Question about Canon MP610 Photo All-In-One Printer
My computer says usb device not recognizide, i reinstalled the driver and it still does not work???????? its a mp600
  • 55 Answers
Check your system and data cable then installed
Posted on Nov 16, 2009
How do I fix the msi motherboard windows 7 USB error 43?
How to Fix a Code 43 Error
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
    Depending on the changes you made, some solutions might include:
  3. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a possible solution to a Code 43 error.
    Important: If a USB device is generating the Code 43 error, uninstall every deviceunder the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Properly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Sep 16, 2012 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
I have a Canon with a USB connection. Can I connect this to a Ethernet connection on my wireless router? (I had it working thru USB port of apple airport router, but new Verizon FIOS wireless router does...
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
dont forget to vote
Feb 27, 2011 | Canon PIXMA MP600 all-In-One InkJet...
MP600 MFP was working fine then recently can't be found as a USB device. Tried changing cable and USB port on the (DELL) computer and it makes no difference.
hi;
look at the USB connector located on the printer is it broken ?
light it with a torch look inside the 4 pins are they fine ?
Nov 05, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600 printer wont print
check first if printer work fine, you can test print it manually, then check if computer communicate with the printer by allowing to remove driver and insert usb cable it must be popup that found new hardware occurred for its detecting printer. reinstall back driver, restart and send print test.
Mar 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Basically bought new webcam Hercules® Webcam Deluxe, its been working fine. it crashed while on yahoo, so i removed it from usb. the programmed desided it didnt wanna respond open so i have...
It sounds like you need to check your USB controllers through Device Manager as well as reinstalling Yahoo Messenger.
1. Go to Device Manager and verify that there are no yellow exclamation marks or question marks, if there are reinstall them.
2. Test your webcam after this point because one of the USB drivers should be your webcam driver.
3. Reinstall Yahoo messenger and test it with your webcam.
By deleting drivers in Device Manager, your computer will attempt to do a reinstall only if your computer needs that driver.
Mar 22, 2010 | Computers & Internet
Will not scan
Hi ..
There could be many reason for not scanning. It could be drivers or could be the cable which is connecting your printer to your computer. If you have already tried to re-install the drivers, try and unplug the usb cable and plug it again. If that does not work, try and plug your USB cab directly to the printer and see if that work.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Scangear - scanning problems with mp600
windows XP instructions.can be easily applied to other operating systems
-turn printer/scanner on
-go to control panel
-click on system
-click on hardware
-click on device manager
-click on imaging devices
-right click on canon mp600 and choose updat driver option and then after that is done.click on scan for hardware changes
(below images provided)
this should make sure scanner work.. but if it still doesnt work then go back to the device manager and check if there are any hradwares with a yellow question mark beside them.if there is then right click on them and click update driver.
if that does not solve the problem try reinstalling the CD or go to the canon MP00 web page (google it) to dowmload the printer/scanner drivers. and repeat everything until it works or until you give up =). hope it all works out bye!
Apr 02, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Mp600 can't load drivers
Try deleting any previous drivers installed,unplug the printer USB from the computer. Restart the computer run the driver CD leave the printer unplugged then when the cd asks for the printer,power it on and connect it to the computer let it install automatically see if that helps good luck.
Nov 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
MP600 canon printer computer cannot recognise USB device
Try different USB ports on the computer to see if its a porblem with the port connection and if there's no change there then try using another USB cable that you know is working perfectly fine.
Nov 25, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP610 Photo All-In-One Printer Logo
old marine
old marine
