Question about Canon LBP3200 Laser Printer
Laser canon lbp3200 manual paper jam problem - Canon LBP3200 Laser Printer
SOURCE: Canon MF4150 Duplex Printing Paper Jams
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
jubag14
  • 89 Answers
SOURCE: Printer prints from manual feed but not from tray.
you need ot open up the papper tray and more the laser down then it should work
please rate my helf i need you to i am a exert
Posted on Apr 20, 2009
SOURCE: Paper Jam lite is on ( no paper jam )
did you try turning it off and then back on?
Posted on May 27, 2009
  • 13433 Answers
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
digitalhubz
  • 109 Answers
SOURCE: My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Posted on Oct 21, 2009
Still no driver or any solutions for windows 7 x64bit?
Hello, you can download your driver from the canon website using this link:
Canon LBP3200 Laser Printer Win7 x64
You can download it from here as well: http://driverscollection.com/?H=LBP-3200&By=Canon
Thanks for using FixYa.
Sep 01, 2011 | Canon LBP3200 Laser Printer
I need windows 7 64 driver for canon lbp3200.
http://support-in.canon-asia.com/?business
Aug 23, 2011 | Canon LBP3200 Laser Printer
My printer keeps saying its jam but i dun find anything wrong wif it
its jammed because maybe there is a small piece of paper in the roller
Feb 28, 2011 | Canon LBP3200 Laser Printer
How to install canon lbp3200 printer driver
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :- http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Dec 01, 2010 | Canon LBP3200 Laser Printer
LBP3200 Laser Printer: crashes with printing test page...
Canon LBP3200 installed in Redhat distribution.But the document cannot print .please help me
May 18, 2010 | Canon LBP3200 Laser Printer
Paper jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | Canon LBP3200 Laser Printer
Manal feed error
There should be some snag in the pick up area of your printer.
SWITCH OFF YOUR PRINTER and UNPLUG IT.
Open the front cover. Clean the paper receiving area blow any dust present there and see if your manual feed works.
Oct 04, 2008 | Canon LBP3200 Laser Printer
Canon LBP3200 Laser Printer Logo
654 people viewed this question
old marine
old marine
