Question about Dryers
Wirlpool dryer not working
My dryer was working then it keeps shutting off. Make a bit louder noise when it works, the noise is only slight. after it shuts off it wont start again until hours later. sometimes i'll spin it by hand and then it will start. I took it apart and cleaned evrything still nothing.........thanks for any info
    Problem Solver:
  • 13 Answers
Sounds like a bad motor to me.
Posted on Jan 09, 2008
6ya staff
SOURCE:
WHY DOES MY WIRLPOOL DRYER MAKE A HUMMING SOUND WHEN TURNED ON
Sounds like there's something in the lower wheel jamming the motor . GOOD LUCK APPLIANCES R EN
May 21, 2014 | Whirlpool GEW9250 Electric Dryer
Loud squeaking noise when you start up the dryer could it be a bearing dull squeak not high pitched a little bit of a grind sound
It does sound like a bearing or at least a lack of lubrication. But it could also be belt slippage if it only happens at the start. If it is the bearing it would be continuous and slowly get louder and louder.
Jun 18, 2011 | Whirlpool LER7646E Dryer
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
Magnatron suddenly making more noise. Much louder
Often over the years the Transformer laminations can loosen, from the on/off rising and collapsing magnetic fields, and then they sorta hum louder. I suspect this is what is going on. Shouldn't be too much of a worry.. keep an eye on it tho.
Jan 20, 2010 | GE JVM2070 Microwave Oven
Loud noise
Sounds as though it could be one of the motor shaft bearings is worn or wearing, or might be working its' way out of the end housing it was pressed into. The best way to verify it is the motor bearing is to remove the belt drive from the motor pully and operate the dryer while you listen for the sound, if still there, you've isolated the noise to the motor and can explore further to see what exactly is causing the problem.
If that isn't it, please provide the brand and model number so we can zero in on the probable issue.
Jul 13, 2009 | Dryers
GE Dryer makes deep sounds when hot and tumbling
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
wrytrtrs
Jan 28, 2009 | General Electric GE 7 0 Cu Ft Super...
I HAVE DRYER GE MOD #DWSR488EB2WW SER#ZG743601A ***HAVE GRINDING NOISE. RELPACED THE BEARING IN THE BACK. BELT SEEMS OK. PUT BACK TOGETHER NOISE CONTINUED. THE NOISE HAS A SLIGHT GRIND/SCRAPE IN ONLY PART...
The most likely cause is the front drum supports. There are 3 or 4 teflon strips (about a half inch wide and 2 inches long) on the top of the front panel that the dryer drum glides on. When these wear down, the drum can scrape on the plastic that holds them or on the metal frame around the door frame. Another possibility is if the drum touches the dryer exhaust vent pipe, most often only if the dryer is vented out the bottom of the dryer and the vent pipe has shifted up just a bit, allowing it to contact a spot on the drum with each revolution.
Oct 02, 2008 | Dryers
Wirlpool 6th sense dryer
bad control board.
Mar 29, 2008 | Dryers
Dryers Logo
124 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
