Question about Dell Studio 1737 Laptop
Dell 1737 won't power up at all. Volume lights flash on bezier panel. That's it.
    Problem Solver:
  • 4 Answers
Try unhooking all power sources (battery and charger) and hold down the power button for a good thirty seconds. Plug the machine back up and try to turn it back on. I seem to run in to this a lot with dell and hp laptops.
Posted on Nov 16, 2009
    President:
  • 414 Answers
Robably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/daughter or addon card(s)..
..plz do check the following as in order:..
the Hardware part:..
1)a)inpower on mode, open/unplug the data/vga cable of the monitorfrom cabinet..see if raster or 'osd' is appearing on the monitorscreen..if so monitor is ok..else replace the monitor and see..[notapplicable in case of laptop]..
b) in case of laptop try to getoutput from external display unit/monitor using vga port..if there'sproper display in there..the problem is probably with either the 'lcd'or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4)see ifthe ram(s) is loose/faulty..open clean/remove carbon & oroxide formed on the teeth with an eraser n resit it..or replace with astandby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6)remove/cleandust neatly..dust is non-uniform in nature n may cause jam/shortcircuitry/excess resistance n many more..resulting an increase in heat..
7)open the CPU Heat-Sink with fan out of the socket..put some "Heat SinkCompound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit ittightly in position..
8)on main/mother board..see with a debugcard for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuitlie around atx connector..the crystal clock generator (if cpu isn'theating up)..
9) [in case of desktop] the smps itself may bdefective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic',or pwm switching regulator circuit..look fordefective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
the Software part:..
1)hva licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove allthe unnecessary startup items from here..(if u can't find what toremove, post me/us in ur comment with all the items listed in each nevery tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a)'AutomaticallyRestart' right click onmy computer->properties->advanced->startup nrecovery->(un check on the) Automatically Restart;
b)'ErrorReporting' right click on mycomputer->properties->advanced->errorreporting->disable error reporting->(uncheck on the) 'but notifyme when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r not a professional, always better to seek advise from ur system admin/vendor....
Dell Studio 1737 with Back lit keyboard but Cap Lock Doesn't Light
Dear Janice,
The light under the Caps key must have burned out. Take your laptop to a Dell service center and get it repaired.
Oct 19, 2012 | Dell Studio 1737 (Studio 1737-RubyR) PC...
Battery light on dell 1737 flashing constantly
This usually means that a cell in your battery is bad. I would suggest trying a new battery.
Oct 18, 2012 | Dell Studio 1737 Laptop
I have a Dell Studio 1737 - I replaced the motherboard and now there's no power. Just a Quick white flash of light
Are you sure you reconnected the main power connectors from the internal power supply to the mainboard, or motherboard? It sounds as if you haven't reconnected it completely, and some of the pins are not inserted into the block connector all the way.
-a.
Jun 24, 2012 | Dell Studio 1737 Laptop
What does diagnostic lights mean in dell studio 1535? How do I understand what the problem is by looking at the flashing lights? For instance, what is the problem if mute and volume up lights are blinking...
I have seen questions about the diagnostic codes (volume/mute LEDs) on Dell Studio 1735 1737 laptops where the Mute and Volume up lights stay on while the Volume down Blinks. So far as I can tell, by searching the web, no one has posted the meaning of these lights.
Well here is a link to tell what the light codes mean. If your system has power but is not performing a POST just check if the mute, volume up, and volume down multimedia buttons are lit in a sequence indicating a system problem.
Here is the wesite to explain those POST failure codes.......
http://www.techmonsters.com/DellTraining/bin/Foundation2010/Portables_Foundation_2010/Studio/Studio_1737/1737/general_ts.htm
Dec 08, 2011 | Dell Computers & Internet
Hey i have a dell studio 1737 and one of my soft touch keys is lighting up and it will not pay any of my music in my media player
On my Studio 17 I know there's a bug where the Volume Up/Down/Mute soft touch buttons would flash, and my speakers would not work while it was flashing. A simple reboot usually fixed the problem. Try that and see if it will make noise after a reboot.
Mar 24, 2011 | Dell Studio 1737 Laptop
The icons on the Dell Studio 1737 media control panel do not light up. The icons work but I can't see them. Previously, I had Dell on-site replace my non-working media control panel, but afterwards, even...
This issue can be solved by downloading the BIOS update and Dell Quickset Applications.
Go to support.dell.com
Download the BIOS and Quickset. And tehn install.
Dec 08, 2009 | Dell Studio 1737 Laptop
Computer Slowing, Problems Starting, Audio Problems
I think this a motherboard or may be a controller problem. Try contacting dell support.
Mar 18, 2009 | Dell Studio 1737 Laptop
Doesn't turn on, Mute and 2 volume lights constantly flashing
Your Pc motherboard is faulty, have a system engr look at it for possible reapirs." it won't boot ecept it is work on. Good luck
Feb 07, 2009 | Dell Computers & Internet
Dell Studio 1737 Laptop Logo
3,615 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
