Question about HP Officejet 5610 All-In-One InkJet Printer
I refilled my HP74 and 75 cartridges and the printer won't accept them. What can I do
Buy correct cartridges - refills have a 70% failure rate. Check the cartridges, on them they'll have an install by date. If your past this date it will reject them.
Posted on Jan 05, 2010
Hp c4150 printer won't recognize my refilled black 98 cartridge. first time it has been refilled. how do i reset the printer to accept the refilled cartridge?
Dear jiraphe102,
Welcome, and thank you for using FixYa!
Unfortunately, you have the particular brand of cartridge that cannot be refilled. The smart chip on the original cartridge has expired; and will not reset.
You can purchase refurbished Ink online (meaning they have rebuilt the entire cartridge) at the link below.
Refurbished Ink
http://www.lainks.com/.sc/ms/pml/Inkjets--Hewlett%20Packard/Photosmart%20C4150
Or buy new cartridges.
Have a great day!
Sep 05, 2011 | HP Photosmart C4150 All-In-One InkJet...
Lexmark X5690 Use no. 4/5, after refilling, printer will not accept cartridges and won't print.
Try to reseat the cartridges into the printer.
Note that Lexmark does not recommend the use of 3rd party/refilled/remanufactured cartridges. These type of cartridges tend to degrade print quality and cartridge performance.
Jul 06, 2011 | Lexmark X2690 All-In-One InkJet Printer
Printer will not accept new cartridges. Printer is new and wants original cartridges to initialize ink system. Original cartridges are not availible. Tryed reset but did not work.
HP printers will not accept refilled cartridges. Are you trying to replace your empty cartridges with refilled cartridges? There is a computer chip in the ink cartridge that tells the printer when it is out of ink. If you try and refill it yourself, the printer will not recognize that it has been refilled without replacing the computer chip in it.
I think your printer is telling you that it needs HP brand cartridges that are original and not refilled cartridges. There is no way to "reset" an hp printer to get it to use an off brand or refilled cartridge that has not had the chip changed.
You can pick up a good refilled cartridge at a professional company who knows about changing the chip for less then a third of the regular price of an HP cartridge in a department store. However, HP does not want you to use refilled cartridges and should something go wrong with your computer and they find out that you were using them they will void your warranty on your printer.
If you are not trying to replace HP brand cartridges with refilled or off brand versions, I suggest your return them to where you bought them and exchange them. They may be defective cartridges.
Hope this helps?
Nov 11, 2010 | HP C6250 InkJet Printer
Printer won't accept refilled cartage
I had a similar problem and i cleaned the chip on the cartridges several times, eventually mine accepted them and started working. I turned the printer on and off several times and re inserted the cartridges before i got mine to work. This happened everytime i needed to change the ink unless i used a brand new HP ink.
Once I went to the shop and got some refilled cartridges and one of them wouldnt work at all. I presumed the old ones i had taken in would be refilled but apparently not. Anyway the shop replaced the faulty one free of charge.
Mar 12, 2010 | HP Office Equipment & Supplies
Refill lexmark 37xl ink
I own a Cartridge World ink refilling store and we do not refill the Lexmark 36 and 37. The reason is that your printer turns off the electronics on the cartridge when the ink gets low, so you can't reuse the cartridge. Your printer will only function with an electronically functioning cartridge. We NEVER recommend Lexmark printers. They are poorly made, don't accept refills a lot of the time, and across manufacturer their ink costs the most and is designed to clog the cartridge if you don't use it fast enough. We recommend HP printers that take integrated print head cartridges and Canon printers that take tank style cartridges.
Mar 01, 2010 | Lexmark X4650 InkJet Printer
How do i make printer accept refilled cartridge t
Maybe you did not refill and insert it very well.
follow this steps in refilling your ink
1. remove the ink cartridge from the printer
2. make a hole at the top end of the cartridge, the hole can be made under the label on the cartridge by using a sharp/hot pin.
3. if you are using a syringe and needle in refilling, make sure you did not insert it into the hole too much so that the cartridge does not get damaged in the process.
4. make sure the ink is not over-filled to avoid spillage which can cause a hell of damage on you printer as it does to my previous one.
5. Gently use the label or a masking tape to cover the hole and insert it into your printer.
Note: The printer gives a message that the cartridge is empty or non compatible, ignore the message and continue with your printing.
It is also advisable that you refill your cartridge not more than 2 times.
If this solution does not help you, contact me on holamydes@gmail.com for more assistance.
Aug 15, 2009 | HP DeskJet F4280 All In One Printer InkJet
Refilled Cartridges
I've refilled cartridges twice so far. The first time, the black was completely empty and the color was nearly empty. The printer accepted the color refill and not the black. The second time, I refilled both cartridges before they completely ran dry and both were accepted by the printer. The gauges don't register the ink, but it prints just fine. I just monitor the levels through the print quality. A friend with the same printer has told me that she only get 2 - 3 refills before the cartridge has to be reset, and that is a tricky process, but can be done.
Jul 26, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 Won't accept refilled ink cartridges
If problem is what I think it is (that is if you cleaned whole thing and it is connected proprely), you have only one option. To buy at least three cartridges...problem is due a small trick made by HP. Printer remembers at least two cartridge serial numbers, and then wont accept refilled ones. But if you first stick one, then the other, and on the end the third one(only this one should be really full) it should reset printer and it should foul it to accept it. But on some printers it needs up to five cartridges! What a waste of money :( Anyway, hope this helps...
Aug 19, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
195 people viewed this question
Seeker5211
Seeker5211
