Question about Whirlpool Duet GHW9150P Front Load Washer
Flashing f- 21 - Whirlpool Duet GHW9150P Front Load Washer
  • 63 Answers
F21 means “long drain” – takes too much time for the water to get out. Check the drain hose and make sure it is not clogged or kinked. Check the drain pump filter for foreign objects. Check the electrical connections to the pump and make sure the pump is running. Check for foreign objects inside the pump. If it doesn’t help, replace the pump. To clear the display press PAUSE/CANCEL two times. Good luck.
Posted on Nov 16, 2009
How can I pair the anycom ARIS-21 bluetooth with
Just push the button for a long time until the led is not flashing but the colors of the led are changing red and green. I connected it to my laptop and my phone too.
Dec 20, 2009 | Anycom Aris21 Bluetooth Headset Wireless...
Load stops and flashes F-21
F-21 is a code that indicates "long drain".Check the drain line for kinks or obstructions. Check the pump. Check eletrical connections at the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or a jammed impeller. Hope this helped and best wishes.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Palaoma ptg-42pvn flashing a1 21 code
error code 21 is malfunction of air intake filter switch. You need to check and make sure the air filter door is properly seated and that the front panel is properly installed
Aug 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Message Light
press #409 to cancel message receive
press #64 follow by et\xtn on display to cancel sent message
mayb st 21 been assigned, but no body know.to check, call from all extn to displayed phone.check 1 by 1.
if light keep blinking for mic, try to change other key phone
May 27, 2009 | Toshiba DKT-2010 Corded Phone
Vdc and engine check lights both on
under dash connect together the 2 green multiplugs. The CEL light (Check Engine Light) will flash. Slow then fast. Count the slow flashes then the fast ones. I.E. code 21 will give 2 slow flashes then 1 fast = 21.
let me know the code and I will diagnose for you.
Dan
Dec 04, 2008 | 2002 Subaru Outback
Whirlpool Duet GHW9150P Front Load Washer Logo
120 people viewed this question
Dan Webster
Dan Webster
Sal De
