When you put the key in the ignition it will not turn.
Try to turn your stearing wheel a little it might be locked up.
Posted on Nov 16, 2009
Ignition key is locked or stiff, does not turn. What is the problem?
the lock is worn. try putting some graphite lock power in it . might free it up.
Aug 02, 2017 | Cars & Trucks
Truck will not start, wait to start warning light is out?
Please provide more information.
"I put the key in the ignition, turn it and the warning light goes out, I turn the key to start but there is nothing..." or
"I put the key in the ignition, turn it and the warning light goes out, I turn the key to start but there only a ticking/clicking sound..." or
"I put the key in the ignition, turn it and the warning light goes out, I turn the key to start but the engine only turns over and doesn't catch."
Jan 06, 2015 | Cars & Trucks
2009 Jeep Commander --- Ignition problems. For the past few weeks, roughly 75% of turning the ignition OFF from RUN, the ignition will not release the key. Need to turn ignition on and off (potentially...
Hey Anon, Is this a total electronic key,,(push button start)..if so, its an electrical issue. If its a standard key urn ignition. try some DRY graphite on the key.. it will lubricate the switch without the mess of liquids... put the key in and out several times, put some more dry graphite on the key and repeat.. give this some time to work,, if this does not improve the switch.. its time for a new switch assy,
Jun 24, 2017 | Jeep Commander Cars & Trucks
Put key in ignition and it won't turn
Your ignition is bad, or your key might be worn out if you have more then one you might try that. Other wise you will have to replace the ignition switch.
Jul 28, 2011 | 1989 Ford Thunderbird
The key does not turn at all to turn the ignition on
1. Make sure its proper ignition key.
2. Try jiggling the key as you turn it. IF this works you igniton is worn out inside.
3. Put your foot on the brake, put the car in Neutral, and try to turn the key. If this works your ignition is bad but you can get by for a while doing this. If it dosn't work you need to replace the ignition.
Feb 03, 2011 | 2001 Lexus IS 300
I have two remotes, both needs to be reprogram, how do i do that whithout take to the dealer
hi, sometimes this is easy. put key in ignition turn key to IGNITION. DO'nt START IT. leave ignition ON for 3 seconds. then turn OFF . take key OUT of IGNITION wait 3 seconds and replace ignition key turn key to ignition. this is key recognition. some cars do and some cars do'nt. try this. gerry
Sep 13, 2010 | 2001 Volvo S40
Car immobilisor
you might be able to reprogram the key, but you can only do this if you have two keys, what you need to do is put one key in the ignition turn the ignition on ( not over ) put the key that needs reprogramming into the drivers door and lock the vehicle with the key not the button, wait 10 seconds, remove the key, then press the unlock on the fobb, turn ignition off, remove key from ignition, put in the key that you just unlocked the car with and turn ignition do not turn over, turn off ignition,remove key wait 10 seconds, then put key back in then you should be able to turn it over as normal, if that does not work you will have to take key to be reprogramed at the main dealer...hope this helps
Feb 13, 2010 | 1995 Volkswagen Golf
I have a 98 dodge caravan and when i put the key
You may have to get a new key cut if the tumblers in the ignition lock are not being lined up to unlock the ignition. If the key's was bent in the ignition lock, the ignition lock may be bad and need to be replaced with a new ignition key. Try replacing the ignition key's first, but if you have a spare key. Try that first and if the spare key's don't turn the ignition lock, then you may have to replace the ignition lock. Good luck and keep me posted. oh and try moving the steering wheel left to right as you try to turn the ignition lock.
Aug 21, 2009 | 1998 Dodge Caravan
Put key in my ignition of my 2005 dodge durango and won't turn on
Disconnect the battery.. Its magnetic. The transponder has gone bad in the key. May need replacing. Unless someone tried to put the wrong key in the ignition and broke the electrical contacts inside the tumbler
Apr 01, 2017 | 2005 Dodge Durango
Key wont turn in ignition
try wiggleling the key too the tumblers may be getting worn in the ignition is this works then replace the ignition
May 10, 2009 | 1996 Oldsmobile Cutlass Supreme Coupe
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
