Question about Cell Phones
Difficult to get new housing for nokia 5500d - Cell Phones
I want to change full body of my nokia 9500
first on your task is surely to buy a genuine casing for your phone... changing it is another, it quite hard for a not-so-techie person to change it by himself because, 9500 series have a flex ribbon connecting the two boards(upper and lower) and it quite difficult to handle, and might get up torn.. i suggest you take it to an authorized nokia center for replacement of your housing
Dec 03, 2009 | Nokia 9500 Communicator
My nokia 5500d can't install games
That's the way the phone was made. Different phones has different file support.
Nov 17, 2009 | Cell Phones
I have a nokia phone and my house charger isnt
i would insist you to buy a new house charger from the authorised nokia outlet only.
Nov 14, 2009 | Nokia 6085 Cellular Phone
My nokia 5500d keeps switching itself off!!
re-load the firmware as it is unlocked. it can be done by some authorized dealers
Aug 12, 2009 | Nokia 5500 Sport Cellular Phone
Nokia 5500sport on it is booting ok going to rebootingloop itself
You try to format your phone for better use---
press--- *#7370#
or hard reset your Nokia N70 mobile phone by :
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Note: You will loose your data after formating the phone, so please make a copy of your data.
please rate this solution.
Thanks for using FixYa.
Feb 13, 2009 | Nokia N70 Cellular Phone
Unlocking password
Hi ediriajila,
You can get your Master reset code from here.
http://www.lur.nu/nokia_mastercode/security_code.php?IMEI=358658%2F01%2F97557
P.S. If I'm helpful, plz dont forget to give FIXYA rating for me!.
Thanks
arundir
Feb 07, 2009 | Nokia 6288 Cellular Phone
My amp goes in protect mode
Maybe the audio amplifier IC´s are damaged
Feb 06, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
How di remove call barring from nokia 5500d
Call barring
Call barring (network service) allows you to restrict the
calls that you make and receive with your phone. To
change the settings, you need the barring password from
your service provider.
1 Select Menu > Tools > Settings > Call barring.
2 Scroll to the desired barring option, and to request the
network to set call restriction on, select Options >
Activate. To set the selected call restriction off, select
Cancel. To check whether the calls are barred, select
Check status. To change the barring password, select
Edit barrings passw.. To cancel all active call barrings,
select Cancel all barrings.
Call barring and call diverting cannot be active at the same
time.
When calls are barred, calls still may be possible to certain
official emergency numbers.
Apr 09, 2008 | Nokia 6288 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
