello, reseting your monitor will not solve the problem, what you need to do is replace the inverter board, if you would like to know price and availability for this model please send a request to parts@wde.com, they will let you know if they have the board, how mutch it is, and they will also troubleshoot with you over the phone at no charge to make sure that is what you need.
Dec 15, 2009 | Westinghouse L2046NV Monitor
Backlight out on Philips 200WB monitor
It sounds like the inverter is out on the power supply for the backlights. If you can open the monitor and take a few pictures of the boards and send them to tech@ccl-la.com I will try to cross reference the boards and give you a repair solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 05, 2009 | Philips 200WB7 (Silver) Monitor
Display went from extremely dark to complely black
Hello there.
I understand that your Notebook is not showing the display lights. To isolate the issue please do the following troubleshooting steps.
1) Check the display with external monitor. If the external monitor is showing the display then the problem is with the LCD screen. If the external monitor is not showing the display then the problem is with the display card.
2) If you have any torch light or a cell phone , try focusing the light on the LCD screen after the Notebook is powered on and check whether you are able to see the texts and images on the LCD. If you are able to see the images and texts then it is the problem of the LCD back-lights. The lights which glow at the back of the LCD panel are not working.
If your Notebook is under warranty HP will repair it free of cost.
Contact HP customer chat center for more information regarding the details of the repair and the procedure for sending the Notebook to HP in case of repair.
For contacting HP chat support click on this link or copy and paste it in address bar of a web browser.
http://welcome.hp.com/country/us/en/contact/chat_1.html
Feb 17, 2009 | HP Compaq Presario M2010US Notebook
Side Buttons - Not Responding (wrong input?)
These buttons can stick, when you press the buttons do they click
if not then it is stuck in.
Jan 27, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Dispaly settings for samsung 794 MG 17" CRT
can u send me the wat is in the setting menu of your monitor?
Dec 16, 2007 | Samsung 793DF 17" CRT Monitor
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
