Question about Raymarine M1500 15 in. Flat Panel LCD Monitor
Raymarine E120, after 4h on display went dark in
Raymarine E120, after 4h on, display went dark in daylight position (you see only dark violet when viewing close), as if all LCD cells would block all light. Changing to night position all information is here, but to dark to do any work.When presing repeatedly on "day" key, this toggles, when same for "night" key it remains readable but dark. Changing the brightness has no effect at all. Software update no change too. Boat is not in water yet, 13.4V, 28°C all time, back of E120 is free to air in aircond room, can not overheat.
Any idea would be highly appreciated as I am in the Philippines and Raymarine service is far far away.
  • blubaju Jan 17, 2010
    was one of the many electronic boards inside, changed in Hongkong at ELEKON for about 400?, flat fee in US would have been $1600 plus 2way courier or sending it to Raymarine UK, but no quote until oopened. The Raymarine offices DID NOT suggest any of their repair partners. I found and choose them on my own risk. Shipping to US or UK and back plus the repair costs as much as a new unit.
  • 732 Answers
Blubaju, probably cold-cathode-fluorescent-lamp backlight failure! if unit dosen't have electro-luminescent style backlighting. All LCD panels require WHITE light to see what is on the screen!!! Is same common problem that computer (pc) lcd monitors suffer from!!! I suspect that if your unit has CCFL's, that the SMPS power supply or CCFlamp INVERTER circuit has a problem common to ALL LCD monitors. I should think that any BIG TIME tv/monitor repair shop could examine the printed circuit boards and effect a repair for you! Just mention that you think it suffers from the BLACK SCREEN of DEATH syndrome!!! Also mention that to RAYMARINE!!! when you call them and **** them out!! 12fixlouie .5hr nrth/wst of Windy City Rate this on fixya if this msg helpful??
Posted on Nov 16, 2009
Testimonial: "My thought, hoped for anyone with similar problem who field-fixed it & give tech. hint or has diagram. Basically its a linuxPC in an OEM-case sold4$$$"
    New Friend:
  • 132 Answers
Backlighting failed, sorry
Posted on Jan 16, 2010
2001 dodge 2500 wiring radio diagram
2001 Dodge Ram 2500 Truck Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 30, 2016 | Dodge Cars & Trucks
Chrysler Radio Schematics
Be aware that you must choose a radio that is compatible with the trucks electronics or you will have electrical issues, don't cut the wires, use a plug and play adapter harness, you can get them plus info on the type radio you need from www.Crutchfield.com
Car Radio Battery Constant 12v+ Wire: Yellow/Red
Car Radio Accessory Switched 12v+ Wire: Run a wire to the steering column and use the dark blue/pink wire in the ignition switch harness.
Car Radio Ground Wire: Black/Orange
eft Front Speaker Positive Wire (+): Gray/Violet
Left Front Speaker Negative Wire (-): Gray/Yellow
Right Front Speaker Positive Wire (+): Dark Green/Violet
Right Front Speaker Negative Wire (-): Dark Green/Yellow
Left Rear Speaker Positive Wire (+): Gray/Dark Green
Left Rear Speaker Negative Wire (-): Gray/Light Green
Right Rear Speaker Positive Wire (+): Dark Green/Gray
Right Rear Speaker Negative Wire (-): Dark Green/Light Green
Dec 02, 2016 | Chrysler Cars & Trucks
Whats the color codes for a 2001 dodge ram 1500 stereo wiring harness?
2001 Dodge Ram 1500 Radio Wire Colors
Car Radio Ground Wire: Black/Dark Green
Mar 30, 2016 | Dodge Cars & Trucks
Cant see screen properley really dark
The backlight on your screen has failed and the lcd panel will need to be replaced.
http://compu-sat.co.uk/repairs%20lcd%20&%20touch%20pads.html
Jul 03, 2014 | Tomtom Go 530 GPS Receiver
Raymarine Raydata
You can find very good new and used Raymarine equipment on Ebay for about 1/2 the price of retail.
Mar 06, 2014 | Raymarine E26011 Bt Triducer F/ Raydata...
2001 dodge stratus coup raido wire diagram
i split the diagram in two just prtin and paste. and please leve 4 thumbs up thanks
May 07, 2011 | Dodge Stratus Cars & Trucks
I've bought an adapter thing, but I don't understand how to wire these wires.
  • Yellow - To the car battery of continuous +12VDC
  • Red - To ACC Power, +12VDC
  • Black - Ground, to bare metal or clean part of the car
  • Dark Blue - Motor Relay control lead for Antenna
  • Dark Blue / White Strip - Amp Relay Control lead
  • White - Front/Left Positive Speaker
  • White / Black Strip - Front/Left Ground Speaker
  • Gray - Front/Right Positive Speaker
  • Gray / Black Strip - Front/Right Ground Speaker
  • Green - Rear/Left Ground Speaker
  • Green / Black Strip - Rear/Left Ground Speaker
  • Violet - Rear/Right Positive Speaker
  • Violet / Black Strip - Rear/Right Ground Speaker
Nov 11, 2010 | Panasonic CQ-DP133U CD Player
I have an NEC '19 Multisync LCD 1920nx monitor. The display went blank and will not come back on. There's power going to it. It just doesn't display and image. How do i fix this?....thanks
the inverter or the lcd bulb may be out. inverters are cheap, bulbs are not. is the screen dark like its off or glowing black? if its dark like the bulb is off, next, look closely and see if you can make out a faint image on the dark screen, if so, it is likely the inverter.
Aug 05, 2010 | Mitsubishi Computers & Internet
The screen is turning blue. what is the problem? I just had the bulb replaced a couple of months ago.
Your Optical Block is failing. It needs to be replaced in order to fix this. The details of the mater, if you are interest: The Mercury vapor lamp used in the TV emits UV light. UV light has a short wave length and is therefore positioned on the violet side of the spectrum. Blue, being the closest of the 3 colors (red, green, blue) in wave length, deteriorates faster due to UV damage. UV light damages most things, it is unavoidable. If the UV light was trimmed out by filtration, your picture would be far to dark to view. So, it must remain at some level... even if in time it will destroy the LCD panels (which it does... in every rear projection LCD TV which uses a Mercury Vapor lamp.) As for the fresh lamp... this is common. Your lamp is back up to full UV power and your picture is bright. You can now see the damage progressing more quickly. I hope this was helpful or at least explained the "how and why" for you, best wishes.
Apr 22, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Raymarine M1500 15 in. Flat Panel LCD Monitor Logo
547 people viewed this question
Top Raymarine Computers & Internet Experts
David Payne
David Payne
Are you a Raymarine Computer and Internet Expert? Answer questions, earn points and help others
