Question about D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842)
DI-624 always lost connection after use about 10mins. to 20 minutes
  • awekhan Nov 19, 2009
    thxss.
    signalstrength - good,
    security - secured
    no interferance
    near to router,only use 2 pc. 1 connected by cat5cable and the other 1 wireless.
    when the problem occured the status light went off,so i plug cat 5e (from modem)direct to my pc ,it work ok.
    its these mean my wireless router damage and need to be replace by a new one.
  • D-Link Master
  • 32,281 Answers
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Posted on Nov 16, 2009
  • Chris Hingee
    Chris Hingee Nov 19, 2009
    Before you buy a new one.
    Power off the wireless router wait for a couple of minuter and power it up again and see if you can connect.
    Next reset the router back to the factory defaults. Power up the router and press the RESET button on the back of the router until the LEDs flash, release the button and configure the wireless settings. If you cannot remember the settings you previously configured then create new ones and the wireless card in the computer will need to be configured with the new settings.
    If this doesn't work then buy a new router.
All of the lights on my router are blinking and the internet wont connect
try to unplug router and telefone line for 20 minutes and try again, hope it works. Maybe a temporary problem with your provider.
Nov 01, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
WAN cable connection problem
Try a different cable to eliminate the possibility of a faulty cable.
Sep 09, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I dont know how to connect my wireless router
Download software and manuals from here:
http://www.dlink.com/products/?tab=3&pid=DI-624&rev=DI-624
(http://www.dlink.com/images/support/common/download-now.jpg)
Jul 28, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have a DI-624 router I am having trouble connecing
if you still have product code on BOX, go toD-link.com, or just reset the router, and the admin password is 111111 or 111111, i have same router just not around at the time>>
Apr 19, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Where can I get a free d-link DI-624 installer online?
There are multiple revisions of the DI-624, each with version specific drivers, firmware, installation guides, and other resources. Please use the descriptions below to identify your revision.
The links will take you to the drivers and install guides.
Note: The revision is located on the label on the bottom of the device next to H/W
The DI-624 Rev. A has 2 antennas.
<img src=http://support.dlink.com/prod_img/revisions/DI-624v.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI-624
The DI-624 Rev. B has 2 antennas.
<img src=http://support.dlink.com/prod_img/revisions/DI-624_revBv.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI%2D624%5FrevB
The DI-624 Rev. C has only 1 antenna.
<img src=http://support.dlink.com/prod_img/revisions/DI-624_revCv.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI-624_revC
Dec 25, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Can I piggyback a wireless router onto a hard-wired router?
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
Aug 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
X-Box 360 Wireless Connection
you just check the network. properties try then un plug the cable of the wireless connection, upter a 5 minutes plug it on
Jun 19, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Internet Connection
try a cross cable between di-624 and westell dsl router.
Jan 12, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI-624 can't login as admin
I was ready to give it up and pitch the thing, but I found this on another board and it worked:
login - admin
password - password (not blank)
Aug 08, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Logo
368 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
