Question about Microwave Ovens
I have an error code on my new LG LDF 6920st dishwasher. It runs for about 10 minutes and then dings and flasher LE
    Brigadier General:
  • 4,090 Answers
I would suggest calling the seller or distributor and having this unit replaced.
This error is not part of the consumer repair area and should only be done in A workshop here are two preevious ownrs experiences
1)
LE ERROR CODE
YOUR MOTOR RING CAME APRAT
THE UNIT EMPTIES AND REFILLS AND STOPS AT WHEN IT TRYS TO WASH I had to take the unit apart from the inside to comferm the motor is stuck. remove the racks the spinner in the bottom, the screen assy (1 foot in dia.) the wheel of pump with left hand threads, make sure it is unplugged, try to spin the garbage disspser blade. if it has trouble spinning then, pull out dish washer unit and flip over and remove the cover on botom and the motor and ground wire. good luck. i have had to replace mine twice now!
2)
I had the same problem and was told it was the motor. Well, it wasn't the motor. Take the front panel off & look at the wiring harness. There was a wire broken, not to mention the insulation was in the wrong place. It should be between the inside wall (dishwasher tub) and the wiring harness this way the wires wont get hot and break. Simple fix but, I would have never thought to take the door apart.
This unit is under warranty and should be attended to by the technicla support. LG are not good quality at any time, now made in Korea as cheaply as possible.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 16, 2009
  • mark ibbertson
    mark ibbertson Oct 12, 2013
    Display Condition LE = Motor Error
LG LMV 1680 ST shows error AC-1 and will not heat. The turntable does not turn either. The exhaust fan still works and the control panel still responds. What does this code mean?
Check the fuse. Also check out the safety switch by the unit door. If not closed when door is closed, no power is applied to either the turntable or the tube.
Aug 22, 2017 | LG Microwave Ovens
What is error code E-10 on a LG microwave oven, model MC- 7646UQ
This usually means a defective control circuit board.
Contact manufacturer for help.
Jun 27, 2017 | LG Microwave Ovens
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
My LG microwave oven not working.
not to b messed with even unpluged capasator holds 10.000 volts dc if it discharges onto u it can kill b carefull
May 03, 2015 | LG Microwave Ovens
Microwave ne se rechauffe pas
Premierement, assurez vous que le niveau de pouvoir est sur le maximum (10).
Si ca n'est pas le probleme, vous probablement aurez besoin d'un micro-onde nouveau.
Il y a un parti a l'interieur appeler le Magnetron qui ne fonctionne plus. Avec le cout de travaille, remplacement de cette parti peu couter jusqu'autant q'un nouveau machine complet.
Si votre machine est presque nouveau, contactez le magasin ou vous l'avez acheter, et demandez un retour ou echange.
Outrement vous devez acheter un nouveau. Essayez de faire un peu de recherche sur l'internet avant d'acheter un autre. Le modele que vous avez a recu beaucoup de plaintes de mauvais qualite.
http://www.reviewcentre.com/reviews126097.html
Desole de vous donner les mauvais nouvelles.
Merci et bonne chance.
May 12, 2011 | Neff H5430 Convection Microwave Oven
I have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the...
Dear Sir i have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the problem How Can Solved this Problem This prestige induction cook top model PIC 3.0 Only one week so please do need full
thx... Kundan singh Rana Baddi (H.P.) 09857455945 ranansd@gmail.com
Mar 23, 2011 | Microwave Ovens
I have a LG Dishwasher that keep displaying and "e" error signal can you tell me what is wrong
Have you checked the water inlet? If the water doesn't enter the machine quickly enough and error 1E will show.
Hope that helps.
Mar 06, 2011 | Microwave Ovens
Microwave runs but does not heat or cook food
If a Goldstar, LG or Zenith MV1610 or MV1608 is running but not seeming to heat a load placed in center of turntable, its probably because the "stirrer" intended to spread microwaves generated by the magnetron around the cook chamber is stuck so that most all the heating is directed toward the back and top rather than the center of the cook chamber. This usually occurs after cooking for longer than a minute with no load in the cook chamber - as when a model w/o a timer (such as a MV1608) is intentionally operated in cook mode to serve as a kitchen timer, or when a model with a timer function (such a MV1610) is accidentally operated for longer than a minute w/o any load. Before assuming the magnetron (usually warranted for 5, 8 or even 10 years) or other high voltage component such as diode or capacitor needs to be replaced, try “cooking” a 16 oz pyrex cup of water at full power on the outer edge of the turntable for 2-3 minutes - which usually reactivates the "stirrer" and restores normal cooking function.
Jan 18, 2010 | LG Microwave Ovens
LG LMVM2055: Cooked itself?
First you will need to answer a few quick questions between yourselves.
  1. Do you have life insurance?
  2. Is it enough for the wife and kids to survive on
  3. Whats the number for 911
After you answer all these questions, then pick up the microwave, and take it for a long drive.
There are bits inside there that will happily kill you days after it has been turned off. (some even weeks)
For the cost of a replacement in this case, it's not worth it.
Apr 18, 2008 | LG LMV2055ST Microwave Oven
Microwave Ovens Logo
87 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
