Question about Acer Aspire™ T180 PC Desktop
I cannot get online unless I restart the computer, then when I switch it off I have to go through the same routine to get on line again. Virgin say it is not a fault with the server.
  • Chris Hingee
    Chris Hingee May 11, 2010
    Is your computer connected to the Internet using a LAN cable connected to the DSL or cable modem? OR Is the computer connected to a router or wireless router?
    President:
  • 414 Answers
Though i need to know the os platform u r using..
however, this is quite common n critical problem of a trojan/ malware..it stops the 'server' and many more windows service(s), which also disables n hangs internet connection n disconnect option..ethernet n etc..itz not the problem with isp..
the Software part:..
1) open->start menu->run->type 'services.msc'->click run/ok->windows service will open->enable the services->by right click->properties->on 'startup type'->select Automatic from drop down menu->next click on the Recovery tab->then on the First, Second & Subsequent Failure->select change the value from Take no Action to Restart the Service->now set the Reset Fail Counter after: 0 Days and Restart Service after: 1 mins:..
Server, Computer Browser, Remote Registry, Secondary Logon, Windows Time, Remote Procedure Call (RPC), DNS Client, DHCP Client, COM+ Event System, HTTP SSL, Network Connections, Network Location Awarness (NLA)..
2)hva licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
3) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
4) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removeallthe unnecessary startup items from here..(if u can't find what toremove, post me/us in ur comment with all the items listed in each nevery tabs herein)..
5) remove all unnecessary software from add/remove programs..
6) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
7)disable the following:..
a)'AutomaticallyRestart' right click onmy computer->properties->advanced->startup nrecovery->(un check on the) Automatically Restart;
b)'ErrorReporting' right click on mycomputer->properties->advanced->errorreporting->disable error reporting->(uncheck on the) 'but notifyme when critical error occur'..
8) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
9) if problem persists try reinstalling os..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 16, 2009
I have a Whirlpool duet front load washer model # GHW9150PWD. I have an error code of F 02 and SUD. I have so far cleaned the filter and the lines, replaced the pump, replaced the water pressure swith and...
6 - 1
DIAGNOSIS & TROUBLESHOOTING
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1.
The Remaining Time counter is stopped.
2.
The digital display shows Sud.
3.
The Drain Pump is turned OFF.
4.
The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5.
While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6.
Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7.
After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE:
If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses MANUAL
Oct 31, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My dell dimension computer won't turn on. When I push in the button, it only flashes orange and then won't turn on.
Plug the computer into a power strip that has an on/off switch. Turn the power strip on. Press the computer power on button to start as normal, but after after one second turn off the power strip switch just long enough for the fans on the computer to slow down, but the amber computer led doesn't turn off and then turn the power strip switch back on. Computer should start and run fine. Computer typically can be shut down for up to 5 minutes and restarted normally--any longer and you have to sue the power strip power switch routine again
Oct 25, 2010 | Computers & Internet
Printer was moved and is now telling me 'printer off line'??
Turn off your printer and disconnect the usb cable from the computer, restart your computer, now reconnect your printer to the computer's usb port, switch on, and check the status of the printer whether it's still offline or online. If it's offline, click "Start" > "Printers and Faxes", Right click on the printer's icon and select 'User printer online", give a print command and see if it's printing or not.
If the problem still persists, disconnect the printer, uninstall the drivers, restart your computer, and again install the printer's drivers and connect the printer when you are asked to do so. This will fix your problem if there's no physical or internal damage on the printer and the cable.
Good luck.
Thanks for using FixYa.
Jun 28, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Initial Wireless Router connection problem.
Are you trying to install the router.You can do it manually
without the CD.
MAke sure that your computer is able to go
online through the modem.
If your computer is able to go online
through the modem
Then you need to connect the computer to the
router ad the modem to the router.
open the set up page of the
router and change the settings of the router according to the
ISP.
Click Here for step by step by instructions
Jan 16, 2010 | Belkin Computers & Internet
I have an unlocked bigpond modem ,and I am trying to connect to Virgin broadband on my Ibook. Virgin said ring Bigpond and big pond says buy a bigpond wireless modem and we will connect you. But I have a...
once you get the setup disk from virgin and you put your sim into the Bigpond modem, gollow the Virgin prompts it should work once you have searched the right network parameters and entered the IMEI code etc. It takes about 24 hours for virgin to switch you online.
Thanks for using FIXYA
Nov 24, 2009 | Computers & Internet
Need code for chipped box today
These codes are for virgin in the wigan area and work perfectly till virgin change them again
00 line 3F 32 37 03 D0 73 84 84
01 line C6 64 1D EF 47 5A 0E EF
Dec 01, 2008 | Televison & Video
Cannot Install it Successfully
Restart you computer. Turn your printer off, wait 20 seconds and turn it back on again. Load up software you use to talk to the printer.
What interface are you using to connect to the printer?
Jul 17, 2008 | Star Micronics TSP400 Label Printer
Monitor turns off
that would have to do with the invertor board inside the lcd monitor.
Apr 21, 2008 | Fujitsu Siemens Business Line 431V FA 17"...
Acer Aspire™ T180 PC Desktop Logo
118 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
