I have a Yamaha Rx1700 Amp, Samsung 42 inch plasma and a Hitacchi DV-DS163A HDD/DVD Recorder. Its all set up for the home movie thing and running foxtel. I have just moved and have set up the DVD incorrectly as I can hear a DVD but can;t see it. I'm told its something re the hdmi not set up correctly as I can't change the resolution on the DVD player as a result.Can you assist?
  • 5,807 Answers
To change the resolution on the DVD player
you need to use one RCA cord to be connected to the vacant video input
of your TV from the DVD video out.
you need to set the TV to TV/video till you get the image from the
DVD player.
Posted on Nov 16, 2009
  • Rommel Cana
    Rommel Cana Nov 16, 2009
    you will know you have a correct setting on the HDMI when you change the TV/video selector and select HDMI as the source.
    if you cant still use HDMI then try using the yellow cable ( for video) connected from the DVD unit. ( RCA connection first then HDMI later)
    if you are having video and no sound , you can directly connect the audio input of the Yamaha RX1700 amp to the audio out of your Hitachi DVD Recorder, only the volume is on the DVD.
    there is also a volume on the Yamaha Unit but that is dependent on the DVD unit assigned volume. ( otherwise set the DVD volume near to full ) and control the volume using the Yamaha unit or remote.( if there is available)
Upgraded older HD TV to a Sharp 70" smart TV & Home Theater Receiver (Yamaha RX-V575. Have AT&T U-verse HD Cable box. What is the connection sequence using HDMI cables. Searched Yamaha and AT&T sites and...
I dont know about your particular hd hookup , but I take the hdmi cable out of my dish reciever/dvr [digital video recorder] and run it straight to the hdmi input #2 in the back of my apex 40 in lcd-hd-tv
I think take the hdmi output from the at&t u-verse cable box and plug it into the hdmi input of your 70 in sharp smart tv
that will get the input signal from your cable box ,both video & audio, into your tv set.
on the back of your tv set
there should be audio outputs for home theater audio systems that would plug into the audio inputs of the home theater system.
prehaps i am wrong because you say that your yamaha is a home theater* reciever.* is the yahama more than a home theater audio system? What does it recieve?
Idea-- the salesman that you bought it from should be willing to help tell you how to hook it up.
also consider that there are many different ways to hook up vcr's and then dv recorders and dvd recorders and external 2 tera bite hard drives into my tv & dvr . I got that all hooked in & a rats nest of wires. so i can record in hd or sd,on vhs or dvd or dvr
point is that you cant hurt anything by plugging the wrong plug into the wrong jack, as long as the same type of plug goes into the same type of jack.
If its right,it works, if its wrong, it wont work until you plug it into the proper jack.
im sorry ,im 65 am not into knowing all the latest and greatest cutting edge tech ,but i am begining to catch up on my hobby, movie recording tech.
Oct 08, 2013 | AT&T UVerse
Can you show me how to connect up the scart and aerials up to the following so they operate correctly Samsung PS42C450 42-inch 600Hz Widescreen HD Ready Plasma TV with Freeview SAMSUNG DVD-SH893M 160GB...
hello firstly scart lead from sky box to tv1 in) this is at the top there are two AV inputs ,,,on the bottom AV slot this is where your DVD conects too).iff you are using sky you will not need aerial in back of tv as this is for analogue use such as indoor antenna or outdoor antenna or iff using horizon the scart lead will suffice for all goodluck
Mar 19, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
On the samsung sh893 is it possible to copy movies from the hdd to usb? if so how
No,u can't copy Hollywood movies,it codes protected.U can use a computer with a program that design to decodes and able copy Hollywood movies.
May 21, 2010 | Samsung DVD-HR735 DVD Recorder/HDD...
I have recordered many home movies to a dvd+r
Dvd+r disks are the least compatible to most devices.
Try using Dvd-r instead.
Dec 02, 2009 | LG RH1999H DVD Recorder/HDD Recorder
DVD player now showing in black and white
Make sure your av channel is av2 and not av2s as this will give b/w playback
Sep 13, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Marantz SR8500
Check the settings on your dvd player!. It might be set to PCM
instead of HDMI.
Jan 27, 2008 | Marantz SR8500 Receiver
 Grubhead
Grubhead
