Question about HP Pavilion Dv3-1075us Notebook
When the power button is pressed the light flashes for a few seconds and the system stops and not working. but the charge light in the side is glowing and not in the front side
  • 19 Answers
Light flashes cause battery is critical low.
Try to unplug and then plug in cord again, until front lamp lites on.
If you continue to have this problem, post and I will explain how I solved mine.
Well I had problem that sometimes after plug in or out, battery goes from 100% to 3%, I thought it was battery or adapter, but it was software. I did ask HP about it, they said they had customers with such problem.
You might have same problem.
Posted on Jan 13, 2010
  • KovaZg Jan 13, 2010
    If you get it to work, and from time to time your battery drops to 3% or so. (From 100%), you should do next:
    1. Disconnect the AC Adapter.
    2. Remove the Battery.
    3. Hold the Power button down for 30 seconds to 1 minute.
    4. Put Battery back
    5. Reconnect the AC adapter.
    6. Turn on the Notebook power.
    Then you need to perform the steps to Battery Calibrating.
    1. Plug in the AC adapter.
    2. Allow the battery to charge until the Battery Charge light turns
    off, showing that the battery is fully charged.
    3. After the Battery Charge light turns off, unplug the AC adapter.
    4. Turn on or restart your Notebook.
    NOTE: Steps 5 through 8 prevent your Notebook from entering Sleep
    mode. These steps also allow the battery to drain faster.
    5. Click Start and then Control Panel.
    6. Click the Power Options icon to display the Power Options
    Properties dialog box.
    7. Click the Power Schemes tab and select the Portable/Laptop scheme.
    8. From the Running on batteries column:
    a. In the Turn off monitor drop-down list, select Never.
    b. In the Turn off hard disks drop-down list, select Never.
    c. In the System standby drop-down list, select Never.
    d. In the System hibernates drop-down list, select Never.
    9. Let the battery drain until your Notebook reaches Hibernation and
    turns off.
    10. Plug in the AC adapter and restart your Notebook.
    11. Return to the Power Options Properties dialog box, and re-enter
    your power savings settings to the desired level.
    12. Open the Device Manager and then click '+' sign beside Battery.
    Then right click on the entries listed under it and unistall them.
    Once you uninstall the entries, restart the notebook.
    13. Run Battery Health check
    14. See if problem is solved
  • 115 Answers
Its problem with your power supply(Battary).Pls change the power supply and the start the system again it will work properly.
Posted on Nov 16, 2009
Power light flashing amber
Follow the steps given below. (Please be careful when handling computer electrical components like batteries and AC Adapters)
  • Remove the battery and hold down the power button for few seconds (to drain all remaining power)
  • Power up the computer without the battery with the A/C adapter plugged in.
  • Wait for few seconds and plug the battery back in
After a few tries the computer should start charging normally. The amber battery stops blinking and turn green when fully charged.
Feb 13, 2015 | Acer Aspire One Kav10 Netbook
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
I have an error 5200 The green light flashes and the orange alarm flashes.does not print. have tried unplugging the printer. then plugging it back in. Does not work.
This will work
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
Sep 17, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Won't turn on. On button glows green and harddrive light flashes and goes out. On button continues to glow. If I hold the on button down 5 seconds it goes out. It was working fine, I turned it off and...
*This method only applies to Aspire ONE A150 only
1) Format USB memory stick with FAT file system.
2) Download BIOS for A150
http://global-download.acer.com/GDFiles/BIOS/BIOS/BIOS_Acer_3310_A_AOA110%20&%20AOA150.zip?acerid=633850493862245097&Step1=Netbook&Step2=Aspire%20One&Step3=AOA150&OS=X01&LC=en&BC=Acer&SC=PA_7
3) Extract all files the downloaded file and place FLASHIT.EXE and BIOS file onto the memory stick
4) Rename BIOS file to ZG5IA32.FD
5) Turn netbook of, with power AND battery connected
6) Plug in memory stick with BIOS file and Flasit.exe
7) Press and hold Fn+Esc the unit will go on, hold until power LED is flashing then release keys. If it does not flash, then release and press power button once.
8) You'll notice the LED of both the usb memory stick and the power LED will flash together.
9) After a few seconds the flashing will stop and the unit will reboot or switch off completely.
^^ this is a copy paste from my own solutions
May 13, 2010 | Acer Aspire One AOA150-1570 Notebook PC
Laptop will not boot. The power light flashes
CLICK HERE
the codes which you see are universal for all the dell laptops. find the appropriate. this will solve your purpose and guide you how to go furthur.
Sep 26, 2009 | Dell Inspiron 1521 Laptop
Flashing lightning bolt on Compaq C300
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
KX-TG1000N new handset 1
For KXTG1000 only
  • The base unit must be connected to the AC adapter and the power must be on
  • Press the following sequence of buttons on the base unit: * * 3 3 5 7 8 2
  • When the display reads "Enter Base ID", deregistration has been completed successfully
  • For KXTG1050 only
  • Disconnect the AC adapter
  • Hold the Locator button down while you plug in the AC adapter
  • When the Power light flashes, release the Locator button
  • Immediately press and hold the Locator button again, and release when the In Use light flashes
  • The Charge light should flash for 4 to 6 seconds and then turn off
  • When the Charge light stops flashing, press Locator again
  • In about 20 seconds, the handsets will deregister. When the displays read "Enter Base ID", deregistration has been completed successfully.
  • Jul 15, 2008 | Panasonic KX TG1000N Cordless Phone
    Toshiba power led flashing yellow
    This flashing LED usually means only two things, both are quite harmless:
    1. Some laptops will flash the power LED when battery is charging. If this is the case, it should stop when battery is fully charged. This can be presumed if the laptop starts normally while LED flashes. If not, suspect step 2 below:
    2. Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
    Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
    Then wait. Can take 60 seconds to "wake up" on slower processors.
    If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
    Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
    If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
    good luck.
    May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
    My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
    hello!
    You will see 3 led lights on the printer. They will blink continously if:
    if the print cartridge status light is flashing
    -- check if the top cover is open, Close the top cover.
    -- there may be a problem with a print cartridge
    1. Verify that the correct print cartridges are installed.
    2. Check if a print cartridge is low on ink or improperly installed.
    if the resume light is flashing
    -- the printer may be out of paper
    1. Place paper in the In tray.
    2. Press the Resume button on the front of
    -- the printer may be ready to print the second side of a two-sided document
    1. Follow the onscreen instructions for printing the second side.
    2. Press the Resume button.
    if the power light is flashing
    -- the printer is preparing to print
    -- The light stops flashing when the printer has received all data.
    if all lights are flashing
    -- the printer may need to be restarted
    1. Press the Power button to turn off the printer, then press the Power button
    to restart the printer.Proceed to step 2 if the lights continue to flash.
    2. Press the Power button to turn off the printer.
    3. Disconnect the printer from the power source.
    4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
    May 06, 2008 | HP DeskJet 940c InkJet Printer
    HP Pavilion Dv3-1075us Notebook Logo
    342 people viewed this question
    Top HP Computers & Internet Experts
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
