Question about Home Security
A wiring diagram foe a brinkmann hg300 infared
A wiring diagram for a brinkmann hg300 infared motion detector
3 Suggested Answers
  • 16 Answers
SOURCE: Paradox 525D Motion Detector wiring up
nc c + - Y G Tmp Tmp
nc and c is relay output normally closed
+ and _ is 12vdc input
Y and G is bus connection
Tmp is tamper output also normally closed
Posted on Apr 13, 2010
ginko
  • 19396 Answers
SOURCE: question with visonic duet-AM
Hi.
If you use as end of line connect the resistor in parallel between Alarm (NC) and EOL. I am saying this just in case you are using Tamper NC.
If that is not the problem, and resistor is wired correctly, check status of tamper switch on sensor.
In case this does not help, please let me know what specific error is prompted by Vista.
Here sensor manual
Here Vista.
Regards.
Posted on Apr 23, 2011
Tip
How to test an infared remote control device
How can I tell if my remote is working? You could invest in an infared detector pen or device that will detect the infared signal or you could use a common cellphone with camera mode. Place the phone in camera mode and hold the remote up to the camera lens. By depressing the buttons on the remote now you can actually see the emitted infared light slowed down to a visable light, thereby determining that any or all buttons of the remote are functioning properly.
on Dec 01, 2009 | Televison & Video
I want my motion securtiy light to acturally stay on all night. more after animals than people, can this be done?
Usually with mains power motion lights if you switch them on and off two or three times and then back to on, the light will stay on all the time. To put it back to motion, switch off, wait a minute and then switch to on.
This is borne out by this article
Search Results Most motion detectors have a built-in override:
  1. Normally the switch is kept on all the time. ...
  2. If you turn the switch off and on within a second or so, the light will stay on, and this overrides motion detection.
  3. To go back to normal operation, turn the switch off and wait ~10 seconds, then turn back on.
More items...
lighting - How can I override a motion detector light? - Home ...
https://diy.stackexchange.com/questions/.../how-can-i-override-a-motion-detector-light
make motion security light stay on Google Search
Sep 04, 2017 | Home Security
Do you have a wiring diagram to wire a security motion detection light between 2 3-way switches so switches can be turned: (on-Motion)/(on- Completely) from 2 differemt locations?
One of the switches needs to be a 4-way then the PIR will act as any other switch. The downfall is if the lights are on and motion is sensed they will turn off.
My preference is to connect the contacts of the security device across the travelers of the three way circuit. The travelers are probably the red and black in the three conductor cable. When motion is detected the lights will turn on regardless of the settings of the three way switches then after timeout they will turn off. If they are turned on with one of the three way switches nothing will happen when the motion detector turns on except you cannot turn the lights off until the security device has turned off.
I hope this helps. The motion contacts need to be isolated from the motion detector power.
Feb 20, 2014 | Electrical Supplies
Hi my question is motion spot light has has two black wires one from each light and two white from each light and one red from the motion detecter which is connected to the black wires there are two wires...
The red wire from motion detector connects to both of the black wires from the lights. The black wire from the motion detector connects to the incoming black wire from the switch or source. The white wire from the motion detector connects to both of the white wires from the lights and to the incoming white wire from the switch or source (all white wires are under one wirenut).
Dec 18, 2010 | Home
Mar 31, 2010 | GE Security Simon 3 Wireless Home Security...
How to wire a cooper industries 6107 3-way motion detector switch
I opened the box and traced the lines to see which are connected
when the switch is turned on and I left the red wire disconnected.
Jan 28, 2010 | Cooper Wiring Devices Motion Sensing...
Wiring diagram 3 way motion detector switch I want the motion detector to be in the hot line box, and I want a regular 3 way to turn the light on from the load box. So far I can only get the motion...
Sorry, but you need one extra wire between the switches to wire "the opposite configuration" that you want :-(
That means going into the attic and pulling another cable :-( I can walk you through it if you are willing to do all that work.
The only other solution would be to purchase the commercial version of that motion switch, which would also require a sensor at _each_ switch location :-(
Jan 02, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
Dsc sensor not operating properly. I want to change it, is this very difficult? Thank you.
You don't mention what type of sensor. I assume it is a motion detector. Before replacing I would strongly suggest you first remove all power from the system by disconnecting the backup battery inside the control panel then pull the system's power transformer which should be plugged into an electrical outlet nearby. You will know that all power is removed by looking at the keypad - all lights on the display are off. Next remove the motion detector's front cover. Some detectors have a small screw on the bottom so that when removed the cover pops off. Others need to be opened using a flat blade screwdriver and prying off the cover. Once the cover is removed there should be a 4 conductor wire that is wired to a series of terminals. Observe the polarity of the wires, disconnect them and remove wall mounting screws. Install new unit. Be sure when wiring to connect power wires correctly. The 4 conductor wire should have a red (positive) wire and a black (negative) one. Connect the red to the + or pos terminal and the black to the - or neg terminal. Read the instructions that came with the new unit if in doubt. When finished plug the power transfomer back in then reconnect the battery (in this order). If power is connected properly the motion detector's red walk test light (indicating motion) should light whenever you walk in the protected area. Also make sure the system recognizes motion by first closing all protected areas such as windows and doors to get a system ready or green light indication on your keyad, then walk around the protected area. A properly working detector will show you a fault on the keypad everytime the system senses motion.
Sep 11, 2009 | DSC Home Security
Home Security Logo
192 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
